Question about Nextar X3-03 Car GPS Receiver
My x3-03 will not charge, auto or house , it will turn on when I ave the usb plugged in, whats going on. Jim
  • 3524wells Sep 03, 2010
    how do I get a new charging port, I have tried both 12 volt and 110 house hold chargers, can I get into the area behind the unit to repair it my self.
    Jim
  • 15,935 Answers
The battery has failed.
It is internal, and not user-serviceable.
Thanks!!!!
Posted on Sep 03, 2010
    Genius:
  • 1,478 Answers
The charging port of your nextar x3-o3 GPS might be bad, if you have a spare charger/adapter, try use it to see if it will charge, but if did not still charge, it means the charging port is bad.
Take care.
Can I hook up a 4 port usb hub backwards?
well if you plug the usb cord that powers it into some thing else that has a usb port that is running electricty through it such as a pc you should be able to plug in any thing that needs charging with a usb cord that will go into the 4 ports . so i guess it should work i know it wont mess anything up so go ahead and try it. also if you got a usb wall charger that can hold a usb cord you can plug the 4 port usb hub into that and it will work like a charger for things with usb chargers.
Dec 17, 2012 | Video Game Consoles & Games
How do I charge the Go Gear Vibe other than USB port
Not sure what you are looking for, but you could get a wall charger. You or someone you know might have a plug for an older cell phone that uses the USB mini-b plug. That would allow you to charge it in your house or car without a computer. You can purchase USB charges for you home or car. Finally, you could follow the many instructables on building your own USB charger, if you wanted a learn something while you are at it. All of these would allow you to charge without a computer, which is what I think you are asking about.
-Kenn
Feb 16, 2010 | Philips Audio Players & Recorders
How do I change Spark plugs?
93 park ave has a v8. Four plugs on each side. Followthe spark plugs from top of engine to spark plugs. Use a spark plug wire remover (plastic pliers) to help remove wire from plug. Mark each wire where they go. Go down to auto store and buy pugs and get a swivel spark plug wrench to fit the plugs anduse a extension with rachet to remove plugs (turn counter-clockwise to remove). Replace with new. (new plugs should screw in with fingers, then tighen with socket firmly. Not over tight. I holp this helps a little - ran out of writing space. Good luck
Oct 15, 2009 | 1993 Buick Park Avenue
My 1993 want start or turn over buick park ave.
Check the battery connections and the battery itself the battery must be charged and tested, clean the battery terminals charge the battery and try to start, if no luck take the battery to an auto parts store to have it tested for free replace battery if neccessary, always wear safety glasses when working near a battery. If the battery is good and connections are good replace the starter, but you may want to check the connections at the starter first before purchasing a starter there may be corrosion on the connections.
Aug 03, 2009 | 1996 Buick Park Avenue
Unit won't remain powered-up
You are absolutely correct Jim. Low Battery
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} There are three ways to charge the internal battery in your automotive GPS unit.1
  1. Use the provided vehicle power cable that came with your GPS unit. The unit will charge while powered on and using the device as well as when the GPS unit is powered off and plugged into a running vehicle. About 3 hrs for a full charge.
  2. Use an AC power adaptor. Some units come with this power cable to plug the GPS unit into a wall outlet allowing the GPS unit to take a charge. For units that do not come with this cable, one can be purchased from Garmin's online store.
  3. For most units, the final way of charging the battery is to plug the GPS into a powered on computer with a USB cable2. This method of charging will be a trickle charge and it may take longer (like a full day) than the other two options, however it will still charge the battery. A USB cable is provided with a few GPS models. For those that don't come with this cable, one can either be ordered from the online store or you can use a standard USB to mini-USB cable that fits the unit and plugs into your computer.
1 - Please note that temperature can play an effect on the charging of a device. If the battery registers a temperature of 0°C and below or 45°C and above (32°F and 113°F
Dec 25, 2008 | Garmin nuvi 260W GPS Receiver
I have a garmin nuvi and the cable that you put into your cigarette lighter will not work. I changed the fuse and it still will not keep the unit charged. I can charge it on my computer with a usb cable....
Do you see a lightning bolt symbol over the battery bar graph? This indicates that its charging. If it's under warranty, please contact Garmin on their website. www.garmin.com and call them. No need to worry about this if its under warranty. Send them your charger too.
- Jim
Dec 12, 2008 | GPS
NEW PURCHASE AND PLUGGED INTO AUTO TURNED ON AND GARMIN LOGO APPEARED AND THEN SCREEN WENT BLACK. DOES NOT WANT TO STAY ON. INTSTRUCTIONS SAY UNIT WILL PROMPT BUT NOTHING HAPPENS. IS THERE SOMETHING ELSE...
Yes!!! Please charge the unit overnight. You didn't say what model you have. If it's a 2xx series, plug in the charger and move the on/off switch momentarily to the left until you see the screen say charging. Set the unit down and the screen will go off. If you touch the screen again, it will come on. After charging is done, when you touch the screen it will say charging is complete. Remove the charger. If its' a 3xx or 6xx product, hold down the on/off power button until you get the charge screen.
- Jim
SHARCNET-USA
Dec 11, 2008 | Garmin GPS
1991 park ave ultra
if the car cranks and your fuel pump works with no fire to the plugs then you've got yourself an electical problem. the first thing i would check is the condition of the distributor. does is spin when you crank the engine? if it does the mechanics of your distributor is fine. next make sure all cables on the distributor is properly connected to all distributor ports as well as the battery connection as well.
Sep 02, 2008 | 1991 Buick Park Avenue
23" olevia lcd does not turn on
Plugging in the USB worked for me too!
May 14, 2008 | Olevia LT23HVX 23 in. LCD Television
Nextar X3-03 Car GPS Receiver Logo
75 people viewed this question
Top Nextar GPS Experts
Are you a Nextar GPS Expert? Answer questions, earn points and help others
