Question about LG Dehumidifiers
Our dehumidier runs, all the buttons respond, but no water is produced. We had a hose atached for a year , well last Summer, and i thought all was ok but i never saw water running. i figured it was because of the hose, it ran too slowly to see, but now i think it has not been producing water for a long time. i have detached the hose.
  • 3 more comments
  • johnnyde26 Sep 03, 2010
    i HAVE TRIED RUNNING IT WITH IT'S OWN WATER CONTAINER, BUT STILL NO WATER.
    HOW CAN ICHECK TO SEE IF THE COIL IS BAD/
    jOHN
    I took the rear cover off. I see one large black coil, which is clean and free of dust.
    I have an 18-Range Multitester. One of the measurements is for ohms.
    On the selector knob their are numbers that it can be set to for OHMS : RX1, RX 10, RX 1K.
    On top of the coil itself, there is a red wire attached to a loose fixture on one side and attached to a second fixtue are 3 , maybe 4 wire.
    What are the exact steps i need to do now to test/ what setting do i switch the tester to/
    Do i actually detach the wiring from the coil or just their covers. ? Do i plug in or unplug the Dehumidifier?
    John
    I disconnected the connectors from the coil,plugged the Dehumidifier back in and turned it on. I attached the black and red probes from the multitester to the disconnected wires, but got no readings.??
    I am afraid i must go out now, but will return in about 4 hrs. Please advise how i should proceed then
    thanks
    John
  • johnnyde26 Sep 04, 2010
    is the coil the black cyclinder about 6" high?
    Is it supposed to be cold when it is working properly?
    What about the short copper tubing, what is their role?
    So is it that I disconnect the wiring from top of black cyclinder and whith the unit plugged in and power turned on , i put the multitester prong to the connections on top of it? does it make any difference whether it is the red or black prong i am touching to a particular connection?
    John
  • 3,083 Answers
Here is part of a customer review on Amazon.com:
Cons: To get proper operation must set unit to 2 hour timer cycle. Unknowledgeable customer support.
Here is another review that describes the problem, and lack of support LG is providing:
tomeske's Full Review: LG DH504EL Dehumidifier Same story as another review I read. LG DH504EL Dehumidifier (Product number 3850A20500F) worked well, fairly quiet. Bought it June 10, 2005 from Home Depot. It is now May 18, 2006 and appears to be running. I can hear the compressor running, but it collects absolutely no water. Used only in my basement and was never moved or bumped. I cannot find it now on the LG website, they must know it is unreliable and discontinued producing or selling it. The LG Customer service put me on hold and then after 20 minutes, hung up. I'm sorry, but Life is Not So Good.
Lastly, but probably foremost, some of LG's humidifiers are on a recall list. Here's an excerpt from the web recall site:
Sold at: The Home Depot, Walmart and Heat Controller Inc. nationwide from January 2007 through June 2008 for between $140 and $150.
Manufactured in: China
Remedy: Consumers should immediately stop using the recalled dehumidifier, contact LG to determine if it is included in the recall and return it to an authorized LG service center for a free repair.
Consumer Contact: For additional information, contact LG toll-free at (877) 220-0479 between 8 a.m. and 7 p.m. CT Monday through Friday and between 8 a.m. and 2 p.m. CT on Saturday for the location of an authorized LG service center for the repair, or visit the firm’s Web site at www.30pintdehumidifierrecall.com
I think this is just a poor product, from the numerous reviews. Maybe your unit is on a recall list, hope so.
Good luck, hope this helps, and thanks for using FixYa.
Posted on Sep 04, 2010
  • 2,841 Answers
Hearman101 posted a great tip on this very problem and it is quite thorough. You can read it here. http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in This should answer your question.
Posted on Sep 03, 2010
  • 11,896 Answers
You can try running the hose in a bucket or pan. The hose must be lower then the unit to properly drain. Make sure the filter is good as well so it can absorb the moisture.
The dehumidifier removes moisture from the air by passing the moist air over a cold dehumidifer coil. The moisture condenses out of the air on this coil and goes to the drain. You may have a bad coil
  • 2 more comments
  • Nate Stansfield
    Nate Stansfield Sep 03, 2010
    you can use a voltmeter and test power to the coils. Make sure coils are clean and free of dust. You can also disconnect the wiring to the coils and use an ohmmeter and place one probe on each coil connection. You should get a reading, if not it's bad. If you do get a reading, then coil is good and refridgeration system is faulty and a tech with equipment would have to service it.
