Question about Rollei 66 Dual Slide Projector
I have a Rollie Type 350A slide projector serial No. 8096942 made in Singapore. The slide carrier is firmly locked in the slide projection position so that I cannot remove it to release the slide carrying tray. Do you have any suggestions please. Norman Collins.
  • zen180181 Sep 03, 2010
    Rollei Slide Projector Type P350A Serial No. 8096942 made in Singapore. Movable slide carrier became jammed firmly in the slide projection position and the slide carrier tray could not be removed. Solution found was to remove machine cover and rotate fan by hand whilst easing the slide carrier away from the machine.
  • 944 Answers
There will be bumber pad along the side .Which gets it locked some time.So you have give some pressure to release it.so that the slide carrying tray can be easily removed.
Posted on Sep 03, 2010
How to remove a Croussel from Ektagraphic AF1
First of all, make sure the LOCKING RING is in position on the tray & locked! This will prevent all the slides from falling out when you remove the tray. Next, place a quarter (or a dime or a penny) in the SLOT in the HUB of the projector. Turn the coin to release the Emergency Latch Release and lift the tray off. Flip the tray upside down. Remove the jammed slide from the optical gate of the projector (inspect it for damage - "dog-eared" slide corners cause this kind of jam) and re-insert it in the slot of the tray from the underside (now facing you). Now rotate the tray until the pointing arrow and the notch on the bottom of the tray align. At this point the tray should be back in the "Zero" position and can be re-installed on the projector. I have attached copies of Kodak instructions for this, as well. Good Luck !! Jim4d786888-c152-4bd3-b086-29e6f8e29e37.jpg409ae3e8-80fd-44c8-820b-23fd94def009.jpg
Mar 14, 2013 | Kodak A Ektagraphic 35mm 140 Slides Rotary...
Kodak slide projector flap block the slide fron viewing
The spring that tensions the shutter is either unhooked or broken. The spring is located on the outboard side of the slide gate - - & is positioned vertical. Without this spring in place & functioning, the shutter will cover part or all of the projected image path.
Nov 13, 2012 | Kodak Office Equipment & Supplies
Will not load slide
Michael, Is this a Kodak projector? If so, will the tray lock in? Will it rotate if you hold down the "SELECT" button? Look at the slot in the top of the projector that the slides drop into - - is the slide lift lever in the "up" or "down" position with the projector powered on? If you answer these questions, I think I can help you diagnose your projector. Thanks!
Nov 06, 2011 | Office Equipment & Supplies
Where can I get an old Rollie 35mm SLR (singapore Manufacture )tested or serviced and restored to fully useableCondition? It left a shadow on photos lower right corners last time I used it a few years...
Is it Rollei or Rollie?
Kindly mention your country - Is that UK or US or Germany?
Let me know,so that we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 16, 2011 | Rollei Cameras
Lamp changing Instructions for tv model wd-52525
Hello
Unplug your Mitsubishi DLP TV and position the unit so you can easily access the back
Locate and remove the screws for the back panel. Do not remove the entire back of the TV but the lower panel only. The screws will be located in the edge of the panel.
Locate the projection box in the center of your DLP TV. The projection box will have a series of wires coming out of it and be attached to the speaker housing with four screws
Remove the four screws holding the projection box in place and slide the projection box out. It will not come all the way out but will slide out like a drawer. Disconnect the electrical wires at the projection box by pulling the connectors apart. You should now be able to see the projector lens itself.
Facing the back of the DLP TV, the lamp box is on the right side of the projector lens. Pull the lamp box to the right and it will slide away from the projector lens
Grab the top of the lamp box firmly and pull it out of its spring holding clips. Replace it with your new lamp box by pressing the new box into place in the same manner as the old one. Finish the job by reconnecting and installing everything you opened or removed
Mar 18, 2011 | Mitsubishi Televison & Video
When the projector was turned on it started to cycle as when ejecting slides then it stopped and seems to be jammed...the rectangle black screen that opens and closes during the cycle to view slides is...
First of all, remove the tray (use the emergency tray removal in the center hub of the projector). BE CAREFUL not to spill your slides, so before you remove the tray, make sure the tray ring is in position & tight, then when you remove the tray turn it upside down immediately and move the tray plate to the "zero" position. Remove any slides that might be in the gate of the projector. Turn the projector on and cycle the projector 2 or 3 times in Reverse. This should clear a tray/slide jam. Good Luck !!
Jan 24, 2011 | Kodak ABR Ektagraphic 35mm 140 Slides...
How do i set a new daisy wheel for the ML 100
1. Open the top cover.
2. Pull the lever towards you to release the daisy wheel lock.
3. Remove the cassette daisy wheel by pulling it out of the machine by the protruding "ear' on the top right.
4. Insert the desired cassette daisy wheel into the slot and press down gently.
5. Slide the lever back to its' original position to lock the cassette daisy wheel in place. Make sure to press the lever firmly.
6. Close the top cover.
7. Press [CODE]+[RESET] to move the carrier to the previous position.
(make sure the daisy wheel cassette is not inserted backwards. The "ear" should always be on the upper right.
improper insertion of the daisy wheel may cause malfunction and incorrect printing.
It is not necessary to remove the cassette ribbon when replacing the daisy wheel.
Please check the shape of your daisy wheel cassette before replacing the daisy wheel. The daisy wheel cassette type "B" cannot be used with this machine.)
Dec 22, 2010 | Brother ML-100 Typewriter
Kodak 410 Projector/Viewer - no lite through projector or viewer
These projectors were designed & made by Telex for Kodak.
If the screen stays black when you push a slide down into the "gate" (in either viewer or projector mode), then the trip mechanism that opens the shutters when a slide is detected has a problem. It could be an adjustment, a broken or out of position spring or hardened lubrication.
There is no good way to proceed unless you are trained in the service of these projectors. Contact a factory-trained repair dealer. Happy New Year!
Nov 16, 2009 | Kodak Open Box BC-4601 Slide Projector
The first slide advanced and then a black piece came across the lens and didn't retract. what do we do?
These projectors are equipped with a "dark shutter", which stays closed unless it detects a slide in the "gate" (projection path). With the projector on, try GENTLY inserting a pencil on the movable levers that hold the slide vertical in the gate. If the "dark shutter" does not open, then chances are the lever that "trips" it open has been bent or somehow moved out of position.
I recommend you contact a factory-trained repair dealer.
Nov 15, 2009 | Kodak Carousel 4400 Slide Projector
The roller spins freely on my brother sx-4000 typewriter
Did you recently remove the daisy wheel cartridge? If you did... did you remember to slide the lever on the right hand side do the cartridge carrier back into its original position to lock the cassetted daisy wheel in place? Remember...make sure to press the lever firmly.
Press [CODE] + [RESET] at the same time to moe hte carrier to the previous position.
Apr 04, 2009 | Brother SX-4000 Typewriter
Rollei 66 Dual Slide Projector Logo
189 people viewed this question
Top Rollei Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Rollei Office Equipment and Supply Expert? Answer questions, earn points and help others
