How do I install memory on a Dell Demension 8400 computer?
  • 734 Answers
HI there,
Below is the link to your online complete service manual which will intruct you, with pictures, step by step, how to do anything you need to work on your computer, including the relatively easy task of installing additional memory.
http://support.dell.com/support/edocs/systems/dim8400/SM/index.htm
Best Regards
Posted on Sep 03, 2010
I have no display when computer is turned on and
First use the following steps:
Turn off the system and disconnect power cables
Press and hold the power button for 10-15 seconds.
Reconnect power cables and try to turn it on.
If it remains same, the next step will be to:
Open the case and re-seat memory modules
If you have more than one modules installed, try to test the system with a single module at a time.
Mar 13, 2010 | Dell Dimension 8400 PC Desktop
No Power
i hope you completely unplug all power cables from the outlet before inserting the new memory. if not, your mainboard may be damaged already.
Nov 09, 2009 | Dell DimensionTM 8400 PC Desktop
No sound from speakers using sound blaster live 24-bit
go to dellsupport.com and redownload the audio drivers for your system. Hope that helps.
May 25, 2009 | Dell Dimension 8400 PC Desktop
Plug in Tv and use monitor as well?
enable the second device by rt clicking on the desktop, and go to properties then display, click on the second device and click on enable. that should allow you to run them both, as long as your card allows it, which it should if it has 2 outputs
May 01, 2009 | HP RADEON X300 SE, (128 MB) PCI Express...
Dell blue screen tests got data bus system
I presume you ran the 32bit Dell diagnostics. The memory test failure indicates that the memory module has failed. If you have more than one memory installed, you can try removing one at a time and run only the memory test (from Custom test option), this way you can isolate the faulty memory. If you have a warranty for the computer, Dell would replace the memory for you (Check warranty status from http://support.dell.com/support/topics/global.aspx/support/my_systems_info/manuals?~ck=ln&c=us&l=en&lnki=0&s=gen )
As for your other problem “it just does nothing when i type r for recovery”, you would need to go to the bios, under the “Drives” tree, under “SATA operation” you would need to change option one to two and save and exit. This is applicable on for the Dim 8400. But you would not need to do this if the prvious steps resolve you issue
Hope this helps. Please rate your feedback!
Thanks,
VJ
Mar 24, 2009 | Dell Dimension 8400 PC Desktop
Dell Demension 4600 motherboard memory
From the Dell specifications page for Dimension 4600:
Memory
Architecture
Dual Channel DDR SDRAM
Memory connectors
Four
Memory capacities
128-, 256-, 512-MB or 1-GB
Minimum memory
128-MB DDR SDRAM
NOTE: Between 32 and 64 MB of system memory may be allocated to support graphics, depending on system memory size and other factors.
Maximum memory
4 GB
Memory type
PC2700 (333-MHz) or PC3200 (400-MHz) DDR SDRAM
(non-ECC)
Mar 09, 2009 | Dell (2336V) Motherboard
Help
how to put music on it
Feb 12, 2008 | Apple iPod nano
Woes with Dell
If the power light is steady amber, a device might be malfunctioning or incorrectly installed.
Disconect fan , see if it starts.
Jan 13, 2008 | Dell Dimension 8400 PC Desktop
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
