Question about Dometic RM2852 Refrigerator
CHANGED LOWER CONTROL BOX BUT WILL NOT WORK HEATER IS ON ALL THE TIME
    President:
  • 1,796 Answers
Hi!!
Check the climate control heater switch, it may be defective. (Stucked in the "ON" position.)
CLIMATE CONTROL HEATER
The climate control is a switch operated DC electric
heater. Its primary function is to warm the frame of the
refrigerator during high temperature/high humidity
conditions. This prevents the formation of condensation
on the metal frame.
To check the switch, disconnect the wires and do a
continuity check. In the OFF position, there should be
no continuity. In the ON position, there should be a
continuity reading.
To check the heater itself, do an ohms resistance
reading on the heater wire by using a properly calibrated
ohm meter. The proper ohms reading is 34 ohms
± 10%. The approximate amp draw is less than .5 (1/2)
amp.
NOTE: The climate control will draw DC power continuously.
It should be turned off when charging source is
not available.
Also check the ELECTRODE
First, do a visual check for cracks or breaks on the
ceramic insulator. Verify the mounting bracket is attached
properly to the electrode. If either of the above is found, replace the electrode. The spark gap must be set at three sixteenths (3/16") of an inch and tip of electrode above the slots in the burner. If igniter (see Sec. 5.5A or B) and high voltage cable
(see Sec. 5.6A or B) are good and there is no spark at
the tip of the electrode, replace the electrode.
Posted on Sep 03, 2010
1991 dodge dakota heater vacuum air flow shutters son't move
Taking your heating box apart may be a really big job.
It would be good to check the vacuum supply at the heater box, and/or at the controls.
Lack of sufficient vacuum can cause the heater to not work.
The low vacuum could be due to a vacuum leak somewhere before it gets to the controls or the heater box.
Then, the heater box or flaps could be stuck or warped, causing malfunction.
It is all repairable, but can cost you a lot of time and effort fixing this.
God bless your efforts.
Dec 22, 2015 | 1991 Dodge Dakota
Spinning right and in going circles
Inside the lower body is a small rectangular box with a red disk on top. This is a gear box that control the left, right, and straight running time for the pool cleaner. A small rock or a leaf can jam these gears and it will no longer change direction. Very easy to fix if this is the only problem. Worst case, buy a new gear box and replace the one that is in there.
Jul 01, 2013 | Hayward Navigator Pool Cleaner
I have a 1990 lumina apv. Lately When I have the heater going I cannot turn the heat down. I lower the "thermostat" to cooler but it remains hot. I can lower the blower speed but not get it to...
You need to check the blend door on the heater box to see if it is working by hand.The door is behind the glove box near top of heater box.Make sure it is connected to its control lever
Dec 09, 2010 | 1990 Chevrolet Lumina APV
Energy smart hot water heater not giving ample amount of hot water both elements ohm at 12.5
For images and product information
For manual
You checked ohms, did you check for 240V across lower element when lower element is turned on?
Energy smart electric water heater
has a control box on top of unit. Water heater does not have typical thermostats that can be tested and replaced. Temperature sensors located above each element send information to control box through small black and red wires. Temperature sensor sells for about $40, but there is no test listed that shows how to determine when sensors fail.
Potential problems:
-Temperature sensor is not reading correct temp
-Control box not processing correct temperature information
-Selector on control box set to 2, 3 or 4
-Thermostat temp on control box set lower than 120 degrees F
-Sediment build-up starting to surround lower element so water doesn't circulate (see if drain valve runs full-open
Oct 08, 2010 | Water Heaters
Replacing heater fan motor in a Toyota Previa
Removal & Installation It may be necessary to remove the upper radiator shroud to perform this procedure.
  1. Open and support the hood.
  2. Disconnect the negative battery cable and wait at least 90 seconds to proceed working on the vehicle.
  3. Disconnect the power steering and coolant reservoirs.
Disconnect the coolant reservoir
4. Disconnect the coolant reservoir and power steering brackets from the side of the heating unit box.
Remove the coolant reservoir bracket from the side of the heater unit
aa7a886.jpg Separate the power steering reservoir bracket from the side of the unit also
5. Remove the two bolts that attach the upper and lower portion of the heater box. 6. Disconnect the control cable on the side of the heater unit box.
Disconnect the control cable on the drivers side of the unit
7. Remove the eight nuts retaining the unit.
Remove the nuts (8) from around the heater unit
There are 4 nuts on each side of the unit
8. Disconnect the heater control valve bracket from the heater box.
9. Separate the top of the control box from the bottom.
Separate the upper case from the lower
Dec 02, 2009 | 1993 Toyota Previa
Change a heater core
  1. Disconnect battery ground cable.
  2. Remove glove box attaching screws, then the glove box.
  3. Remove lower sound insulator attaching screws and nuts, then the lower sound insulator.
Heater And A/C Programmer And Actuators
  1. Remove programmer as follows:
  1. Remove programmer shield attaching screws, then the programmer shield.
  2. Disconnect threaded rod from programmer.
  3. Disconnect programmer electrical and vacuum connector, then remove programmer.
  1. Disconnect body control module electrical connector, then remove module attaching screws and module.
  2. Remove relay panel from module assembly, then the module assembly heater core cover.
  3. Disconnect heater hoses from heater core.
  4. Remove two heater core attaching screws, then the heater core.
  5. Reverse procedure to install.
Oct 29, 2009 | 1995 Cadillac DeVille
AC & Heater Fan on fast spped only
Most of the time this is a bad "blower motor resistor". It is easy to replace. You will find your behind the glove box in the ac/heater (evaporator) housing. Below is a pic of the resistor as it is seen from behind the glove box. 1. resistor assembly. 2. harness 3. fasteners (2). 4. lower edge of glove box. (open).
Jun 11, 2009 | 2002 Chrysler Town & Country
No hot water, control board light stays green
It may be bad thermostat terminals of the water heater, or, alternatively, the very top heating element is in need of replacement. See this handy diagnostic article for more info:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Home_Improvement_Zone_Heating_Systems_Water_Heaters_Cold_Water_Still_Released_Despite_Water_Heater.htm
Hope this helps.
Brad
May 11, 2009 | Water Heaters
2003 Camry A/C and Heater fan only works on High
The heater fan resistor has failed. This is the device that controls the voltage to the fan motor, on the 3 lower speds, The resistor is bypassed when HIGH is selected. It is located under the dash, passenger side, on the box between the heater fan blower housing and the main heater box at the center. Held in by 2 phillips screws. Easy to change.Hope this helps, and Thanks for choosing FixYa. Please feel free to comment back if you have any other questions.
Nov 11, 2008 | 2003 Toyota Camry
Dometic RM2852 Refrigerator Logo
53 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