  • Nate Stansfield
    Disconnect the coil. Set meter to RX1. Place a probe on each connector and check reading. Do this to all connectors.
  • Nate Stansfield
    Nate Stansfield Sep 04, 2010
    Not testing the wires, just the coil connections itself. The wires would have to be tested with a voltmeter, however it is peculiar you didn't get any ohm readings on the wires with the power on. May have a defective control board unit. Does all the lights and everything works except no water pickcup? If that's the case, board should be ok, coil is likely the problem. Test the coil with ohm setting RX1
  • Nate Stansfield
    That would be the coil. It should be very warm when the machine is on. The tubes carry the liquid. The coil should be warm.
I have a danby dehumidifier...when I turn it on the fan goes on, but the actual dehumidier does not...the light about the first button does not light up. What Can i do?
It's probably in the wrong mode. This could be from a number of causes including you have not emptied the water chamber.
Aug 13, 2014 | Danby Dehumidifiers
The dehumidifier is running constantly but no water is being collected
Sounds like you're in a wintery environment. Most people operate a humidifier in those locations because the air is too dry. If that is your situation, I suggest you turn the dehumidifier off until Summer and save electricity. If will pull moisture out of the air in the summer.
Jan 11, 2013 | Haier 45-Pint Dehumidifier
MY FEDDER DEHUMIDIER RUNS ALL THE TIME AND CLLECT VERY LITTLE WATER AND THE AIR FILTER IS CLEAN.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Aug 18, 2011 | Fedders A7DH45B2A Dehumidifier
My dehumidier is not pulling any water into the bucket. Runs fine. About 1 year old.
If the unit is not pulling water into the bucket its probably not that humid in that area anymore. If it aint broke dont fix it.
Jun 27, 2011 | Dehumidifiers
I have attached the hose to the Danby dehumidier and put the water tank back into the machine. I pressed continuously flow and the humidity indicator is at 87 The water tank was full later with the...
Did you punch out (or cut) the plug that the hose connects to? If not, its blocking the water from draining to the hose.
Please rate 4 stars if this is helpful. Thanks and good luck!
Oct 14, 2017 | Danby Dehumidifiers
Goldstar dehumidifier model DH305Y6 is there an outlet on this model for a hose so can drain into sump pump?
I have a Goldstar dehumidifier, Model DH305Y6. I bought it about 5 years ago at a local Walmart. During the summer I run it in the basement, here in south-central Pa. When it was brand new it worked very well, for about 2 yrs. Then it began turning on & off very irregularly. At first I thought it was the sensor on the front of the coils. So I moved it to the lower left side of the coils, and had the same results. The other day the water heater in the basement developed a leak. About 300 gals. of water covered the floor. After sumping/wet-vac'ing down to a wet carpet, I pulled out the dehumidifier and plugged it in,(the filter was cleaned before put away last summer). It began its on/off cycling again. It runs for about 2-3 mins., then shuts off for about 5-10 mins. So, I took the On/Off switch apart and read the resistance. It read 48k, for the 50k switch. I turned the switch all the way left to all the way right and it went from 48k, down to about 8k. The two wires to the switch were attached to the #2 and #3 poles,(only 3 poles). I did some testing, then removed the wires and re-soldered them to the #1 and #3 poles. I put everything back together, and now it works. It runs constantly, but it works/runs just fine. I need to get the basement dry, so I will let it run until the job is done. In the Spring I will get a new 50k potentiometer,(on/off switch), and see if that works. I will post results if I remember to.
Sep 29, 2009 | Goldstar Dehumidifiers
Dehumidifier runs but does not collect water
I have dehumidifier Whirlpoot Gold Model #39R171E Serial #H/XE11M1K 6203A it was working fine last year, but this year it is not collecting any water, it is running for day. I opened it, cleaned the filter (which was mostly clean) & it still has not water in bucket. What is wrong & is it possible to fix it by myself.
Jun 10, 2009 | Haier HDN655E Dehumidifier
Dehumidifiers Logo
171 people viewed this question
Top LG Dehumidifiers Experts
Bill Long
Craig Butler
Craig Butler
Gil Shultz
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
