Question about Microsoft Windows XP Professional for PC
My window is xp. my antivirus is telling about error in my pc. so what i do.
  • Alun Cox Sep 03, 2010
    Which antivirus are you using and what is the exact error it is telling you?
I think a had two antiviruses, and now it tells me that theres an error in the system so what could i do to fix it myself
uninstall one of your antivirus, if you install 2 antivirus one of the antivirus will detect the other antivirus as virus and make system error
if you was uninstall one of the antivirus and this problem can fix
reinstall your operating system(windows) of your pc desktop
Mar 22, 2011 | IBM NetVista PC Desktop
Antivirus is not getting installed in my laptop. i jst hv changed my operating system.
If you have xp installed in your laptop it will accept any antivirus but if your os is vista or windows 7 the antivirus should be compatible cause vista and 7 havetwo bit modes 86 and 64 so check if the antivirus is is supported with 64 or 86 bit supported
Dec 08, 2010 | Lenovo G550 PC Notebook
Comwindows xp instalation error code 7
I have a feeling it is your registries, or an antivirus preventing the installation. Please follow this link and follow the prompts:
http://www.windowsreference.com/windows-xp-sp3/windows-xp-sp3-install-fails-with-error-code-0x80070005/
Hope this helps! and please do not forget to rate!, Thanks:)
Oct 12, 2010 | Computers & Internet
After installing McAfee on my computer, it seems to lag. It is very annoying...starting up and shutting down can take a minute! WEb browsing began to lag too? Is the antivirus to be blamed? My computer is...
Change settings from Constant Protection to Constant Surveillance-
Prevent McAfee from eating up system resources-
Disable Unnecessary Mcafee Scans -
Do you think after installing the Mcafee Antiviurs your system is slow then I will tell you some points to short out your problems.
To know more visit at (https://antivirusdaddy.com/after-installing-mcafee-computer-slow/)
Sep 11, 2010 | Microsoft Windows XP Home Edition
I have been getting a lot of error messages. My pc has been shutting down and when it starts back it says ''Windows has recovered from a serious error''
Hello
This is most probably a virus. Best help i can suggest is to get a antivirus and update it before scanning your computer.
If you are wondering which antivirus to use, i suggest bit defender.
Really hope this can help. Please rate this.
Best regards
Sep 28, 2009 | Microsoft Windows XP Professional for PC
Error code 2352
http://service1.symantec.com/SUPPORT/nav.nsf/pfdocs/2003020714354306?Open&docid=2003020714354306&nsf=nav.nsf&view=pfdocs
To run the Microsoft Windows Installer if Norton AntiVirus was installed from the CD
  1. Insert the Norton AntiVirus CD into the CD-ROM drive.
  2. Do one of the following:
    • If the installation program appears, then click Browse the CD
    • If the installation program does not appear, then double-click the My Computer icon on the Windows desktop, and then double-click the CD-ROM drive icon.
  3. Double-click the MSI folder.
  4. Do one of the following:
    • In Windows 98/Me, double-click the WIN9x folder.
    • In Windows 2000/XP, double-click the WINNT folder.
  5. Do one of the following:
    • In Windows 98/Me, double-click the Instmsi.exe file.
    • In Windows 2000/XP, double-click Instmsiw.exe if you have Windows 2000/XP.
  6. In the next dialog box, click Yes.
  7. After the rollback has finished, then reinstall Norton AntiVirus.
    Follow the instruction in Reinstalling your Symantec program after a failed installation or after you see error messages to start the computer without any programs running on startup and then reinstall your Norton program.
If these steps do not fix the problem, then go on to the next section.
To run the Microsoft Windows Installer if Norton AntiVirus was installed from a downloaded version
  1. On the Windows taskbar, click Start > Find (or Search) > Files or Folders.
  2. Ensure that "Look in" is set to the drive where you downloaded Norton AntiVirus, and that "Include subfolders" is checked.
  3. In the "Named" or "Search for..." box, do one of the following:
    • In Windows 98/Me, type the following:
      instmsi.exe
    • In Windows 2000/XP, type the following:
      instmsiw.exe
  4. Click Find Now or Search Now.
    You might see many files with this name. Look for the file with this name that is located in either the Symantec_Norton_AntiVirus_2003 or the your Windows temporary file location depending on your version of Norton AntiVirus.
  5. In the Search Results window, do one of the following, depending on your version of Windows:
    • In Windows 98/Me, double-click Instmsi.exe.
    • In Windows 2000/XP, double-click Instmsiw.exe.
    This will undo the changes that were made to your system during the first failed installation.
  7. After the process finishes, then reinstall Norton AntiVirus.
Apr 22, 2009 | Microsoft Windows Vista Home Premium...
Error message
Hi there
It has something to do with your antivirus i think, If you used the System Restore function of your computer, it is very likely to have installed an obsolete antivirus program. Almost all computers now come with an antivirus program some sort installed, and the Restore disks (or built-in System Restore) will reinstall it automatically.
Open the Windows Control Panel, check your list of installed programs, and see which antivirus program you have. Uninstall all but one of the antivirus program's.
Good luck and thanks for using Fixya!!
Feb 13, 2009 | Microsoft Windows XP Professional With...
Im trying to uninstall a program the antivirus system avast
The one time I tried to remove avast i recieved the same issue what i had to do was to reinstall and the unistall and make sure you have it disabled when you try to unistall
Feb 11, 2009 | Acer Aspire X1200 Desktop PC - Athlon X2...
Cannot reply or send e-mails
Reconnect to server or restart pc OR investigate stuck email on outbox or try to disable firewalls or antivirus as well
Jul 17, 2008 | Microsoft Windows XP Home Edition
My windows search is not working
Doug Knox has a possible solution under XP Tips, look for Fix Windows XP Search (error) and try the vbs fix
http://www.dougknox.com/
Jan 02, 2008 | Compaq Presario 5000 PC Desktop
Microsoft Windows XP Professional for PC Logo
13 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
