Question about Zanussi ZWF1430W Front Load Washer
Zanussi 1035E Hi I have the above washer and it will not do anything! When you choose a programme it lights up "Fin" (end) Ive emptied the front drain plug and foung a plectrum but nothing eles. Any ideas? Thanx
    Problem Solver:
  • 4 Answers
You have to check the electric door lock first open the door then take out the metal ring posted on the rubber seal then you have two scews on the font where the latch of the lock unscrew it and change the electric lock
Posted on Jun 04, 2008
Zanussi zwf12070wi machine indicates cycle is
flashing red start/pause button, wont spin or drain
Jul 13, 2010 | Zanussi ZWF12070 Front Load Washer
Not spinning and emptying
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 14, 2010 | Zanussi FJD1266W Front Load Washer
Zanussi washing machine, conditioner doesn't empty
heatman101
May 14, 2009 | Zanussi ZWF1430W Front Load Washer
WASHING CYCLE STOPS AFTER A MINUTE
Can you skip through the programme to drain? Press pause button. then press start to move the lights down to the empty cycle. leave to finish.
If you have already tried this, I can explain how to put machine into engineer test mode, which will then give out a fault code to identify problem.
Apr 04, 2009 | Zanussi FJD1266W Front Load Washer
I have a Zanussi WDA1055W washer/dryer. I never
the water should only be filling up to approc 2in above the drum bottom...........look inside when its filling..........if its filling to nearly the bottom of the door you either have a faulty pressure switch or grit/dirt in the internal filter.......as a result the machine will not spin if there is too much weight in the drum
Feb 23, 2009 | Zanussi F1045W Front Load Washer
Zanussi zwf1929w front loader
it could be either the heating element the machine is waiting to heat up before moving on or the brushes on the motor. somtimes the motor is able to spin without a load but struggles full up programmer faulty is a rare fault
Oct 30, 2008 | Zanussi FJS1225W Front Load Washer
Machine filling and then immediately draining
Hi You need to higher your outlet pipe on the back of the machine there is usually a clip to hold the pipe in place 3/4 of the way up the machine so it looks like a u upside down its should stop the machine from emptying straight away
Apr 29, 2008 | Zanussi ZWF1430W Front Load Washer
Wash.machine won't spin
Door lock switch # 131763245 if everything else is working fine this should fix the problem. It shorts out between the motor control board and the door lock from emptying the cycle and spinning. Try running your machine on drain/spin and see if it drains and tosses clothes and then stops with no spin. If that happens then it is your door lock.switch. Easy to replace by yourself and costs $65.00
Mar 13, 2008 | Kenmore Elite 45986 Front Load Washer
Zanussi ZWF1430W Front Load Washer Logo
119 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
