Question about Maytag MSD2454G Side by Side Refrigerator
Small pool of water under freezer side of my side by fridge freezer
  • Maytag Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 03, 2010
Ice Diamond model RF68 - what could be causing a small pool of dark brown liquid to collect under the front right hand side of the unit. It has no noticeable smell & dissolves easily in water. The...
Rusty water melting from the drain pan or insulation. Check the condenser is clean, and the drain dan that sits on top of the compressor isn't split.
May 06, 2014 | Freezers
Whirlpool refrigerator is leaking water
If the water is pooling around the bottom of the fridge I would pull the fridge out and pull the panel of the back of the fridge and check to make sure the black plastic drain pan is in place and the white or clear plastic hose coming from the bottom of the fridge is aimed at the drain pan, if they are not then that would be why you have water pooling up under the fridge. Generally the Walter gos into the drain pan after defrost and the heat from the discharge lie of the compresser evaporates the water and it should never overflow. Hope this helps
Sep 08, 2012 | Whirlpool GB2FHDXWS (63 cu ft) Top Freezer...
There was standing water in the bottom of my Roper refrigerator under the crisper drawers. The drain pan under the fridge was dry. I cleaned up the water and vaccumed under the bottom of the fridge. ...
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the center
Good luck
I hope this helps
Gene
Jul 31, 2011 | Refrigerators
The refrigerator is not defrosting properly, and water is pooling under the fridge daily. In fact, water congregates in the bottom of the freezer side. What doesn't escape to below the fridge, freezes...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Aug 31, 2010 | Jenn-Air JCD2389G Side by Side...
Water pooling under right front of refrigerator
is there any ice on freezer floor or is the bottom rack iced in?if so you have a blocked drain in the freezer,or if that's ok you could have a crack in one of the plastic water lines,also check the catch pan where the water drains into when the fridge defrosts,you can pour water down the drain in the freezer to check that,roll the fridge forward and take the bottom panel off the back,should be easier to check for leaks and take off the front kick panel,while you're in there vac out all the dust in there,front and back,you should do this every 6 months
Jan 23, 2010 | Maytag MSD2756G Side by Side Refrigerator
Hi freezer on american style fridge freezer is
there is a defrost mode that melts any frost or ice on the evaporator coils and drains it into a pan under the fridge. if that drain is blocked, the water will pool inside. also check the door seals. if warm moist air leaks in, it'll condense on the cold interior and pool as well.
Nov 10, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Flooding when freezer defrosts
Make sure the refrigerator is level and the drain tube is not clogged. This is the most common cause of water pooling.
Jul 29, 2009 | Refrigerators
Leaking water from freezer side-by-side GE refrigerator
Hi, It sounds like the defrost drain is plugged. You will need to remove the rear inside panel in the freezer and unp,ug the drain. Once you remove the rear panel, you should see a collestion of ice under the evaporator coil. Locate the drain hole and clear the ice. Flush the drain hole out with hot water to make sure it will drain. You might have to run a wire through the drain or you can flush water through it with a baesting serienge.
I hope this helsp you. Please let me know if I can assist you further.
Vic
Jul 01, 2009 | Refrigerators
Fridgidaire Gallery Series Side by Side Refridgerator
"jennycub" sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine. very common problem( easy to detect. water on the floor of freezer compartment) as far as the other posting by" humblerumble", ive seen where the drain tube under the refig has pushed a hole into the drain pan under the refrig, in which case it will only leak after a defrost cycle, with the kickplate removed grab a flashlight and look under the unit for the drain pan as you pur water into the back of the freezer sect to trace water flow
Oct 24, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Maytag MSD2454G Side by Side Refrigerator Logo
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
