Have to use an external monitor to see desktop or any infomation. I can barley see anything on the laptop screen. tried hard re boot and it did not work. tech said the lamp was gone.
    Sergeant:
    Champion:
  • 233 Answers
The issue might be due to the corrupted display display drivers. Reinstalling the drivers may fix the issue.
Visit the below weblink for more information:
http://notebook-solutions.blogspot.com/2009/05/notebook-solutions-notebook-solutions.html
Posted on Sep 03, 2010
Apple MacBookPro 2010 is in a white screen
If the start up sound plays and the hard drive sounds normal try connecting the computer to an external monitor. If the external monitor shows the desktop just fine then the cable connecting the laptop to its screen is probably going bad.
If the computer will not boot at all try zapping the PRAM by
  1. Pressing the power button and then command-option-p-r before the gray screen comes up.
  2. Hold those keys down until you hear the startup chime.
  3. Let go of the keys and let the Mac reboot.
If that doesn't work try booting from an install disk and run a repair utility.
Jan 28, 2014 | Apple 13" MacBook Notebook Computer ...
Pc switching on but lines on screen only
If you can't see anything - even the text from BIOS when it boots, I would suspect that it is probably the monitor. If the PC USED to boot fine, then suddenly started behaving this way it is very possibly either the monitor or the signal to the monitor.
You didn't say if the PC is a desktop or a laptop. If it is a laptop, try to find an external monitor to connect to. Of course, in most cases laptops require that you switch them to a dual monitor mode, which will be difficult if you don't see anything on the main monitor.
Is the a Windows machine? What version of the OS are you running? Have you made any changes to the system?
Also: be sure that if you are using an external monitor, the cable is seated fully and tightened down.
Jun 03, 2012 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Blank screen
Did the laptop boot up all the way except the screen is blank? Do you hear fans running and the hard drive spinning, lights on? If you think it booted except the screen is blank try the steps below.
Shine a flashlight on the dark screen to see if you barely see the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works, then your screen is bad. If you see no icons by shinning the flash light and nothing shows on the external monitor, then most likely your video card is bad.
May 23, 2012 | Computers & Internet
Dell Inspiron8600 display is blank. It begins booting, the screen flashes with the Dell logo then it goes blank. I can see faint images on screen but can't read anything. Can I hook up to an external...
If you get the boot image on your screen then you screen is working correctly unless there's something that you not explaining. You can try an ext. monitor if you think it is something related to your LCD screen not woring during boot up. If the ext monitor not showing your laptop to boot then you have problem with your OS and may need to get it repaired or restored.
Oct 31, 2009 | Dell Inspiron 8600 Notebook
Gateway laptop seems to boot, but no screen and cannot do anything. Seems to boot up, but nothing at all is on the screen (not even the cursor). Power and wireless lights are on, can hear CD drive scan and...
Can you hear sound playing as if it were loading the Windows desktop? If so, there are are a few things to check for:
  1. Look VERY closely at the screen once the laptop is on. Can you make out very faint images? They will be hard to see and it's best to be in a well lit area at the time. If you do see images, then the backlight on your LCD screen has gone out. You will need a new LCD most likely.
  2. If you don't see any image at all, try plugging an external monitor into the laptop and booting up the laptop. If you see an image on the external monitor but not the LCD, then you may have a bad inverter/cable/LCD.
If you cannot get an image on the external monitor either, then your video card may be bad. Considering that a lot of laptop video cards are built-in to the motherboard, you may be looking at having to replace the motherboard of the laptop (about 2/3rds the cost of the laptop).
There may be other problems at hand, but those are the most common I've found in this type of situation.
Sep 02, 2009 | Computers & Internet
The monitor on my laptop has been broken for a while so i'm using an external monitor, now all of a sudden when the laptop gets to the loggin screen it switches to the native (broken) laptop monitor and...
open the device mgr. and disable the internal and set the external as default windows should set it as default automatically when disabling the internal
Dec 21, 2008 | Computers & Internet
Black screen for hp laptop
Initially, a couple of ideas ou may want to explore:
  • hook an external monitor. Often there would be a VGA connector at the rear of a laptop specifically for this purpose. It would need a standard 15 video cable normally attached or with the external monitor. You may need to cycle through Fn + F? keys to enable the external monitor. F? would be the function key with the small monitor icon;
  • remove the hard disk of the erring laptop, connect it to a 2.5 to USB adapter and attach to a free USB port of a 2nd computer. it will be treated as an external storage device much like a thuimb/flash drive and therefore would allow copy and paste;
  • tap on the cover of the laptop, the one right behind the LCD screen anywhere on the sides, this is in the hope that it is a cold solder or loose connection;
  • run the laptop with the lid not fully opened;
  • slightly warp/twist the lid/LCD, it could just be a loose connection;
  • if the display works even just momentarily, then chances are that no major repair work is required. The bulk of the job would be in the opening and offhand, no major component replacement.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 16, 2008 | HP Pavilion dv4000 Notebook
Cant see anything but white screen after bootup
Plug in an external monitor and use the F key with the FN to toggle between lcd and external monitor. On my laptops It is the FN and F5. If the external monitor works the problem is the the inverter board, the flex ribbon cable or the LCD. If the external monitor is also messed up then the problem is probably the video card/ motherboard.
May 14, 2008 | Sony VAIO VGC-LS30E 1.73GHz Pentium Dual...
No Power,No Booting,...
try to visit http://www.acerpanam.com/synapse/forms/webpage.cfm?siteid=7117&areaid=2&website=AcerPanAm.com
probable cause: there is an external device connected to your computer like printer, external hard drive or docking station. remove any if there is
could be a video card issue: try using an external monitor if you will get to see anything on it. if video card is integrated and you still have a warranty in your system have your motherboard replaced. when you use an external monitor be sure you know how to switch the screen from your lcd to the external monitor.
when you turn on the computer do you get to see anything come up on your screen before it goes blank?
try also removing the memory/ies of your system. see if you will get to see an error message on the screen and beeps from your computer without the memory. then try putting back 1 at a time and try using other memory slot to check if one of the slot is not working or just your memory
May 01, 2008 | Acer Aspire 5100-5022 Notebook
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
