Question about Dell Dimension 5150 (DIM515MIN) PC Desktop
Computer freezes on the dell spash screen, progress bar does not complete, have removed and reseated the memory and the hard drive, and various connections, a friend plugged the hard drive into another pc and appeared ok, any idears ?
  • Dell Master
  • 629 Answers
Could be related to the motherboard. try entering BIOS by pressing F2 when the system restarts. If it works, try to reset the BIOS defaults and see if that helps. If same thing happens, try to reseat the CMOS battery, or find a jumper reset on the motherboard. If nothing works, you may need to get your system serviced and it may need a new motherboard
Posted on Sep 03, 2010
Dell DXC051 desktop will not boot
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove the memory modules from their slots. Take the opportunity to clean the slots on the motherboards and the memory module connectors. Use compressed air to blow dust away and clean contacts with a soft cloth. Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components. Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r Allow the pins to dry. They will air dry in a matter of minutes. If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer. Check the memory module and memory slot contacts. They are either copper tin or gold. The colour will tell you which they are. Mixing tin and gold can result in corrosion that prevents proper contact. Look for any sign of physical damage to the memory module, memory slots or the motherboard. Reseat the memory modules. You should hear an audible click when they are in place. Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard. The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible. Could be a problem with the Hard Drive or the Hard drives PCB http://www.onepcbsolution.com/ There is a connection problem such as a bad cable for internal hard drives
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide this will be the first to fail Make sure all leads that are attached to your drives dvd\cd and floppy (If Applicable) have secure connections and are not faulty. or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
Hope this helps.
Dec 16, 2012 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Reseated hard drive, computer wont re-boot, asking for disc?
Check The BIOS to see if the hard disk is detected. If not then -
Check if the harddrive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a workingcomputer's USB port. If this computer cannot see itas an USB mass storage device and you cannot open the various folders and fileson this drive, then this confirms the hard drive is faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Jul 10, 2012 | Computers & Internet
Dell vostro 1500 mouse disappears ansd computer freezes
Sub out the ram one at a time and power on, take second piece out and replace the first one and try again, remove the hard drive and reseat it back in place. If no change do a complete recovery of the operational system using your installation disc.
Mar 24, 2012 | Dell Vostro 1500 Notebook
Won't turn on
You may have hard drive issues or corrupted window files, remove hardware and reseat it back in position, sometimes this will correct the problem, next sub out the memory one at a time, causes a lot of strange symptoms. If none of these works, use the recovery disc "if you made one" The final option is a computer store to resolve the issues.
Mar 05, 2012 | Dell Inspiron 1545 Notebook
Dell Vostro 1500 Laptop: Without any obvious warning, my laptop will no longer boot into windows vista beyond the "microsoft corporation" screen with the green progress bar. it will get past the...
@rkbrown1_rb
If your Dell diagnostics shows no fault on the hardware (hdd, memory, chipset, videocard, etc.) but still same issue occurs, I recommend doing another test using a different utility. Try using Hiren's Boot CD that can be found here and try running the S&M Stress Test 1.9.1 and Video Memory Stress Test 1.7.116. If your computer hangs while doing the stress tests, the video card or CPU might be failing already.
Good Luck.
Sep 05, 2011 | Dell Vostro 1500 Notebook
On power up the computer shows the windows screen and then will freeze with the progress bar stopped. It will stay like this until the machine is powered off by holding down the power button. Next it...
Hi
If it freeze and error codes comes out, It might be defective RAM MEMORY. Just replace new RAM memory card.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
Jun 01, 2011 | Computers & Internet
Dell inspiron 1525 will not boot. it posts but will not go past the dell spash screen. tried accessing restore partition.... tried reinstalling windows from restore cd....says windows loading then hangs...
RY THIS FIRST Hold down FN KEY and POWER Button for 3 Secs to go in Diagnostics Mode (works on almost all Dell Laptops) and run the full test you'll find something wrong if its a internal issue (even if its a hard drive issues), see if that fixes it, but I'd check the CPU HS Fan (the slots where air comes out)just blow in there and you'll see dust come out, clean it out with Air Can or Air Hose at 60PSI to prevent it blowing your blades up on the fan. If its not a hard drive or cooling issue, might want to try the Memory check (Dell has laptops have memory issues from time to time) Hope this helps!
Feb 27, 2011 | Dell Inspiron 1525 Notebook
17 inch monitor goes blank
  • Prepare to diagnose the computer .
