Hello Sir, What exactly is "Registry Booster".....? When i was surfing the net, i was made to download the 'registry booster.exe' to check my system.....what does it check actually...? and when i did that it showed about 1021 files need to be repaired....i am using AVG free ware anti virus and that doesn't show any such message when it scans my System. hope i was clear in mentioning about my problem. Thank you.
Simply adding or removing software and
hardware and changing your preferences and general settings (e.g.,
creating a shortcut to a document or renaming a folder) your Windows
registry will grow in size and complexity. Even this regular use will
cause your Windows registry to become fragmented and full of errors.
Here are 5 key benefits that you will derive from using Registry
Booster regularly.
Shocking but True
When researching for this article, I was shocked to learn the following:
Statistics show that about 94% of computers have corrupt and
possibly harmful files. And, on average, almost each PC will have about
150+ errors on them due to corrupt or missing registry entries.
Coming to think of it, however, it is only obvious. I am not
one who leaves his computer in peace and I often surf the web
downloading stuff just to try it out and see whether it fits my needs
be it some weird gizmo or an application that I would need to work or
play. (Andrew, our system administrator looks daggers at me as soon as
I walk in his office with the statment "Eh, Andy, my PC's playing
up...".
Well, to cut a long story short, I found 425 errors in my
registry and that is only after a year of use. WOW! I started reading
up on Windows Registry and was thoroughly convinced.
Clean your System and Boost Performance
Repair your PC and Keep it Tuned
Enhance System Stability and Efficiency
It is highly probable that even though your computer system is new or
you are not encountering any visible serious problems, your computer
already has some problems in the registry. The more frequent symptoms
of registry problems include:
Frequent error messages,
Slow start-ups,
Sluggishness and declining performance,
System stalls and failing integrity
Severe degradation in operating speed,
Unstable and frequent application errors and crashes, and,
Registry Booster is the solution to clean and
optimize your system, free it from registry errors and fragmented
entries. Through Advanced Error Detection Technology, Registry Booster
automatically identifies missing, corrupt, or invalid items in your
Windows registry and dramatically enhances performance and general
stability. With Registry Booster, . One mouse click and
Registry Booster does the rest. And, using Registry Booster regularly
keeps your PC free from errors and from obsolete, unused or unwanted
files. AVG anti virus detects virsus,it will not check for registry errors .If you want to know more about what is registry and how to make changes in your system just click on the link below http://www.iwebtool.com/what_is_registry.html --------------------------------------------------------------------------------------------------- If this answers your question please rate this as fixed. If you need more help just add a comment and I'll be glad to help you further... Thanks
My C: is used for XP OS and apps . It is 20Gb in size. When I use Acronis 8.0 to create a drive...
(More)
My C: is used for XP OS and apps . It is 20Gb in size. When I use Acronis 8.0 to create a drive image from a notebook drive, can I create the image onto EXTERNAL USB DRIVE? How much disk space should I roughly need? Not sure about how much compression Arcronis can do to 10Gb data on my c:? Any idea? Since I don't have additional drive in notebook, will this way of dumping an image onto external hard drive the best way to go for backup and recovery in case my hard drive dies?
i have windows vista & i seem to have a problem with my cd dvd driver. my computer says i...
(More)
I HAVE WINDOWS VISTA & I SEEM TO HAVE A PROBLEM WITH MY CD DVD DRIVER. MY COMPUTER SAYS I HAVE ARCSOFT FILE VERSION 1.0.0.2
Memory Frame model-MF-810 software doesn't work on 2-year-old HP Pavilion desk top. Has software...
(More)
Memory Frame model-MF-810 software doesn't work on 2-year-old HP Pavilion desk top. Has software been updated?
