Question about Kenmore Dishwashers
It is leaving a white film on everything. - Kenmore Dishwashers
    President:
  • 1,197 Answers
If your dishes or glassware appear filmy or spotted following a complete wash cycle, adjusting the amount or type of detergent you?re using and adjusting your hot water heater?s water temperature may solve the problem. But before you do either of these, put a rinse additive (such as Jet-Dry) in the rinse dispenser to improve the sheeting action of the water.
Next, you?ll have to determine whether the film is removable or permanently etched. To do this, soak a glass in undiluted white vinegar for about 15 minutes. Or, wash the glass with warm water and concentrated dishwasher detergent or a high-phosphate detergent (such as Glass Magic).
If the film comes off, it is probably caused by hard water minerals, improper amounts of detergent, or unsuitable water temperature.
Permanent etching is often caused by a combination of soft water and excessive heat or detergent. If glassware is permanently etched, there isn?t anything you can do to make it clear again. But you can avoid future etching by taking these steps:
1) Be sure hot water entering the dishwasher is no hotter than 140 degrees F. Don?t use extra-hot settings such as ?Power Scrub,? and use the ?Energy Saver? dry cycle.
2) Adjust the detergent amount.
3) Don?t pre-rinse your dishes before loading them in the dishwasher. Food particles on the dishes actually help the detergent and drying agents clean better.
A common cause of poor washing results is improper loading?dishes that block or impede the spray arm(s) or prevent the soap dispenser from opening. On the other hand, if your dishwasher has chronic problems with good washing, the problem may not be your dishwasher. A good first step is vary the amount of dishwasher detergent you're using and try switching brands.
Other possibilities: Your home?s water pressure may be too low, your water may be too hard, or the water temperature may not be hot enough.
In order for your dishwasher to fill to the appropriate level, water pressure should be from 20?120 pounds per square inch. If you suspect that your water pressure may be low, turn off all faucets or other users of water (such as washing machines and sprinklers) and then put a half-gallon jug under the kitchen faucet. Turn on the hot water full-blast. If the jug doesn?t fill within 14 seconds, your water pressure may be too low for proper dishwasher operation. Call your city water utility to discuss your options, or avoid drawing water elsewhere in the house or yard during dishwasher cycles.
The right amount of detergent to use depends on how large your load of dishes is and how hard your water is. Hardness is measured in grains of minerals?the more grains per gallon you have, the more detergent you?ll need. If your water has 12 grains or more of hardness, fill both dishwasher soap cups completely with detergent. If that doesn?t work, consider installing a water softener. (For more information, see the article Water Softener Systems.
To check water temperature, hold a meat thermometer under the hot water faucet for two minutes; if it doesn?t register a minimum of 140 degrees F., turn up the temperature dial on your hot water heater. (However, if you have a newer dishwasher that heats the water internally, it isn?t necessary to turn up your hot water heater.)
If your dishwasher has worked fine in the past but suddenly your dishes aren?t clean after the dishwasher completes all cycles, listen to the spray arm(s) spinning inside during the wash cycle. If spinning poorly, wait for the machine to cool down, remove the spray arm(s) by unscrewing the hubcap(s), lifting the arm(s) off, and then cleaning out the spray holes in the spray arm(s) with a stiff piece of wire.
Posted on Sep 03, 2010
  • SAM JAYANTH CHANDRASEKAR
    If you do find my solutions helpful .. please dont forget to rate the Solution. they are our encouragement to Serve you folks better.
Kenmore Elite dishwasher won't clean and leaves white film
CHANCES ARE YOUR WATER TEMP IS TOO COOL and the 2nd
PROBLEM IS VERY HARD WATER THAT IS CAUSING THE WHITE RESIDUE. RAISE THE TEMP ON HOUSEHOLD WATER TO 140 F AND ADD SOME SALT TO THE WASH CYCLE. LASTLY USE A LIQUID DETERGENT LIKE LIQUID CASCADE.
Oct 13, 2012 | Kenmore Dishwashers
It is 6 mos old and it leaves the dishes dirty and with a white film on everything. I used jet dry, cascade with no results. what would cause this? it has done this since day one. thanks
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Feb 23, 2011 | LG LDS4821BB 24 in Builtin Dishwasher
My dishwasher just started foaming really bad. And leaving lots of white residue. It has never done this before. I run finish detergent and just ran 2 bottles of cleaner through it and right away foam and...
heatman101
Jan 16, 2011 | Danby DDW497W 22 in. Countertop Dishwasher
My dishwasher is leaving a residue on everything and is turning anything metal a darker color. What would cause this?
heatman101
Jan 13, 2011 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Machine is leaving residue on everything after full wash cycle>
heatman101
\\000\
Dec 28, 2010 | Bosch SHU9915UC Dishwasher
My DD603SS dishwasher (top drawer) leaves a residue to powder and does not rinse well. I have tried to clean everything, but I think something is broken in water pump
heatman101
Dec 03, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
My dishwasher is leaving a white soap residue on everything..dishes and all inside the dishwasher itself. I can't even scrub all of the white scum off of the door of the dishwasher.
heatman101
Nov 04, 2010 | Whirlpool GU2700XTSS / GU2700XTSY Built-in...
My dishwasher is leaving everything in the dishwasher full of a residue. That is very hard to get clean even when washed by hand.
heatman101
Aug 18, 2010 | Frigidaire 24 in. FDB750RCC Stainless...
My dishwasher is all of a sudden leaving white film
Called limescale deposits, does it have a salt reservoir? if so fill up, if not run a bottle of white distilled vinegar in with a short program
Feb 24, 2010 | GE PDW9980NSS Built-in Dishwasher
The dishwasher is leaving residue on the lower rack dishes...everything except plates.
heatman101
Dec 29, 2009 | Amana 24 in. ADB1500AWS Stainless Steel...
Dishwashers Logo
150 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
