I also have a frozen button on my lcd monitor - I have been shutting down the tower and then turning off all power - is that the best way to deal with this problem?
  • 27,725 Answers
Try cleaning your computer of dust using a fine air blower from a compressor making sure that there is no moisture in the air line dust causes static to build up in a computer
hope this helps good luck
Posted on Sep 03, 2010
Monitor immediately goes to sleep. Tower shuts down from unplugging it.
have you tryed starting up in safe mode to see if you can get into your windows?
Apr 09, 2015 | HP Pavilion Media Center TV m8400f...
Desktop: Gateway LX6810-01 PC will not power on. When I hit the Power button on the tower, a long continuous BEEP comes on and nothing appears on the monitor. After the BEEP, the On light (on tower)...
Thank you for using FixYa
I would try shutting down the computer in the normal way, and turning off the monitor.
Boot up and turn the monitor back on.
If it still doesn't work, then I would check the cables and power plugs and wall plugs.
Check the mouse and keyboard cable and any other cables plugged into the computer.
The next step requires a seperate monitor or laptop.
Try unplugging the monitor and pluging in another monitor. Most laptops have a common
VGA adaptor jack or even an Svideo jack.
If the other monitor does not work, Then take to a qualified technician for repair.
It could be your power supply in the computer or video controller.
I hope this was useful and please comment if this was helpful to you.
Mar 24, 2011 | Computers & Internet
HP L1720 monitor on screen control frozen in center of screen
mcdevito75 here, Try to simply shut the monitor off at the monitor itself, Or with your computer shut down, disconnect and reconnect the monitor to the computer.
Jul 10, 2010 | LG 22" FLATRON LCD Monitor
My monitor will not go back on. There is a green light blinking
Hi ,
In order to isolate whether its the monitor or the compurter tower you can do a self test to check if the monitor is fine .Turn the computer off and then disconnect the cable for the monitor from the back panel of the computer tower.It will be a blue connector with screws on it .Undo the screws and then disconnect it then turn the computer on ,if the monitor is fine you should get a message that would say check input signal or you will have some kind of message on the screen that tells you that the data cable to the monitor is not connected.If u dont get any message that simply means that the monitor has gone bad and needs to be replaced...
hope this helps you .....all the best
May 12, 2010 | Acer AL1916W 19" LCD Monitor
Monitor blinking but will not come on
most of the time the blinking is a form of error message from the monitor depending on how many blinks in between each pause lets service technicians know which breaker fuse or transistor needs to be replaced
I would suggest taking it into a computer repair store and have them attempt to fix it however alot of the times its cheaper to just buy a new one
Hope this helps
Robb
Apr 26, 2010 | Dell E193FP 19" LCD Monitor
AOC F22 lcd 22" monitor locked menu button and power button are the same plus when u shut down it doesnt want to come right on
Hold down the power button to turn it off, then hit the power button and immediately hold down the left side of the ring. Wait for the OK to disappear.
Took me a couple tries, but it works.
Apr 06, 2010 | AOC LM742 17" LCD Monitor
My hp w1907 monitor has suddenly stopped working!!as soon as i turn on the tower it just displays"monitor is going to sleep"PLEASE HELP!!!
I love this one. I've actually done this many times before and have been successful.
1. Turn the computer off and unplug the power cord from the back of the tower.
2. Press and hold the power button for about 3 seconds while the computer is unplugged (this drains the remaining power from the capacitors on the motherboard).
3. Plug the computer back in and turn it on.
If that does not work, follow steps 1 and 2 again, but this time:
3. Open the computer while it is unplugged and unplug the power supply from the motherboard then hold down the power button again for 3 seconds. (You may also want to take the RAM out and put in back in)
4. Plug everything back in and turn the computer on.
Mar 13, 2010 | HP w1907 LCD Monitor
My hp2009m monitor goes into sleep mode
Monitors are programmed to go to sleep when there is no input. If you shut it down on the other "tower" also it will do the same. You need to physically hit the power button on the monitor to actually shut it off.
Feb 15, 2010 | HP Computers & Internet
Just hooked up my pc yesterday worked fine. I shut down by going to start & turn off computor. Came back later to start back up. Monitor tells me in power safe mode. Tower doesn't seem to be starting...
You can try removing external devices like (ex. usb printer, external Hard drive) and try to start the computer again. And see if there are lights on the tower
Hope this helps
Jan 03, 2010 | Dell E173FP 17" LCD Monitor
LG L1751S Flatron Screen
My sister's monitor wont turn on at all. She was shutting her system down due to a storm rolling in, and it said windows shutting down installing updates, while she is shutting it down. She turned it on today and the little light came on then it went off and hasn't been on since then. The Tower works fine but the monitor isnt turning on at all. What should she do? She has had the monitor at least 2 years no more then 2 1/2 years! And it is a LG Flatron 20". HELP
Apr 25, 2008 | LG Flatron L1751S-SN 17" Flat Panel LCD...
Computers & Internet Logo
David Payne
David Payne
