Question about Amana NDG5800 Gas Dryer
Gas dryer starts out ok. When it needs more temp to keep drying, the glow plug turns on and waits for the lp gas to show up and nothing happens. My quess, 1. solenoid valve malfunctions 2. no flame detection. What do you think?
  • Amana Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 03, 2010
How I cant start my gas dryer
Gas Dryer no heat: or shuts down soon after heating CHECK:
Thermal Fuse
If the air flow in the dryer is restricted, the temperature in the heating chamber can get hot enough to blow the thermal fuse. If the fuse blows, it cuts power to the coils that control the gas valve. The fuse is usually mounted to the exhaust duct just inside the back panel. You can check its continuity with an ohmmeter. If, after disconnecting the fuse, you get any reading other than 0 when you touch the leads of the meter to its terminals, it has blown. There's no way to restore it -- you'll have to install a replacement.
Igniter and Gas Valve Coils
TEST with a multi meter: The igniter is an electric conductor that works like the element in an electric heater, glowing hot enough to ignite gas when you turn on the dryer. This conductor can burn out, and when it does, it may glow, but it won't get hot enough to ignite the gas. At times it may give a reading of continuity yet fail mechanically and not get hot enough to ignite flame though it gets hot and glows and even may show Ohms or continuity ( close circuit) ?
Occasionally, the Gas safety valve and the electric coils that control the gas valve are defective -- they can wear out when the dryer gets old. When this happens, the igniter glows, but gas never enters the heating chamber or does not stay consistant.
Performing a continuity test on either part will help you determine whether or not you need to replace it. But the coils should also be tested for amount of resistance as well as Ohms. As they may be showing ohms yet not putting out enough resistance to keep proper gas pressure flowing. Most coils should show at least 1300 ohms ( GIVE OR TAKE 150 OHMS). Anything significantly less Thus u get an ignition but then it soon goes back out. The flame does not stay lit.
Air Flow and Heat
The motor that drives the tumbler also drives a fan that circulates air through the heating chamber and the tumbler and expels it through the vent. If the air can't circulate, perhaps because of lint blockage, the heating chamber overheats, which prompts the cycling thermostat to turn off the gas. The thermostat resets when the chamber cools, but the chamber heats up quickly and the thermostat again shuts off the gas. The result is that the temperature in the tumbler doesn't stay hot, and your clothes take longer to dry, if they get dry at all.
Warning
There's a big difference between a dryer that doesn't heat up at all and one that just doesn't get hot enough to dry your clothes. In the first instance, the problem is usually a defective part, and things should be back to normal after you replace it. In the second instance, the problem is caused by restricted air flow, and you need to clear the lint filter and vents and take steps to prevent lint build-up. If you don't, you'll use more energy for drying than you need and the dryer may continue to malfunction. Worse, you may have a dryer fire.
Feb 02, 2015 | Kenmore Dryers
Kenmore Elite HE4 Gas Dryer Shuts off prematurely in the Auto Dry cycle and the Timed dry cycle
Thermal Fuse
Air Flow and Heat
Warning
Jul 19, 2014 | Kenmore Dryers
The heater ignites well, but if it gets a clear blue flame (and it burns very quiet), the thermocouple will glow red and the heater stays on, but when it gets a opaque blue flame (it makes a sound when...
I would start by replacing the thermocouple. It is suppose to keep the gas valve open when in operation. If the mercury in the thermocouple dries out it won't keep the gas valve open and thus the flame goes out. If that does not work then you have a gas valve problem.
May 05, 2017 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
2001 VW Diesel Golf TDI. Car started no problem. Drove to gas station. Stopped for gas. glow plug light wouldn't come on, engine wouldn't start, engine turning but not starting. Waited a few minutes then...
the glow plugs only come on when the engine is below a certain temp,so if you drove it to the gas station,chances are it didnt need them.BUT,it could have been just at the temp that the glow plugs werent needed and the engine was still coldish.happens very rarely.wet air is colder than hot air so that would also have an effect.lastly, this engine is known to foul up the injectors with carbon so use redexe/wynns or similar at 1can to 1/2 tank fuel,you WILL feel the difference.......
