Three circles of radius 3.5 cm are placed in such a way that each circle touch as the other two the area of the portion enclosed by the circle is????? A)1.967cm2 B)1.975cm2 C)19.67cm2 D)21.21cm2
    Brigadier General:
  • 10,406 Answers
There is no single, correct, answer to this question.
For example, if the three circles overlap 99%,
then the combined area will only be about 1% larger
than the area of a single circle.
If the circles only slightly overlap, then the combined area will be much larger than the area of one circle.
Posted on Sep 03, 2010
A circle with a radius of 3 kilometers
What is the question?
A circle with a radius of 3 kilometers has a perimeter of about 18.85 kilometers and an area of about 28.27 square kilometers.
Sep 02, 2014 | Office Equipment & Supplies
Area of circle
(pi)R squared (Fixya won't let me use the sign for Pi)
Area of a circle=pi*radius^2 or pi times radius times radius
example: suppose the radius of a circle is 10 inches, then the Area of the circle would be pi times 10 times 10 or 100*pi
pi represents the circumference (distance around) of a circle / diameter and for any circle is constantly the same number which is approximately 3.14
so in my example 100*pi=100*3.14 or 314 square inches
Jul 03, 2014 | Computers & Internet
Math
Since the area of a whole circle is pi times the radius squared, the area of half the circle is one half times pi times the radius squared.
Apr 30, 2014 | Computers & Internet
A circle has a radius of 4.5 inches. If the radius of the circle is doubled, does the area of the circle double as well
Try it. Area is equal to pi (3.1417) multiplied by the square of the radius.
At 4.5 in. A=63.585 sq in
At 9 in. A=254.34 sq in
What do you think?
Mar 13, 2014 | Computers & Internet
If you know about area formulas of class 8 and 9,please solve my question?there is a circle.in the between of the circle,there is a rectangle of dimension 4cm and 3cm.if the rectangle will cut out what...
The diameter of the circle is the diagonal of the rectangle use Pythagoras this rectangle is a made from two 3,4,5 triangles, so the diameter is 5cm, the radius will be 2.5cm don't forget the BODMAS ordering rule (Brackets of Division Multiplication Addition and Subtraction) Also rounding to 2 decimal places. This solution is based on all four corners of the rectangle touching the circumference of the circle.
Area of a circle is P (22/7) i x Radius (squared ^2) ====> 22/7 x 2.5cm ^ 2 ====> 22/7 x 6.25cm
TOTAL AREA of CIRCLE = 19.64 cm^2
Area of the rectangle is length x width ====> 4 cm x 3 cm
TOTAL AREA of RECTANGLE = 12 cm ^2
The remaining portion is the circle area minus the rectangle 19.64-12 = 7.64 cm^2
SIMPLES brought to you by SpideRaY @ http://www.windowstipsclub.com
Jan 31, 2011 | Computers & Internet
There is an equilateral triangle. in it there are three coins of equal radius is placed. find the radius of the coin.
how big is the triangle? if the coins are a mile in diameter doesnt mean you cant have an equilateral triangle with legs of 32 miles long.
or are you asking for the equation?
i will send you on the path to the equation.
if you draw a circle on a piece of paper then draw a triangle around it where is the center? if the triangle were a perfect equilateral then the circle would be a perfect circle touching the sides of the triangle.
its important to know where the center is because the center of the circle to the edge of the circle is the radius.
so the center of a triangle is the center of the circle. therfeore the radius of the circle will equal hieght/2...
thinking that way you can say that if there were three coins then the center of the triangle cant be occupied by a coin but is very close to an edge. where is the center of the coin?
Jun 10, 2010 | Mathsoft StudyWorks! Middle School Deluxe...
How to calculate surface area using a casio fx -83 ES
You sort out the formula for the surface you have to calculate then substitute the numerical values for the variables (sides, bases, heights), the constants if any (pi, etc.) an press = to get the result
Ex Square with side= 2m
Surface area=side^2
Area : 2 [X^2][=] result is 4 m^2
Circle of radius r=3 cm
Area: Pi* 3[^2]=28.27 cm^2
May 12, 2010 | Casio FX-115ES Scientific Calculator
What is the area of a semi circle the diameter is 2.500mm the radious is .425mm the circumfrence is 3000mm
You cannot have a semicircle that has a diameter of 2.500 mm and a radius of .425mm and a circumference of 3000mm
Circumference is equal to pi times the diameter. pi is = 3.14
The radius of a circle is always 1/2 the diameter
Area of a circle is pi time the radius squared
Loringh
Oct 30, 2008 | The Learning Company Achieve! Math &...
Computers & Internet Logo
130 people viewed this question
David Payne
David Payne
