Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Top freezer works but the bottom refrig is blowing warm air
  • Whirlpool Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 03, 2010
Vegetables in crisper are frozen, as well as liquids in bottom 1/2 of fridge door. The fridge & freezer temp controls won't adjust to our settings. Also, we're getting ice, but no water will dispense.
The freezer cools the refrigerator, so you actually get very cold air passing from the freezer to the refrig. The air from the freezer enters the refrig on the top and falls to the bottom where it is drawn back into the freezer. The temperature of the refrig is regulated by a thermostat and a fan that runs when the thermostat calls for cooling. If the refrig thermostat is faulty and causes the fan to run more than it should, there will be a freezing problem in the refrig at the bottom because cold air falls and warm air rises. If the refrig is thermostat is calling for cooling constantly, this will take more cold air from the freezer than is normal. Your freezer temp might be higher than normal and the refrig will be colder then desired. If the fan from the freezer is running constantly I would suspect a bad refrig thermostat.
May 06, 2015 | Refrigerators
Side by Side GE Refrig/Freezer is blowing hot air out of the bottom - is this normal?
If your refrig is 10 yrs old or les , then yes , this is normal . It pulls air in from the back over the condensor coils then compressor and out thru the front . The refrig should be 3-4 inches from the wall so it can pull fresh air thru . If any closer , the hotter the air will be causing the coils and compressor to be hotter than designed for therefore causing less life for the refrig . The WARM air is good meaning the refrig is cooling properly .
Jul 18, 2010 | GE Refrigerators
Freezer cold fridge warm
sounds like the evaporator in the freezer section is iced up and you need to see if the defrost section is working correctly,then as for the warm refrige side,it sound as if the vent damper door is frozen shut or the cold control in the refrige isn't opening it to let cold air into the refrige from the freezer,if its frozen take a hand held hair dryer and remove the vent grille over it and defrost it and then check to make sure the control opens and closes it as you adjust its control in the refrige
Apr 26, 2010 | Hoover HCA391FFK Bottom Freezer...
Freezer works and fridge on top doesn't
Check behind the back wall for frost build up if the is a defrost problem this is the first sign
Mar 14, 2009 | Kenmore 71279 Bottom Freezer Refrigerator
The fridge is 4 the freezer is 4 the problem is fridge warm
Can you hear a fan motor blowing or feel air blowing in the freezer section? I'm thinking this fan has quit running and is not distributing air to the refrig section. If this fan is running then check that you can feel air blowing out of the vent at the top of the refig section if not check that the damper is open. you can do this by removing the grill on the vent (it just snaps out) as warm as the refrig is this should be wide open.
The fan os the most likely and most commonly seen problem for me. the part number is 12002744 and is approx 40 dollars. this is a fairly easy fix if your mechanicly inclined. if you call a service company you will be looking at 150-250 depending on the company.
If you have any further questions leave me a comment here thanks Peyton
Mar 01, 2009 | Maytag MFD2560HES Bottom Freezer French...
Kenmore Elite Bottom Freezer - only top does not work
i would check to see if you hear a an blowing in the freezer sect when the door is opened, if you cant hear the fan blowing then there is yout issue, not circulating air up to refrig compartment
Nov 11, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer works, fridge doesn't
freezer ok no refrig???? do you here a fan on in the freezer sect when you open the freezer door?? common problem to have a bad evap fan motor and the unit will not blow the air up to the refrig compartment
Oct 27, 2008 | Maytag MBF2256H Bottom Freezer...
Sears Kenmore bottom freezer/refrig #68142model
just called in a sears technician 150 dollar bill that was an easy fix. he says my bottom freezer kenmore fridge with warm fridge problem was due to the pathway being blocked by ice and garbage which is common with these fridges. he took off cover from the fridge bottom and poured boiling water down to the freezer. try that before you replace any parts or call in a tech. next time im getting a top freezer because the blower is on the top not in the middle with the bottom freezers and thus more problem prone.
Jul 20, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore top freezer unit-refrig not cooling past 50degrees
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
Sep 03, 2007 | Kenmore 64802 Top Freezer Refrigerator
Amana ABB2224DES Stainless Steel Bottom Refrigerator is warm however the freezer works fine. How do I solve this problem? I vacuumed the coil and renoved most of the dust accumulation. Is there a way...
check freezer for frost build up and if FAN is blowing, check condenser, make sure its clean, and fan blowing, check vents in refrig. make sure no blockage, controls should be in the middle setting, make sure u didnt turn up freezer control cutting air supply to refrigertor side should be 1/2 feel vent coming from freezer see if you feel any air coming in to refrig.
Sep 02, 2007 | Amana ABB2224DES Stainless Steel Bottom...
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
49 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
