Question about Samsung Digimax S630 Digital Camera
If the light intensity is high, the pictures appears to be almost white and horizontal lines can be seen.. does it something to do with its lenses??? if light is low, it is clearer but still horizontal lines are present.. please answer me if what is wrong with my cam..
  • 37 Answers
Hi,try to go in your menu and setup withe balance to the center
hope that will help you...
regards Allan...
Posted on Sep 03, 2010
  • mely_cmok Apr 18, 2011
    where is that setup for white balance anyways??It's not on menu:s:s
My screen has gone white?
The display being white can be due to failure of the LCD or the CCD which is the optical sensor of the camera. So to confirm check the older picture to be seen on the display. Confirm this by checking the card on your PC. If the images/picture is seen to be of good quality, then the LCD can be faulty, fault on the linking cable or the control board.
However if the older images are seen well then the LCD is working correctly and the fault can be failure of the CCD- charge coupled device in the camera. If you have accidently exposed the camera directly to high intensity light / sunlight, then it is possible that it is damaged. Remove the battery and keep the camera aside to reset and try as a last resort. Get estimate before you decide. It will be good to have it checked at the authorised service as you do not have to run around for spares.
Please click on the link for tips to replace a LCD
http://www.youtube.com/watch?v=aB4x7F5Chow
Dec 14, 2011 | Nikon COOLPIX L20 Digital Camera
If the light intensity is high, the pictures appears to be almost white and horizontal lines can be seen.. does it something to do with its lenses??? if light is low, it is clearer but still horizontal...
The lens cannot itself create the lines. The fact that there are horizontal lines indicates that the sensor and/or its related electronics is faulty. It is best to contact support from the manufacturer's website as this does not seem to be an easy problem to solve by oneself.
Please rate Fixya answers.
Apr 18, 2011 | Cameras
Shots are either light or white outdoors
Probably the shutter flexcable burried in the lensblock is broken,have it replaced or change whole lensblock,labor intensive ,technical skill required .
Reason: lens movements wears out the flex cable and breaks,shutter inoperative ,pictures are white outdoors ,video OK ,horizontal lines showing as blinds.
Parts are available at ebay.Better have it serviced.
Jean
Jan 26, 2011 | Canon PowerShot A460 Digital Camera
How do you adjust headlights on a 1993 chevy C1500
if you look at the light, there is an adjustment screw at the top of the light that controls the up and down motion , clockwise will raise the beam, and a screw on the side that controls the side to side motion. the best way to center your lights would be to park the vehicle 25 feet away from a verticle wall. be sure to be very square to the wall and on level ground. make a tape line vertically on the wall in very close relation to the center of the vehicle, and another tape line vertically in very close relation to the center of each headlight. now place a tape line horizontally in very close relation to the center of the headlights. start with low beam adjustment. adjust the high intensity zone to 2 inches below the horizontal line and 2 inches to the inside of the vertical line directly in front of the headlight. for high beam adjustment, adjust so that the high intensity zone is centered on the center vertical line and just below the horizontal line. hope this helps
Apr 04, 2010 | 1993 Chevrolet C1500
I have an rca model hd52w67 tv and there is a problem with the picture. the picture has a red and green picture that don't allign by about an inch. I think it is in the picture guns but i cant find a...
Do not align the guns! they are located facing up toward the mirror; they are picture tubes! covered with big glass lenses! heavy!
instead look for a red/green/blue adjustment knob on the set's front; the buttons should say: convergence or, crosshatch push the crosshatch button: once you have three vertical lines crossing three horizontal lines; just merge them using the other R/G/B knobs untill you have one white vertical line and, one horizontal line crossing in the center of the screen.
(you may have to find the controls on the remote using "setup")
Feb 11, 2010 | RCA Televison & Video
I have a KF-42E200A Sony Bravia LCD tv. Recently we had to replace the lamp. Since then a horizontal line appeared at the top of the screen and it has grown to about 3 inches now. The picture itself is...
The lenses in the TV are more than likely misaligned due to heat from lamp. The heat can cause the lenses to move and the red shaded horizontal line appears over time because the lenses fall out of alignment.
You just need to have the lenses realigned and the red shading will go away.
Jan 07, 2010 | Sony Televison & Video
Trying to adjust head lamp in a 1995 chevy C1500 just had to buy a new lamp assembly
Oct 20, 2009 | 1994 Chevrolet C1500
Intense white & coloured horizontal line on black background on startup
I wouldn't attempt as the capacitors on a tv store around 25000 volts this is more than enough to kill you and they keep there charge even when the tv is off. Either take it to a repair shop or put that money towards buying a new tv - Do not even attempt to open the tv. (It sounds like maybe a tube has gone or the electromagnet that makes the beam move vertically is gone.
Sep 03, 2008 | Televison & Video
Black screen with sound only no picture.
I have same problem,it appears to be the flyback
xfr.
Apr 18, 2008 | Hitachi 32UDX10S 32" TV
Samsung Digimax S630 Digital Camera Logo
304 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
