Question about Hotpoint Dishwashers
What causes white powdery residue on glassware in the dishwasher. I think it is lime deposits. Can I use lime remover in dishwasher to eliminate the buildup?
    President:
  • 1,197 Answers
If your dishes or glassware appear with a white film or a white powdery residue or spotted following a complete wash cycle, adjusting the amount or type of detergent you?re using and adjusting your hot water heater?s water temperature may solve the problem. But before you do either of these, put a rinse additive (such as Jet-Dry) in the rinse dispenser to improve the sheeting action of the water.
Next, you?ll have to determine whether the film is removable or permanently etched. To do this, soak a glass in undiluted white vinegar for about 15 minutes. Or, wash the glass with warm water and concentrated dishwasher detergent or a high-phosphate detergent (such as Glass Magic).
If the film comes off, it is probably caused by hard water minerals, improper amounts of detergent, or unsuitable water temperature.
Permanent etching is often caused by a combination of soft water and excessive heat or detergent. If glassware is permanently etched, there isn?t anything you can do to make it clear again. But you can avoid future etching by taking these steps:
1) Be sure hot water entering the dishwasher is no hotter than 140 degrees F. Don?t use extra-hot settings such as ?Power Scrub,? and use the ?Energy Saver? dry cycle.
2) Adjust the detergent amount.
3) Don?t pre-rinse your dishes before loading them in the dishwasher. Food particles on the dishes actually help the detergent and drying agents clean better.
A common cause of poor washing results is improper loading?dishes that block or impede the spray arm(s) or prevent the soap dispenser from opening. On the other hand, if your dishwasher has chronic problems with good washing, the problem may not be your dishwasher. A good first step is vary the amount of dishwasher detergent you're using and try switching brands.
Other possibilities: Your home?s water pressure may be too low, your water may be too hard, or the water temperature may not be hot enough.
In order for your dishwasher to fill to the appropriate level, water pressure should be from 20?120 pounds per square inch. If you suspect that your water pressure may be low, turn off all faucets or other users of water (such as washing machines and sprinklers) and then put a half-gallon jug under the kitchen faucet. Turn on the hot water full-blast. If the jug doesn?t fill within 14 seconds, your water pressure may be too low for proper dishwasher operation. Call your city water utility to discuss your options, or avoid drawing water elsewhere in the house or yard during dishwasher cycles.
The right amount of detergent to use depends on how large your load of dishes is and how hard your water is. Hardness is measured in grains of minerals?the more grains per gallon you have, the more detergent you?ll need. If your water has 12 grains or more of hardness, fill both dishwasher soap cups completely with detergent. If that doesn?t work, consider installing a water softener. (For more information, see the article Water Softener Systems.
To check water temperature, hold a meat thermometer under the hot water faucet for two minutes; if it doesn?t register a minimum of 140 degrees F., turn up the temperature dial on your hot water heater. (However, if you have a newer dishwasher that heats the water internally, it isn?t necessary to turn up your hot water heater.)
If your dishwasher has worked fine in the past but suddenly your dishes aren?t clean after the dishwasher completes all cycles, listen to the spray arm(s) spinning inside during the wash cycle. If spinning poorly, wait for the machine to cool down, remove the spray arm(s) by unscrewing the hubcap(s), lifting the arm(s) off, and then cleaning out the spray holes in the spray arm(s) with a stiff piece of wire.
Posted on Sep 03, 2010
  • SAM JAYANTH CHANDRASEKAR
    If you do find my solutions helpful .. please dont forget to rate the Solution. they are our encouragement to Serve you folks better.
White residue in tub
The white Residue may be mineral deposits, such as lime and /or calcium deposits. There are products on the market such as 'Lime Away' or ' CLR' that remove mineral deposits. They can be found in any supermarket in the cleaning/laundry isle
May 05, 2014 | Maytag Washing Machines
GE Profile dishwasher doesn't clean!
If you have "powdery film" it sounds like hard water deposits to me. Many states have outlawed phosphate as an ingredient in dishwasher detergents, so the detergents don't work as well anymore if you live in a region with hard water. New product designed for this very problem. "Greenest" product ever...it's all-natural and comes shipped to you in a re-claimed water bottle!
www.CloudyDishes.com
CitriClean of Florida CitriClean of Florida
Jul 21, 2012 | Dishwashers
How did I get the film off my glassware? My glassware has a thick film that is very unappealing. I have to hand wash them. I use cascade detergent.
If you are not using a water softener use a rinse aid such as Jet Dry. This will help to eliminate scum on glassware. Use the solid form of Jet Dry. If you use a water softener you need to decrease the amount of detergent.
You can determine the cause of cloudy glassware by soaking a glass in vinegar for 5 minutes. If the cloudiness is removed it is a hard water deposit and more detergent is likely needed. If the cloudiness is not removed it is a permanent condition known as etching. In this situation, use less detergent and stop pre-washing. In actuality, dishwashing detergent needs a bit of soil to work on, otherwise it will tend to foam up.
Mar 12, 2011 | Whirlpool Dishwashers
We have a Miele dishwasher that is less than one year old. We have lots of problems with cloudy/etched glassware with every dishwasher load. We are using Cascade soap. In our previous dishwasher (not...
There are several causes in dishwashers that make dishes come out with film on them or something of the sort. Here they are.
1 Water temperature should be 140 degrees. Your dishwasher should have a "sani" cycle that heats up the water into that range.
2 Most dishwashers were never engineered for liquid soap. So if you are using it, go to powder soap.
3 A rinse agent is definitely a big plus
4 In some parts of America, such as Florida, lime deposits build up in the machine and accumulate onto the dishes and glasses. It's a white film. It also accumulates in the parts of the machine and clogs them. If this is the case. Run white vinegar in the machine.
Empty the machine.
Turn it on.
While the machine is filling with water, (not at the very very beginning as it will drain out existing water when it is started) put a quart of vinegar in and run it. If it has lime deposits it will greatly reduce them.
5 The spray arms may be jammed with pieces of food or other debris. make sure the holes in the arms are not obstructed.
That should do it.
Best, Mark
Dec 31, 2010 | Miele G892SC SS Dishwasher
Have a Maytag MDB4000AWW dishwasher that now leaves white residue on glassware. I think that the water is not getting hot enough. Does this model increase the water temperature, if yes how do you test that...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Nov 08, 2010 | Maytag 24 in. MDB4000 Built-in Dishwasher
After the dishwasher has finished there is a white powdery residue on the dishes. What can be causing this?
heatman101
Sep 23, 2010 | Maytag 24 in. MD5600 Jetclean II Built-in...
Whte residue left on glassware and dishes
use a dishwashing cleaning agent in the machine. or some thing the has a grease cutting agent.run this on an empty cycle.
there are times residue grease and oils can accumulate down in the sump area where the water sits and can cause film on the dishes.
this could also be some lime or scale build up for that you can use some C.L.R or any kind of lime and scale remover to clean your machine.
make sure tht that this is done on an empty dishwasher
May 19, 2010 | KitchenAid 24 in. KUDS02FRSS Stainless...
How do you remove cloudy film from glassware
Hi- try a product called calcium/lime/rust, or CLR. Let glasses soak in sink with warm water and CLR.Then handwash/dry.-- Try air dry option on dishwasher.- heat 'bakes' on mineral deposits from water.Let me know if this helps- ED
Mar 01, 2010 | Dishwashers
Dishwashers Logo
1,372 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
