Question about ASUS M2N-MX Motherboard
Cmos checksum bad...usb current status detected system shut down 15 sec
Hello im building my first pc and have done it by the book so far. when i turn the power on i get this command and then the computer shuts off
cmos checksum bad
usb device current
status detected system will shut down in 15 seconds.
then it does what it says/ im lost and im in great need of help will be very thanful to anyone who can help.
asus p5ld2 se......
USB DEVICE OVER CURRENT STATUS DETECTED SYSTEM WILL SHUT DOWN IN 15 SECOND
  • 3 more comments
  • Geoff Plumb
    Geoff Plumb May 13, 2008
    My pc,s exactly the same
  • Anonymous Jun 03, 2008
    • USB Device over current status detected system shut down 15 sec problem, and notify you when a new
  • Doctor Ross Oct 30, 2008
    I have the usb over current status message. I have cleared the cmos, checked the jumpers, pulled the mobo and tried to run it on cardboard to see if it was a grounding problem. I'm stuck. This is a new build and my fourth. Any suggestions?
    specifics... asus p5n-d board
    q6600 cpu
    gts8800 gpu
    ocz ddr2 dualchannel 800 ram
  • sassabrassa Dec 29, 2008
    Exactly the same problem:
    cmos checksum bad
    usb device current
    All new components putt together for the first time.
  • manomk2006 Mar 08, 2009
    usb device over current status detected error
  • 58 Answers
Situation Remedies If you have encountered this error and would like to fix your computer, here are some remedies for each situation:
CMOS Battery Not Functioning Properly: If you suspect your CMOS battery is not functioning properly you can easily change it. Before changing your battery, reboot your computer to make sure that the error still exists. If it does, go into your CMOS and write down all of the settings. If all settings are lost, you can usually get them from your computer manufacturer. Now locate the battery and remove it, you might need to consult your computers manual or tech support to remove your battery. Take down the CMOS batteries information such as volt, size, etc. Once you have your new battery, you can replace it and reenter your CMOS settings. If your battery was the cause of the CMOS Checksum Bad Error, you should have remedied the problem.
Your BIOS has Been Updated (either by you or possibly a virus): If your BIOS has been updated recently, your CMOS settings may have become reset. Make sure that the values entered in the BIOS are correct or simply reset them to the default settings. If you believe that a virus updated your BIOS settings, run a virus scan and make sure that the BIOS settings are back to the default.
The Computer Was Shut Down Improperly: Sometimes when running MS Windows, if you shut down your laptop or desktop without first properly shutting down your operating system it will corrupt the CMOS settings causing the CMOS Checksum Bad Error. You can easily avoid this error by making sure that you completely shut down your computer before turning off the power. Usually this entails going into the Start Menu/ Turn Off Computer/ Shut Down. If you received the error, shut down the computer properly, if this is the cause of the error, the error message will not return.
Posted on May 11, 2008
  • Mountaine70 Sep 14, 2010
    I Update the Bios myself because it was the first version with 3 years old, but when the system reboot the message "Cmos checksum bad" appeared, so I downgrade the Bios version 1 time, and again the same message, downgrade twice and the same, then I reset the Bios to the default settings and it worked.
    Thank you very much.
Fixed - there was two jumpers on different places on the motherboard, that selects if USB items can wake the computers sleep mode. One of those jumpers was missing.
Posted on Dec 30, 2008
ITs the motherboard battery!
Posted on Aug 01, 2008
I have problem with it
Posted on Oct 29, 2008
2 Suggested Answers
SOURCE:
SOURCE: cmos checksum bad...usb current status detected system shut down 15 sec
It is in your bios this motherboard has been known to have isues with the bios chip.I am useing this motherboard and have been lucky I did not get this problem you are haveing.You may try flashing to the curent bios 1903 geting the download from the Asus site.
Extract
Then remove file
Rename file to P5LD2.rom
Put renamed file only on three and a half floppy disk
Reboot Holding alt F2 at same time
flash will start
If you do not feel safe doing this then you can get a new bios chip from asus with the 1903
Good Luck
Also make sure you have no air gaps on your heatsink to proc this will cause the pc to heat up and shut down.
Posted on Mar 05, 2008
Camcorder won't turn on
is this camcorder battery dead, is the cell battery dead ,
have connected camcorder to power cable and it is still dead I need to know if it is receiving any power supply or just the power supplied from your pc
Apr 14, 2014 | Toshiba Camileo X400 Camcorder -...
Getting a CMOS checksum bad error when starting my Acer M5640 Desktop with Windows 7 Thanks Daniel
Solutions to CMOS Checksum Bad Error
The CMOS Checksum Bad Error can be fixed easily by following the listed steps carefully.
