Question about Hotpoint FFA60 Bottom Freezer Refrigerator
FFA45W My Hotpoint FFA45W Fridge Freezer has the alarm message "eat all food in the freezer immediately" and both the fridge and freezer do not seem as cool as they should be. (The back feels "normally" warm if thsi is of relevance). I know very little about FF's, but am reluctant to pay hotpoint their £90 call out charge without getitng an inkling if I could fix thsi myself, or get someone else to repair it much cheaper. Any thoughts anyone ?
  • finnt Jul 01, 2008
    have same problem hotpoint said was thermostat 30 pounds or control panel 90 pounds what did it end up being the problem for you
  • rodwww Jul 09, 2008
    Hi
    I've had this a couple of time's. For me it was the top draw in the freezer compartment not fully closing so the door was slightly open! This in turn caused the freezer to freeze up behind the pannel at the top and stop the circulating fan in the freezer compartment so although the fridge was working the freezer could not cool. Once the freezer defrosted it was back in business again. Hope that helps :-)
Hotpoint FFA47X fridge/freezer. I have had this fridge for 3 years now and has always on regular occasions decided to defrost when it feels like it and asks me to consume all the food immediately! I have wasted massive amounts of money on food and calls to hotpoint and have had a hotpoint engineer out to sort the problem about a year ago. It goes fine for a few months..then it defrosts all over again! Its just done it again, luckily I am not using the freezer anymore it only had some peas in there. Has anyone had this problem and solved it?? I would really like to use my freezer again but am loosing patience with hotpoint! I'd be very grateful for some advice.
Posted on Jun 23, 2009
Bosch kann58a50gb/o8 fridge not cooling freezer seems ok
See or hear if the fan inside is working. Im not conversant with your model. Some units have 2 fans , 1 in the freezer and 1 in the fridge. Some only have1 , which will be in the freezer only. If the fan fails, the fridge cannot blow cold air into the food compartment. Generally, when an evaporator fan fails, the fridge doesn't get cold and the freezer overfreezes causing an excess ice buildup in the freezer.
Feb 23, 2015 | Bosch Refrigerators
Freezer is keeping food frozen, but fridge is not very cold
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 08, 2011 | Hotpoint Refrigerators
My hotpoint side by side hss25gfpaww is not cooling on the fridge side but the freezer seems ok. Fridge not getting cold
heatman101
May 03, 2011 | Hotpoint HSS25GFP Side by Side...
Hi,im having trouble with a hotpoint fridge,model number ctx14cybjrwww.Problem is the fresh food area isnt cold,yet the freezer area is.Thx for any help
heatman101
Mar 15, 2011 | Hotpoint Refrigerators
Hi, my Hotpoint ff200e fridge freezer is cooling but not freezing, compressor wires are warm and compressor itself is quite warm, top fridge is not cooling enough, then the lights on control panel start...
Hi.. feel the dividing rdge between fridge and freezer.. is it warm?.. chances are that the little fan at the back of the fridge freezer that helps cool the compressor, has snagged own it's own wire... it's a weak fan, like you get in a computer, but it does a lot of work.. without it, the coolent does not do it's job, which results in your device not cooling things properly
Apr 24, 2017 | Hotpoint HTM17BBSSA Top Freezer...
I have frost free hotpoint future,the fridge seems to be working but the freezer isnt at the minute, the food is not freezing and the fan does not seem to be working! it has no suction on doors either, my...
Defrost timer/control is sticking...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101.
Oct 15, 2010 | Refrigerators
Hotpoint frost free ff200e flashing lights and beeper freezer food defrosting
Make sure fridge OFF freezer OFF ... then turn mains on. ONLY turn freezer to max, after 30mins put fridge to 1care ... this should overcome the problem of the flashing lights. When both nice and cool turn settings down. it worked for me
Jul 05, 2009 | Hotpoint Refrigerators
Ffa70 hotpoint fridge freezer
Adjust the temperature control for the freezer to a normal setting. Fast freeze is only for when new products are put in that need to be frozen. This locks the system into a continuous run mode and could be responsible for the freezing condition in the refrigerator section. Check the temperatures with a thermometer as the sensor for the freezer temperature could be bad causing the light to come on.
May 18, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
Fan not working on fridge section of Hotpoint Fridge Freezer Model FFA90
the problem is there is a build up of ice insid of the freezer .
What you need to do is take out all your draws in the freezer and you will see a plastic backing held on with about 8 screws . undo all the screws and the back should come aay and you will see all the ice built up . just use a hair drier to melt the ice and that should cure your problem.
Nov 04, 2007 | Hotpoint FFA90 Bottom Freezer Refrigerator
Food is defrosting in my hotpoint frost free fridge/freezer
Can you hear the compressor running? Is the fan inside the freezer running? It could be that a wire connection has come loose during the move. Was the fridge laid on it's side during the move? If so you probably have compressor oil restricting the refrigerant system. If compressor and fan are running you will probably need a qualified refrigeration tech to check it out.
Oct 03, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Hotpoint FFA60 Bottom Freezer Refrigerator Logo
673 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De GO PATS
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
