Question about KitchenAid KAWS850L Top Load Washer
Washer not taking in water in wash and rinse cycles in cold cycle
  • Anonymous Mar 26, 2014
    When setting the washer for cold wash and cold rinse, it's doing it with warm/hot water on both cycles?
  • KitchenAid Master
  • 43,501 Answers
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Posted on Sep 03, 2010
I load washer it starts the wash cycle it goes through wash cycle fine drains water but does not collect water for rinse cycle it just idles. So I turn knob to spin and it spins until done.
If it doesn't fill for the rinse, I would say that the cold inlet valve has failed. Check that the cold tap is turned on and check when the machine fills for the wash cycle and see if it is taking hot or cold water. You will probably find that it is filling only with hot water. A local spares store should have the valve you need.
Sep 17, 2015 | Whirlpool Ultimate Care II LSQ9564J Top...
Rinse cycle not working on Kenmore 600?????
sounds like a program prob not familiar with this mech but it seems suspect
Mar 01, 2015 | Kenmore 600 3.5 cu. ft. Top Load 110-2962...
Cold water won't stop before rinse cycle
if it fails to stop running only at the rinse part of the cycle it is probably in the timer as the solenoid valve has to cut the water off when the washer fills for the wash cycle too. fills for wash cycle and cuts off water, washes and drains, refills for rinse cycle and water just keeps running? does this every time you run it? that's in the timer. bad solenoid (water inlet valve) would keep running even on wash fill up. hope this helps.
Feb 25, 2014 | LG WM2688H Front Load Washer
For some reason my GE GBVH6260 washer cycles are getting hung up on either the wash or rinse cycle. Some days it will stay stuck in the wash cycle & some days it will stay stuck in the rinse cycle for...
Most likely its your water inlet valve..(cold side is not letting water in). Very common problem that usually manifests during rinse cycle since rinse uses always cold water.
According to your model # , part # is WH13X10023
Jul 10, 2017 | Washing Machines
Water will not fill during rinse cycle. it does fill when i start the machine but not during rinse cycle.
The rinse cycle only takes cold water so I suspect that you have a bad or maybe clogged water valve on the cold side of valve.hope this helps.
May 29, 2011 | General Electric WBSR3140GWW Top Load...
My whirlpool washer fills up with hot / warm water (cold doesn't work) pretty quick for the washing cycle but it takes forever when filling the rinse cycle....help
The amount of water on the rinse is lower becaus it's using cooler water. You stated that the cold water isn't working.
Shut the water supplies off. Take the hoses loose from the hose bibs. There should be screen washers in the end of the hose. These are to catch the sediment that normally flows through the water supply pipes in our homes... Take the washer screens out and clean them with an old toothbrush.
Reinstall and while you're at it clean the hot side too.
Then take the machine end of the hoses off and check that it's all clear there as well.
Re install and run your machine on a cycle and monitor it to see if there is better flow on the cold wash cycle AND the rinse portions of your cycles...
If there is no screen washers in the hose, chances are you'll need to clean the water supply valves in the machine... real fun.. HOPE There's washers in your machine..
K
Jul 24, 2009 | Whirlpool Washing Machines
Water barely trickles out for rinse cycle
It sounds like you have some buildup in the cold water valve screen. Where the hose connects to the washer there should be a screen inside the valve. Remove the cold water hose from the washer and clear any debri on the valve screen.
If this doesn't fix the slow cold water flow then you will have to replace the whole water valve assembly. The water valve is the piece that the hoses connect too and supply water to the washer.
If you have anymore questions about this please ask. I will be more than happy to help you out.
Thanks
Jan 10, 2009 | Kenmore 24032\24036 Top Load Washer
Spinning cycle
Keeping in mind that the soap & bleach gets dispensed into your wash on the second to last rinse cycle and that most all rinse cycles are in cold water. Is your cold water valve screen plugged causing your washer to rinse poorly? Are you using the HE detergent? If not maybe the washer is sudsing up to much and having a hard time rinsing all the suds and bleach out and leaving the clothes soapy.
Fill the washer up with no clothes in it on a cold/cold wash setting does it take a long time to fill the washer up? Also when it is full and agitating is there suds in the washer?
Last suggestion is if the drain is hose is a lot higher than the top of the washer it might have a hard time draining out all of the soap water before the next load
Mar 23, 2008 | LG WM-2277HW Front Load Washer
KitchenAid KAWS850L Top Load Washer Logo
105 people viewed this question
Top KitchenAid Washing Machines Experts
Sal DeAngelo
thinksewfast
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
