Question about Dishwashers
I also have a GE Potscrubber 1200 but mine is the portable model. It's not draining and it's full of H2O. I've looked around to see if something is blocking it from draining and there's nothing in the way. How do I get all of the H2O out? I'm going on vacation in about 9 hours and I have 2 small kids. HELP!
  • Dishwashers Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Posted on Sep 03, 2010
GE Potscrubber 900 just runs and runs, dial just sits there
Hello Debbe,
Does the dishwasher fill with water, or is full and fails to drain?
Can you provide additional detail so that we may accurately troubleshoot? Also include the complete model number. It should be etched or stamped on a plate inside the door, or elsewhere on the washer.
Thank you!
Jan 30, 2018 | GE Dishwashers
I have a GE 1200 Potscrubber portable dishwasher it was running good until it started to drain then water started coming out the bottom is there a way to fix this? Please help me.
You can take the unit and lay it down. There will be some water leakage. You can then see the hoses and connections. Sounds like the drain hose is either cracked or loose.
Feb 08, 2014 | Dishwashers
When the water drains at the end of the cycle, water drains from the bottoom of the dishwasher, around what looks like an actuator arm? not exactly what the model # is all i know is it is a GE potscrubber...
Hi, I have seen this a lot when I did maintenance work for apartment communities.The part to fix this depending on modle was $85-$125 six years ago, I would just replace it.
Mar 05, 2011 | GE Dishwashers
Looking for dishwasher manual for Model Number GSC700X01AD. GE Potscrubber 700
is this the manual your looking for http://www.managemylife.com/mmh/owner_manuals/4241/GE-Dishwasher-L0801045?brand_name_search=GSC700X01AD+GE+Potscrubber+700+ if you have any further questions or feel that this is not the right manual message me back and please remember to rank how this opinion has helped when our chat has fully concluded it allows me to help others in similar situations in the future Thanks Rick
Feb 13, 2011 | Dishwashers
GE Potscrubber 800 Leaks
See if your parts store can mic the oring and match it to one
May 01, 2017 | Whirlpool GU2400XTP Built-in Dishwasher
My washer will not start. I press the start/pause button and it just beeps twice and does not lock door or start wash. ge adora model wcvh6260
clean the drain filter located behind the front lower panell, its prob. holding excess h2o and wont let the water fill cycle activate. this happened to mine.
Aug 11, 2009 | GE Energy Star WCVH6260F Front Load Washer
I have a GE Potscrubber dishwasher that only hums, won't run
I have a portable that had the same problem. I called a repairman and he turned a fan blade on the motor. Mine is located on the right side about 12" in. It gets hung up when it is run often enough. If your problem is the same is mine all you have to do is turn the blade and it works like a charm. Hope this helps.
Feb 18, 2009 | GE 24 in. GSD2000Z Built-in Dishwasher
Ge potscrubber dishwasher will not drain properly
Had the same problem with my dishwasher. Took it appart thinking that something was plugging the drain but there wasn't anything. Turns out the cylinoid that has the hook coming out of it to control the flap for the ejection of the water is broken. When looking at your pump, you should see a small flapper valve on the exterior of the pump hooked up to a small cylinoid that when accivated flips a flap in the pump to eject the water out of it instead of letting it circulate in the unit. This is an easy part to replace, but for me, hard to find since my potscrubber is so old. Hopefully your units are newer and you can find this part at your local appliance shop.
Oct 23, 2008 | Dishwashers
GE POTSCRUBBER 1200 DISHWASHER
I have a Ge Potscrubber 1200. Fairly new I guess as I bought it with the house that I purchased 1 1/2 years ago. Sometimes it drains and sometimes it does not. Today there was two inches of water! About to remove the bottom panel. Sounds like the drain valve it blocked but not sure. Any thoughts?
Apr 14, 2008 | Dishwashers
Dishwashers Logo
298 people viewed this question
Top Dishwashers Experts
