Question about Kenmore Sewing Machines
How can I loosen the belt on an old Kenmore model # 117.841?
There are 2 hex head bolts ( 7/16 ) in the back, under the motor. You just have to loosen the screws and lift up on the motor, this will loosen the belt.
Posted on Nov 24, 2010
My vintage kenmore hand wheel was frozen now it turns manually but not when I use the foot pedal, then it won't turn
Either you will replace the belt or have to adjust the motor/belt tension.
1. The motor can be loosened by a couple of bolts. This allows the motor to be moved to adjust the tension of the belt.
2. The tension can be adjusted properly by turning the motor on with the foot pedal; low speed.
3. While the motor is running move the motor in a fashion that will loosen or tighten the belt. The correct location will allow the motor to run at it's highest speed.
4. Re-tighten the bolts and retest the machine.
May 04, 2017 | Kenmore Sewing Machines
Kenmore sewing machine model 158-17031- motor runs well but think the clutch or something is stuck
Has it been oiled lately? If not, it could be seized. Old oil turns to glue and then varnish unless it is regularly maintained. Make sure to use only fresh, good quality sewing machine oil or liquid Tri Flow Synthetic Lube. Slowly rock the hand wheel and apply a couple drops every place where metal rubs against metal--no oil on belts, rubber, synthetic parts! If it is still resistant, direct hot air from a handheld hairdryer into the internal mechanism and repeat the process until things are loosened and moving smoothly again.
A sewing machine should be cleaned and lubed every 40 hrs of working time or every 6 months if not in use.
Oct 03, 2016 | Kenmore Sewing Machines
How to replace kenmore model 158 13400 belt
Good morning
If you have got the belt, I would remove the old one and put the new one on as the old one disappears. I used to change belts that way when I had a machine.
Enjoy your coffee
Kolbrun
Jul 05, 2012 | Sewing Machines
I can't loosen the wheel to wind a new bobbin on model 158-1340280
it may be seized up, depending on how old your machine is. I had the same problem with mine & used a hair dryer to blow hot air on it until I was able to loosen the wheel.
Mar 16, 2011 | Kenmore Sewing Machines
I need to replace the motor belt on a Kenmore sewing machine
You can find the belt you need here:
http://www.sew4less.com/QuickSearch.php
if not in stock try here for the part you need:
http://www.a1sewingmachine.com/belts.html
Jul 07, 2009 | Kenmore Sewing Machines
I have a Kenmore 30 Stitch, model 385.1884180 serial #21105527-it has started making a grinding noise when using stretch stitch choices. I have cleaned the machine. But the sound comes from inside the arm,...
easy fix... same thing happened to me. take the back part off by the on and off switch and you'll see the loose belt. loosen the single screw next to the smallest pully and adjust tension.
Apr 15, 2009 | Kenmore Sewing Machines
Broken belt
If you are having problems finding the correct belt, sometimes the stretch belts work great for these situations. You can find many of them on ebay.
Nov 14, 2008 | Kenmore 15516 Mechanical Sewing Machine
Kenmore 10 Sewing Machine
i have a kenmore10 model 1249180 ehwn i sew it squeeks i oil it i dont know where the squeek is coming from
Dec 05, 2007 | Kenmore 744-08BH Mechanical Sewing Machine
Sewing Machines Logo
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