Nov 17, 2010 | 2001 Volkswagen Golf
Glow igniter shuts down when dryer calls for gas
The very noisy part is a little bit odd...
Usually the igniter glows, the flame sensor detects the glow and sends power to the valve coils, which open the gas valve. There are some differences in that setup depending on the brand, but that is basically it.
It could be that the igniter isn't glowing hot enough (doubtful) or that the flame sensor (the rectangle thing on the side of the burner tube) isn't working (also unlikely, but still possible) or that the gas coils aren't working. Gas coils are the most common problem to go wrong on gas dryers, but when they go, they usually work at first, and then start to fail.
Do you have a volt/ohm meter?
Nov 14, 2009 | Whirlpool LGR4634J Gas Dryer
Gas dryer does not heat GAS DRYER DOES NOT DRY CLOTHES WITH HEAT
check for igniter to be glowing, remove the plastic tab on the front panel an start the dryer
if it glows igniter is ok takes about 30 seconds to glow.if it glows is ok.
then check the thermal fuse for conitnuity an if it checks ok
then you have bad coils. replace the coils an ur done
May 26, 2009 | Frigidaire GSGQ642A Gas Dryer
Maytag Neptune MDG 5500 AWQ heats sporatically
your dryer has a safety feature that it will not run or heat when the door is opened. It is so no gas fumes are exhauseted into your home. Once the safety is engaged, It will not allow the dryer to restart for a short while. It should clear itself after only a few minutes. Hope this helps, good luck.
Apr 18, 2009 | Maytag Neptune MDG5500AW Gas Dryer
My Maytag Atlantis MDG6400AWW will not heat up. The drum spins but the clothes don't dry!
my dryer timer is not turning off and it does not get hot,I check glow coil.its working but it does not fire up.I smell gas some time
Apr 16, 2009 | Maytag Atlantis MDG6400AW Gas Dryer
Changing a gas ge dryer to a propane----convertion package we25x10014 directions show a picture of the control panel with 4 plug ins at the bottom and changing out the last one on the right for the new...
Converting your Natural Gas Dryer to Lp is taking it from a lower BTU gas "Natural" to a higher BTU "LP" value. The orfice on a LP gas valve is smaller because you dont need as much gas to make the same amount of heat. make sure you change the orifice. The little plug goes in the regulator of the gas valve, changing the valve from a low gas pressure Natural to a Higher Pressure LP.
If the kit doesnt look right, did you get the correct one?
Maybe you should call you LP provider they can do the conversion for you.
Jul 10, 2008 | Dryers
SPEED QUEEN MODEL AGS68AWF-- I'VE CLEANED ALL VENTS. NOT GETTING HEAT.DRYER CYCLES BUT GAS DOES NOT TURN ON. I'VE OPENED BOTTOM ACCESS PANEL AND NOTE THAT THE IGNITER GLOWS AND CYCLES BUT GAS DOES NOT...
If the glow bar is cycling off and on the glow bar works and the black box on the side of the vent are working, Either there is no gas to the dryer, doubltful but something to check or, You need a gas valve.
I would check for gas first, do you have other gas appliances? and all are functioning properly? Check the gas line and make sure someone hasnt accidently turned off the gas. If it is none of these you need a gas valve.
Go to repairclinic.com or partselect.com with your Sp Q model number, or the part number off the gas valve, it could be a five digit 58**** or 51***** number. Get you best price. Im guessing 80 to 100 Amercian
When replacing the gas valve, unplug the dryer first, turn off the gas, remove the front panel, two screws lower front panel, you will need a crescent wrench for gas line of side and a 5/16 nut driver remove wires. Now remove the orfice from the old gas valve and make sure you install it on the new valve. Is this a Natural Gas or LP Gas dryer?, If it is LP make sure you make the conversion to LP. Ask if you have more questions on this.
install gas valve, tighten gas line turn gas on check for leaks! with a bubble solution, start dryer and make sure dryer works properly.
best of luck
T
Amana NDG5800 Gas Dryer Logo
75 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
