Question about Brother MFC 240C All-In-One InkJet Printer
Then your point is i should buy a new set of color cartrages like the 3 colors before the printing should take place then how can i set my brothers printer mfc-240c into black cartrages only no need to buy the 3 color cartages beacause the ink is very expensive!
    Novelist:
    Champion:
  • 214 Answers
First - read the manual as regards printing. I notice that you can print in Black and White but I cannot find anything to say that you only need the Black ink to do this (therefore I think that I am right in saying that you need the colour cartridges).
Question - Has it worked with only the black ink before now?
As a final solution - Contact Brother direct and check out their FAQ's and/or send them an email asking if you can run the printer with Black ink only installed (I suspect the answer will be no).
If the answer to the above questions comes back as "Yes you can use Black only" (they may tell you how to set this up in which case ignore my next comments), then please supply some more information as regards what happened immediately before it stopped printing. This will help to drill down to the problem.
Posted on May 11, 2008
Does printing black text only on a Brother Inkjet All-in-One (MFC-J625DW) use the color cartridges?
Your right. Simple answer. Take the coloured cartraiges out (you may need to set your printer to mono crome though. not sure.? Save a bit more money and recycle your cartrages you get paid for them. then you can buy refill cartrages and save even more. Some say do not use them they cause problems, but i have from day one and still have no problems 29 years later!!! and i am a high user on a A1 PRINTER!!! (draughtsman if your wondering)
Jan 25, 2012 | Office Equipment & Supplies
My printer will not print black even tried 2 brand new cartrages. i also tried the cleaning process on the printer and it did not help. all other colors print perfect.
the black tube or nozzles are clogged up. The printhead probably needs to be replaced.
possible reasons for this
generic ink
not using the printer for a long time
printing past the warning indicator of low ink and having air get sucked in the tubes.
Probably cheaper to buy a new unit.
Aug 27, 2010 | Brother MFC295CNAll-In-One InkJet Printer
Hp laserjet 2600n printer creates 1/2" wide band that you can almost see the print...like it is not getting toner in black color.
This often happens when cartrage has run past changing point. remove cartrages starting at top and CK for ink. Run cleaning page until clear
Jul 04, 2010 | HP Color LaserJet 2600n Printer
Empty Ink Cartrage message when cartrage still has a lot of ink.
I'm going to provide you a solution worth many dollars now you can use your left over half filled cartidges and in future also use the cartridges to the extreme.
1. Go to menu and select manual override for toner cartridges and then only replace toner when the print quality starts to suffer. This can save you thousands of dollars over the life of this fine printer.
2. download and read this
http://74.125.153.132/search?q=cache:9mwf_bY_x-AJ:www.refill4.com/refillinstructons/pdf_downloads/Full-RefillInstructions.pdf+brother+mfc+5840+override+cartridge+empty&cd=6&hl=en&ct=clnk&gl=in
Jul 26, 2009 | Brother MFC-5840CN All-In-One InkJet...
Black not printing on a Brother MFC-290C
in the printer display try head cleaning option, there must be something blocking the cartridge. hope this helps
Jul 17, 2009 | Brother Multi-Function Center MFC-240C...
I don't use the color printing yet the color cartridges are empty
It's all a scam. I have the same problem and I called Brother and they told me that the machine uses color ink to clean itself. It costs more to replace these color cartridges then to buy a new one, which is what I'm going to do. Buy a black and white from a different company. It's all a scam to get you to spend money on their color ink that you don't use.
Mar 25, 2009 | Brother IntelliFax 1860C Plain Paper...
Color ink cartridge says empty i just filled it
When you put in a "new" cartrage the printer sens an electrical charge to the cartrage to set it up properly. So I would treat this as a new cartrage, rather than a refilled one. Go to the printer menu and re install the ink cartrage in question, it should recognise it and start the function as a new one, good luck
Mar 24, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Every other word either red or blue
Please follow these steps and then try to print :
For winows system :
1. Click Start, Settings, Printers (Windows XP: Control Panel, Printers and Faxes).
2. Right click on the Lexmark printer icon and select Properties.
3. Select the Printer Settings tab (Windows XP: click on the Printing Preferences button) and click on the Change button.
4. Close the I Want To menu and select Print Color images in Black and White.
5. Click OK to confirm the new settings.
For mac system
# Load plain paper into the printer. Open the Page Setup screen and select the required settings.
# Then open the Print screen and customize the image printing settings as follows:
1.
2. From the software application, select File, Print. From the Printer pop-up menu, choose your printer model and then continue.
3. From the pop-up menu in the upper left corner, choose Color Options.
4. From the Document Color pop-up menu, choose Black Only.
5. Click Print.
Mar 20, 2009 | Canon BubbleJet i560 InkJet Printer
Hp color laserjet 2600n ''black print down form its orignal place''
an allignment need to perform on printer with proper placement.
Nov 27, 2008 | HP Color LaserJet 2600n Printer
Text Not Printing
You are out of black and white ink.
Graphics are printed with the color cartrage
text is printed with the black and white.
Apr 30, 2008 | Brother MFC-8440 All-In-One Laser Printer
Brother MFC 240C All-In-One InkJet Printer Logo
56 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