    1. Disconnect all peripheral devices.
    2. Perform a Hard Reset.
    3. Disable the Automatic restart on system failure option.
  • Remove any non-system disc from the computer . During startup, the BIOS checks different devices to locate the Windows operating system. If the boot order is set to check the optical disc drive or the card reader (if the notebook is equipped with a card reader) before it checks the hard drive, and there is a non-system disc in the CD/DVD drive or there is a memory card in the card reader, the boot will fail. This problem can be resolved by setting the BIOS to check the hard drive first.
  • Reseat the memory modules . If you are getting memory errors, most BIOS versions have additional tests that can be run to test the memory. There could be a problem if one of the sticks is defective or loose in the memory slots. To determine what is causing the memory failure, disconnect all electrical power, and then remove and re-insert the memory modules firmly into the slots. Some HP Notebook PCs come with two sticks of memory and have two memory slots. On most notebooks, the memory module compartment is located on the bottom of the case, but the exact position varies by model. On some models, the memory compartment is under the keyboard. See your User Guide for the exact location of memory modules on your notebook.
  • Reset the BIOS to default condition . If you have made changes in the BIOS setting, such as disabling a device or changing the boot order, it could prevent the computer form starting properly. To restore the BIOS to its factory-recommended settings, turn on the computer and press f10 to access BIOS setup, and then press f9 to load the default BIOS configuration.
  • Perform a memory self test . There are different reasons that you may see a memory error. There could be a physical problem or it could be a program error. If the error is a program error, you will most likely see a Windows error message. If there is a physical problem with a memory module, the computer may fail part way through the boot process. Most computers have a built-in memory test to help identify if the memory modules are seated properly and are free of errors. To run the memory test, turn on the computer and press f2 .
    • If the System Diagnostics screen displays, select the Start-up Test to run the system memory test. Press the Esc key once the memory test is complete.
    • If the BIOS Diagnostics screen displays, select Memory Test .
  • Reseat the hard drive . If you get a specific hard drive error message on a black screen indicating the hard drive error, reseat the hard drive. If the computer has been dropped or jarred, or the hard drive has been replaced recently, the drive may not be seated tightly. The hard drive LED should blink if the hard drive has a solid connection in the notebook. Refer to the on-line User's Guide for specifics on locating and removing / replacing a hard drive. HP provides video directions for performing this task for many computer models. Remove and reseat the hard drive firmly into the mounting bracket.
  • Test the hard drive . If you get a hard drive error message, you can test the hard drive. Many computer problems are related to soft failures (or degraded performance) on the hard drive. The HP Hard Drive Self Test will repair soft errors on the hard drive, but it will not report the errors. After the test is complete, restart the computer to see if test repaired the problem you may been experiencing. To run the hard drive test, turn on the computer and press f2 .
    • If the System Diagnostics screen displays, select the Hard Disk Test to run the hard drive test. Allow the Quick and Long Hard Disk Self Tests to run.
    • If the BIOS Diagnostics screen displays, select Primary Hard Disk Self Test . Allow the Quick and Long Hard Disk Self Tests to run.
  • Feb 04, 2010 | X2Gen MG19MY 19" LCD Monitor
    Boots to progress bar before loading windows
    It seems that windows tries to check your Hard Disk for errors before loading the system files to memory. Do you hear some sounds from your hard disk? If you can successfully get to windows, open my computer => right click on drive C => Click on Properties => Click on TOOLS Tab and click CHECK NOW button.
    Check the next 2 options and answer YES when windows ask you to schedule a thorough scan during next boot.
    Regards!
    Jul 21, 2009 | Acer Aspire 5100 Notebook
    My E1705 does finish coming up or turning on.
    if the computer is booting up (you see the dell logo and then the windows logo) it could just be that your ram needs to be reseated, its very easy to do but if your not comfortable doing so any computer shop would be able to do it but most likely not for free. if that doesnt do it try to reseat the hard drive and or the wireless cards, any loose components can cause it to freeze, also if you have any USB Devices hooked to the computer during bootup make sure you remove them while troubleshooting. Past that it would be either a mechanical failure in the Harddrive of the computer or possibly failing memory or motherboard. You will need to do extensive troubleshooting to determine that. If you have a waranty with Dell they will walk you through the paces if your not sure what to do next you can ask me as well.
    Best Regards,
    B.
    Mar 24, 2009 | Dell Inspiron E1705 Notebook
    Dell Dimension 5150 (DIM515MIN) PC Desktop Logo
    237 people viewed this question
    Alun Cox
