Question about Video Game Consoles & Games
My Wii ins't turning on. Iv'e checked every plug, switched sockets in case they were faulty, and switched inputs but still it won't turn on. Do you know the answer?
  • 158 Answers
In all likliehood its the power transformer which plugs into it (the gray box) those are available at most game stores,wal mart etc.. and commonly fail
Posted on Sep 03, 2010
Install wii on toshiba 32L1400u
Plug the yellow phono/RCA from the Wii cable in to the socket marked Y/Video on the TV
Plug the red and white sound leads in the TV's red and white sockets.
Switch on the Wii and the TV. Press the TV remote's input button until the Video input is selected. That's it.
Sep 05, 2014 | Televison & Video
My headlight doesnt work
Hi, Anonymous if your headlight is not working, keeps burning out or is dim the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, that being said the usual suspects are:
1. Faulty ground or power supply wire to headlight bulb socket.
2. Worn, chaffed, or broken wires in the light circuit.
3. Corroded, broken, or loose pins/sockets in wire connectors.
4. Faulty hi/lo beam switch.
5. Faulty ignition switch.
6. Fuse is good but no continuity on both sides.
7. Faulty wiring between battery positive and headlight bulb socket.
8. Weak charging alternator/generator.
9. Faulty voltage regulator/rectifier, overcharging.
For more information about your issue and free downloads that you will need please visit the websites below. Good luck and have nice a day.
Headlight won work Sportbikes net
Why won my headlights turn on
https://absolutelyscooters.net/service-manuals.html
CPI Scooter Parts Racing Planet USA
Tips and Tricks for Motorcyclists
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Feb 26, 2014 | Cpi Motorcycles
Toshiba tv/dvd won't turn on
Check the reset button, wall socket where it plugs in, power cord, and if equipped cabinet interlock.
Bypass the on/off switch with a known good one.
Next check the voltage setting device it could be faulty.
It usually is set for 125v.
good luck!!!
Feb 24, 2013 | Toshiba 20a43 20" TV
Won't turn on
First check the power cable and ensure that it is correctly connected. check the fuse of the plug or socket just in case it is blown.
pay extra attention and never touch contacts whilst power is switched on.
Regards
May 12, 2012 | Cameras
My wii will not turn on. It is plugged in obviosly. Lol!!
there could be a number of things that could be going wrong here, so I can suggest a couple of things to do just to clarify what the problem *isn't*.
Firstly, I would check the wii in a different plug socket. It might be that the socket is faulty.
If it isn't the socket, and it still isn't working in a different one, and absolutely nothing is happening when you try and turn it on, there is a possibility that it the fuse in the plug has blown. That is a simple and cheap fix. However, it could also be the actual console, in which case it would need to be taken to a repair shop, or if it''s in warranty, you should be able to contact either Nintendo or the shop you bought it from and get it either repaired or replaced for free. If it isn't in warranty however, you would have to pay for any repairs.
var fctb_tool=null; function FCTB_Init_f45d35b3738e494c9934f0a1e9dbf1a0(t) { fctb_tool=t; start(fctb_tool); } FCTB_Init_f45d35b3738e494c9934f0a1e9dbf1a0(document['FCTB_Init_3169c511049c499bae1c5e9e76816fef']); delete document['FCTB_Init_3169c511049c499bae1c5e9e76816fef']
Aug 11, 2011 | Nintendo Wii Console
Code error 32022 what is it
Error Occurred. Press the Eject button and remove the disc. Turn the power off and follow the instructions in the console manual.
First turn the Wii console power OFF, and remove the AC adapter's AC plug from the power socket. Next, check whether the disc is dirty or scratched. If it is dirty, gently wipe with a soft cloth from the center to the outside. Wait about 5 minutes. Then plug the AC adapter's AC plug back into the power socket and turn the console power on. If the same message still appears, the Wii console may be damaged. Turn the Wii console off immediately.
Click here to download Ninento wii repair guide
Jan 05, 2011 | Nintendo Wii Console
Keep getting error message,remove disc and turn power off
Remove the AC adapter's AC plug from the plug, and visit support.nintendo.com for additional troubleshooting or call 1-800-255-3700.
Jan 04, 2011 | Nintendo Wii Console
It wont work
take it to a game store to get it buffed out
Aug 07, 2009 | Nintendo Mario Kart (Wii) for Wii
Friends Nintendo Wii went off - screen turned black after previously working ok. Took our Wii and plugged it into their tv and wiring. Our Wii now wont work. When Wii is turned on screen changes from no...
  1. This happens if the wires are hooked up wrong(Video and Audio reversed)
  2. The tv is on the wrong channel
  3. The tv signal settings have been changed
  4. The signal settings on the wii have been changed
First check that all wires and connectors on the wii and tv are properly and snugly connected
and check the tv channel.
Then check the settings in both.
Please rate this fixya solution
Feb 22, 2009 | Video Game Consoles & Games
I cannot make my wii to work on my Sony tv
Some newer hdtvs use the green rca in the back for both a/v and component. Usually it has green with a touch of yellow on rca input itself. Then plug in audio to red and white.
Oct 06, 2017 | Sony (ICSSP20) TV Input
Video Game Consoles & Games Logo
15 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
