Question about Kitchen Ranges
Power failure when using oven. - Kitchen Ranges
  • 2 more comments
  • Douglas Butler
    Douglas Butler Sep 03, 2010
    Everything works OK loses power when oven is turned on. Must be a electronic problem but what one.
  • Douglas Butler
    The range works in all modes expect when you turn on the oven or broiler it will show a power failure after a few seconds. This is a gas stove. 110 only. Do you know about the electronics or am I wasting my time.
  • Douglas Butler
    This is a GAS Range!!! Did you not get the model # kenmore 790.79372406
  • Douglas Butler
    That makes sense. I will try that when I get back next week. I do not think there is any moisture in the control. I would think the control is behind the back panel.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. The issue seems to be with the electronic range control (ERC) going bad however, before replacing it you can take it apart and try to blow some air with the help of hair dryer so that if there is any moisture it blows it off. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 03, 2010
  • Rylee Smith
    Rylee Smith Sep 03, 2010
    Thanks for the model no#, so you think that Gas Range dont have a control.
  • Rylee Smith
    Sure, Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
    Genius:
  • 1,478 Answers
There may be a broken or burned wire at the back of the range/oven. If you repair any of the wires, use only proper appliance-grade wire and wire connectors. Check to see if power is getting to the range/oven. Does anything turn on, even a light? If not, check for a blown fuse or tripped circuit breaker.
Check the cord that connects the oven to AC outlet to ensure it is not damaged, if it is, replace the cord.
Take care.
  • Jimoh Adeleke Muyideen Sep 03, 2010
    I so much believe in the power cord that connects the oven to the AC outlet or the AC outlet itself, plug the oven to another outlet, if same problem, it is the cord that is defective and will need to be replace.
    The
    broiler element may be burnt. That is why it shows power failure after the broiler is on. The broiler element in an electric oven
    is the black, pencil-thick tube at the top of the oven. When the broiler
    is on, the element glows red. This element has an expected life-span of
    several years. It may last for only one; it may last for many more.
    When the element burns out, you need to replace it.
Won't turn on. Shows no power to it but outlet fine,
Check input power supply by tester if its conform its OK then check the oven control box .try to check any abnormalities there .
Jul 19, 2016 | Bosch 500 HMB5050 Microwave Oven
Oven Failure Code F1
sir what type of oven u r using???
May 26, 2008 | Dacor Preference RSD30 Gas Kitchen Range
Power Failure while oven was in self cleaning mode. When power was restored the control panel is completely dark, no error codes or PF indicator. The oven door is also locked after 24 hours, so the the...
Hello. You have an open rear oven thermostat causing the complete power failure of your unit. The part numbers you need are W10176670 for the upgraded blower and 9759243 for the thermostat. You will have to remove the oven from the wall in order to remove the back covers to access the thermostat and blower. The blower has been upgraded from 950cfm of airflow to 1200cfm. I have performed this service flash--you will definitely need a helper or 2 in order to pull the oven out and work on it. There is a service bulletin on your oven describing this exact situation. When you replace the thermostat and blower, re-mount the oven and then restore power, the oven will function and unlock. The link for the thermostat is here:
Thermal Overload Safety Thermostat
The link for the blower is here:
http://www.appliancepartspros.com/whirlpool-blower-w10176670-ap4369539.html
If you are hesitant about performing the repair yourself, definitely call for service. I hope this helps you!
Nov 06, 2015 | Whirlpool RBS305PRS Stainless Steel Oven
APPEAR THE LETTERS PF IN THECLOCK CONTROL
usually, just reset clock..it stands for power failure..if power goes out. they all do this...
Feb 16, 2011 | Ovens
Hi, i own a kenmore elite speedcook oven model 363.63692301, ever since my wife used the convection speedcook oven and had the heat setting set to the maximum temp of 450 degrees which the oven should...
I have had issues with my Kenmore Elite conv oven too. I have had several service calls and found out that the TCU (thermal cooling unit) sensor was not working. This allows the oven to cool down so it doesnt overheat the sensors in the display. I actually had to have the oven replaced after 4 months of use. I am currently waiting for a technician to review the replacement oven for the same issue. I spent $7k on all new Elite appliances and will never purchase Kenmore appliances again. Good luck
Nov 30, 2010 | Kenmore Microwave Ovens
Whirlpool Microwave error F3H
F3H Humidity sensor failure 1. Unplug microwave oven or disconnect power.
2. Connect a new sensor to the board (at P5).
3. Plug in microwave oven or reconnect power.
4. If no failure code appears when starting sensor function:
 Replace old sensor.
5. If failure code appears when starting sensor function:
 Replace power supply board.
6. Plug in microwave oven or reconnect power.
Aug 04, 2010 | Whirlpool GH5184XPQ Microwave Oven
I have a Kenmore over-the-stove microwave oven that is not heating food. Everything else works. I received a message of PF on the keypad. Is there anything I can do before I have to call a repair...
PF - Power Failure - PF error code indicates a power failure during the cycle.
Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 13, 2010 | Kenmore 62702 Microwave Oven
What does pf on digital display mean? Oven will not work
PF means power failure.
This has caused a power outage to the oven.
This error can be removed by resetting the clock.
Hope this helps.
Thanks for using Fixya.
Dec 07, 2009 | Whirlpool Ovens
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