CMOS Battery may not be functioning properly
If you suspect that your CMOS battery is not functioning properly, you can easily change it. Before changing your battery, reboot your computer to make sure that the error still exists. If it does, go into your CMOS and write down all of the settings. If all the settings are lost, you can usually retrieve them from your computer manufacturer. Now locate the battery and remove it, you might need to consult your computer's manual or technical support to remove your battery (the battery a flat, shiny silver colored and coin-shaped). Take down the CMOS battery's information such as volt, size, etc. Once you have your new battery, you can replace it and reenter your CMOS settings. If your battery was the cause of the CMOS Checksum Bad Error, you should have solved the problem.
Your BIOS may have been updated
If your BIOS have been updated recently, your CMOS settings may have reset. Make sure that the values entered in the BIOS are correct or simply reset them to the default settings. If you believe that a virus has updated your BIOS settings, run a virus scan and make sure that the BIOS settings are back to the default.
The Computer may not have been shut down properly
Sometimes when running MS Windows, if you shut down your computer without first properly shutting down your operating system, it will corrupt the CMOS settings causing the CMOS Checksum Bad Error. You can easily avoid this error by making sure that you completely shut down your computer properly before turning off the main power. Usually this entails going into the Start Menu, clicking on Turn Off Computer/ Shut Down. If improper shutdown was the cause of the error, you may have solved the issue.
akuma_ryu21 rate it pls!!
Jan 21, 2011 | Computers & Internet
I have asus p5gc-mx motherboard when i start my pc it show some mess like,,,,,00 mass storage devices found and configured ,,,,and CMOS checksum BAD ,,,,,,,,, somebody know what is this and help me to fix...
Checksum errors are almost always an indication of RAM problems. Have you replaced the RAM lately? Or perhaps had modules out and not reinstalled properly? Is this a new board?
No mass storage devices looks like there are problems with connections or hardware problems with your hard drive.
Are you setting up a new board or did this just happen out of the blue?
Can you get into the BIOS setup when it begins booting?
Any other information would be helpful.
Wayneard
Dec 31, 2010 | ASUS P5GC-MX/1333 - Motherboard - micro...
On starting my pc error come CMOS check sum bad. usb power overload. system will shutdown in 15 sec. and system turns off after that. i have already change the cmos battery. please give some useful...
Check your system USB connector having any short circuit, you can test it by removing all USB connections. Then again it showing USB over current error it is related to your Motherboard ICH problem, motherboard to be replaced
Sep 25, 2010 | ASUS A8N-VM Motherboard
Booting problem
There are usually three main reasons that a CMOS Checksum Bad Error has occurred. They include:
  • CMOS Battery may not be functioning properly. The battery life may have expired.
  • Your BIOS may have been updated (either by user or possibly a virus)
  • The computer may not have been shut down properly e.g. shutting off the computer's main power without first shutting down the computer (MS Windows requires you to shut down your computer before shutting off the power).
Solutions to CMOS Checksum Bad Error The CMOS Checksum Bad Error can be fixed easily by following the listed steps carefully.
If you suspect that your CMOS battery is not functioning properly, you can easily change it. Before changing your battery, reboot your computer to make sure that the error still exists. If it does, go into your CMOS and write down all of the settings. If all the settings are lost, you can usually retrieve them from your computer manufacturer. Now locate the battery and remove it, you might need to consult your computer’s manual or technical support to remove your battery (the battery a flat, shiny silver colored and coin-shaped). Take down the CMOS battery’s information such as volt, size, etc. Once you have your new battery, you can replace it and reenter your CMOS settings. If your battery was the cause of the CMOS Checksum Bad Error, you should have solved the problem.
Mar 05, 2010 | Microsoft Windows XP Professional With...
Emachine t2885 won't start. the power supply and fan works, but the o/s would not come up. any suggestions? thanks
When your system boots Hold F8. You will find list of commands. Try the last known good config and then restart the system once done.
Feb 19, 2010 | E-Machines T2885 PC Desktop
Hi ihave apple power book g4 i want reboot
login in single user mode as below:
Starting up in single-user or verbose mode
    1. Shut down the computer if it is on.
    2. Press the power button to start the computer.
    3. Immediately press and hold the Command (Apple) key and one of the following:
    • the "s" key for single-user mode. (Command-S)
    • the "v" key for verbose mode. (Command-V)
You have successfully entered single-user or verbose mode when you see white text appear on the screen.
Once you are in the Single user mode type the following:
fsck -fy <then press enter>
If this command returns with an error or reports that is found an error but fixed it then run the command again and repeat until the drive checks good.
Once you are done with the repair or feel satisfied, type 'reboot' and press enter.
Feb 12, 2010 | Apple PowerBook G4 Mac Notebook
Hello there, i have problems whether plugging the AC supply into my acer aspire 6920G laptop. when i plugging the AC, the laptop will suddenly shutdown, then boot up again. but when im using battery, it...
I am sure its totally fault of your OS. Becouse some when ac working well, some where battery. your OS does not recognised your power control properly. Try to use single OS and get batter result. if done thumbs me.
Dec 16, 2009 | Acer Aspire 6920 Notebook PC
ASUS M2N-MX Motherboard Logo
6,151 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
