Question about Acer (56.04200.H22) (5604200H22) 200-Watt Power Supply
When I turn the computer on you hear a clip and a light for a second and then nothing.
  • Acer Master
  • 27,725 Answers
Sound like you have a dirty hard drive first remove all the dust around your hard drive then give your hard drive a firm tap on the side to free the reader arm which is getting stuck on the platters while you are cleaning the dust you may as well clean your computer of dust using a fine air blower from an air compressor making sure there is no moisture in the air line then you might
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
good luck
hope this helps
Posted on Sep 03, 2010
Gateway gt4016 wont turn on you can hear the fan and light flicks on for a second but then nothing changed the power supply nothing
try rebooting your coumpter is in sleep mode it takes a long time but you will get it back on .... keep pushing the power button aventally it will start up
Jun 30, 2012 | Gateway GT4016 Desktop PC
Fan just work for seconds
Replace the fan or your computer will run hot and keep turning off.
Or are you saying this is what happens when you power on the computer? if so: When you press the power button do you hear fansrunning, hard drive spinning, lights on the computer, hear any beeps or lightsconstantly blinking, hear the DvD/CD drive click and the light on the drawer ofthe DvD/CD turn on for a second or two? If so the laptop is trying toboot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Mar 28, 2012 | Computers & Internet
I accidently shut my computer down with hibernation before leaving. When I come home, the computer will not turn on, no lights no noise, nothing. How do I unlock the hibernation? Or could it be something...
You need to hit the power button just the once to bring it back out of hibernation mode. It may take around 30 seconds until you hear your computer starting to boot back up and a little longer for the screen to come on.
Failing this, you can try a hard reboot by holding down the power button until you hear your computer re-boot. Usually you need to hold around 10 seconds. However using this last method as a final resort will result in your computer telling you that it did not shut down properly.
Jul 08, 2011 | Gateway 310X PC Desktop
My Toyota Sienna shows VSC light on the broad. What Should I do?
If you've had your vehicle computer codes read and determined no issue with the VSC circuit, then you just need to cancel the warning light.
I've made up the following instructions, on how to clear VSC & TRAC Warning lights:
Zero Point Calibration of Yaw Rate and Deceleration Sensors Using Paper Clips (or jumper wires).
First, locate the 16-pin ODB II connector under the steering wheel (beneath the dash). The pins are numbered sequentially backwards from right to left (from the wide side of the connector looking at it from underneath).
Take two normal-sized paper clips (or suitable jumper wires). If using paper clips, straighten one edge of one of the paper clips. For the other, bend it open to a 90-degree angle (like an elbow).
Insert one paper clip/wire into pin # 14 (Ts), and the other paper clip/wire into pin # 4 (CG) of the OBD II connector - DO NOT allow the paper clips/wires to make contact at this point.
Refer to diagram below:
1. Ensure the shift lever is in "P" range.
2. Turn the ignition switch to "ON" (not start).
3. Momentarily touch the two paper clips/wires together (short) and separate again (open) - Repeat this process 5 times (within 8 seconds of turning ignition on).
Verify that the VSC indicator light is illuminated, indicating the Recorded Zero point is erased.
4. Turn the ignition switch "OFF".
5. Remove both paper clips/jumper wires from the OBD II connector.
6. Turn the ignition switch "ON" (not start) - wait until VSC warning light turns off (approx. 20 seconds), then wait 2 seconds.
7. Turn the ignition switch "OFF".
9. Re-insert paper clips/jumper wires to terminals #4 & #14 of the OBD II connector (as per above diagram).
10. Turn the ignition switch "ON" (not start) - VSC warning light should remain illuminated for 4 seconds, then start flashing at 0.13 second intervals.
12. After VSC warning light flashes for 2 seconds, turn the ignition switch "OFF".
13. Remove paper clips/jumper wires from the OBD II connector.
Drive your vehicle to confirm VSC & TRAC warning lights have been reset and no longer illuminate.
"If this has helped you resolve your issue, please be kind enough to leave a testimonial"
Jun 10, 2011 | 2001 Toyota Sienna
My led and keyboard and mouse light up when I turn on power switch, nothing happens when I push start button. My e-mail address is debandeddy@yahoo.com
first shut down you computer remove the covers of the cpu then locate the memory and remove them wipe them clean with clean cloth and switch the computer on with out the memory and see if you hear any beeps if you hear beeps insert the memory and switch on the computer if still no beeps then remove the processor fan and clean the surface of the processor fan and the processor apply a thin layer heatsink solvent and clip the processor fan tighty to the socket
Sep 14, 2010 | ASUS P4VP- MX VIA P4M266A UATX P4/...
My Sansa Clip wont turn on.
I just had the same problem. Hold the switch to the on position for 15 Seconds. It worked for me.
Aug 24, 2009 | SanDisk Sansa Clip MP3 Player
Sansa clip will not turn on.
hey dude something is lose inside it has no connection to the battery but the actual port that you plug your pc in does ... myn is also like that and iv had it for a year now,,,,
Jul 09, 2009 | SanDisk Sansa Clip MP3 Player
Toshiba laptop m35x-s149 does nothing.
Probably a shorted wires. You can open DVD ROM using paper clip. GOOD LUCK
May 15, 2009 | Toshiba Satellite M35X-S149 Notebook
New Board; Fan turns on; No Screen; Cap, Scroll, Num lights flash
Great!
I've been bitten by that, especially on Dell laptop.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 05, 2009 | Dell Inspiron 1000 Notebook
MY computer cant detect sansa clip n i cant hear any songs...Plz help me as soon as possible
make sure it's plugged up to both the computer and mp3 player first, then if nothing automatically pops up, click on computer and there should be a picture of your mp3 player, which is it, if nothing is showing you may have a faulty plug. =] let me know.
Nov 26, 2008 | SanDisk Sansa Clip MP3 Player
Acer (56.04200.H22) (5604200H22) 200-Watt Power Supply Logo
48 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
