Question about Xerox Phaser 6110 Laser Printer
I have a Xerox Phaser 6180 MFP, and it keeps saying paper jam and there is no jam, what can I do?
    Novelist:
  • 217 Answers
Check the fuser for paper stuck in it.
Check that the 'paper out' sensor arm (in the fuser) is not broken. If it IS broken, you'll need a new fuser.
Posted on Nov 25, 2015
4 Suggested Answers
  • 669 Answers
SOURCE: Xerox Phaser 6180 keeps saying load papertray with
Remove the paper tray and check the guides. Make sure they are lined up on the 8.5 X 11 marks. If it is lined up, try going into the menu of the printer and reset back to defaults.
Posted on Jul 21, 2011
  • 18 Answers
When you adjust the length guides there are 3 little white switch actuators that eith do or do not actuate three little white switches inside the machine which tell the machine the position of the length guide.
For 11"paper only the bottom one should be sticking out to actuate the bottom switch inside the machine.
Make sure they are intact and that no torn off piece of paper is holding a switch actuate.
If you rmove the tray with a flashlight you can see the three switches inside the machine on the right about 2/3rds of the way back.
They should move freely but they do not go click when you press on them
I don't see anything that monitors the width of the paper in the tray..
If all that works, time to call service.
Posted on Aug 20, 2012
  • 217 Answers
There can be another case of this message.
If the paper isn't being 'lifted' due to a fault, or just wear, in the paper tray.
Pull out the paper tray (as if you were loading it, push the paper tray back in. Now open the front door of the printer and look inside at the bottom of the printer. Has the paper lifted, so that it is in contact with the pickup/feed rollers.
If it hasn't, a replacement paper tray will probably sort it out.
Posted on Sep 24, 2015
My Xerox phaser 6180 keeps saying there is a jam at exit. Open door A. I have taken it apart & cleaned/cleared everything I can. Any suggestions?
This could be some paper still stuck in the fuser, so check that.
The usual cause of this, is the 'paper out' sensor arm (in the fuser) being broken.
I'm fairly sure that this is NOT available from Xerox as a spare part, so the quickest, easiest solution is to replace the fuser.
Jul 21, 2015 | Xerox Office Equipment & Supplies
Connect 6180 MFP scanner to Toshiba laptop
Press the document to be scanned on the Platen glass. Press the Scan button, an Utility will appear. Select required size and resolution. Upon scanning document, save it in compatible format and attach it to email.
Jan 08, 2014 | Xerox Phaser 6180 MFP/N Letter-Size Color...
Jul 21, 2011 | Xerox Phaser 6180N Laser Printer
ERROR 093-951
http://www.refillbros.com/en/manuals/p1643-xerox-phaser-6280-service-manual?page=199
see this page for detail and how to repair
i hope this helpfull, if you think this helpfull please rate very helpfull
thanks for using fixya
Jan 23, 2011 | Xerox Phaser 6180N Laser Printer
I'm getting Jam at Reg Roll on my Phaser 6180, and I think there may be a bit of paper in the paper path, but i can't see it. The machine says Open Door A, which I've done a few times, but it isn't...
Had exactly the same problem... today actually.
Found the solution with another model's manual - I removed the paper from the top, but hadn't realised there was a jam in the paper tray. It was only when pulling it out completely that I found it as below...
Jam at Registration Roller
1. Remove Tray 2 completely.
2. Clear the jammed paper from the printer's
intake slot.
3. Re-insert Tray 2.
4. Open front door A.
5. Remove jammed paper if present.
6. Close front door A
Nov 23, 2010 | Xerox Phaser 6180N Laser Printer
I have a Xerox Phaser 6180MFP and when I print #10 standard envelopes and #9 renturn envelopes the envelopes come out with badly pressed wrinkles on the end of the envelope that comes out last. I have...
I am looking for a diagram on how to print envelopes with my phaser 6180 mfp - when I put the envelopes in, it keeps telling me that I need to put paper in. where can I find such diagram?
May 21, 2010 | Xerox Phaser 6180N Laser Printer
We have a paper jam on our Xerox 6180. It jams on every page. When I pull the paper out there doesn't seem to be a jam, probably a bum sensor. Strangely it happened when we replaced a cartridge.
Please Call this number for this solution, details is given below.
Technical Support, Manuals and Documentation - 1890 925 050
Note - Access drivers, downloads, manuals, documentation and the online support knowledge base. Please have your serial number handy.
Thanks for using Fixya.
Anand
Mar 30, 2010 | Xerox Phaser 6180N Laser Printer
XEROX PHASER 6180 SAYS PAPER JAM, I CLEARED PAPER JAM, PUT IN NEW CARTRIDGE, AND IT STILL SAYS PAPER JAM
Mar 16, 2010 | Xerox Phaser 6180N Laser Printer
Xerox 6180 MFP N error 016-782 Windows 7 x64
did you get a solution to this problem. i have the exact same situation.
Feb 16, 2010 | Xerox Phaser 6180N Laser Printer
Paper jam
I had the same problem kept getting an error something like Jam at Exit Door Open Door A. When I looked at the top of the where paper normally comes from and flipped it open I found a super crinkled piece of paper, which once removed cleared the jam.
May 03, 2008 | Xerox Phaser 6180N Laser Printer
Xerox Phaser  6110 Laser Printer Logo
680 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
