Question about LG LH-D6230 System
Audio playback hello every one. i have lg lh-d6230 dvd player. my problem is ..i had a dvd movie which is playing in my pc but when i play in this lg dvd player the video is crisp and clear but it is unable to play audio.....if anyone has a solution to this please help me.....
    Genius:
  • 1,224 Answers
1.bad rca jacks
2.could be connected to wrong audio lead rca jack
3.the settings in dvd player donot match the receivers example- dts or ntfs
4.make sure its regioned to your player some audio isnt on the disks
5.pc's usually have new cd formats that came out
cd's and dvd's for some reason in this age isnt being able to play fully in older equipment do to the change in cd/dvd formats which makes you go out and buy new equipment it happened to me not just 2 weeks ago bought a new dvd and found out it wouldnt play in my year old dvd deck had to go out and buy new dvd deck then disk and all my others played fine
Posted on May 12, 2008
SOURCE:
Lost remote control of my lg dp122 and now i dont know if i can play movies
get a logitect universal remote and set it up to the dvd player.
I know what you are asking and I don't think you will be able to move or select sub menus on movies without a remote.
or buy another remote
http://www.ebay.com.au/itm/like/261378869015?hlpht=true&ops=true&viphx=1&lpid=94
Jan 26, 2014 | LG DP122 DVD Player, Multi Format...
LG DVD player LH-D6230 - displays "dvd error" soon
Eprom corruption. Replace eprom, and edit in mode service.
Jan 07, 2011 | LG Audio Players & Recorders
Cannot record t.v. programmes after the changeover on video
I put the recorder channel on AV2 and then recorded it. It worked. Thank you anyway.
Dec 29, 2009 | Samsung SV-DVD55 DVD Player / VCR Combo
Playing DIVX on an LG LH-RH3690 DVD recorder
You can not view from the USB, since the USB port on the DVD player is ver 1.1. The transfer speed is to slow to watch a movie. Alternatively you can copy your movie from your flashdrive to the harddrive and watch from there. You will see what I mean with slow speed when you copy the movie. It takes ages.
Sep 11, 2008 | Yahoo YDP305 DVD Player
No Audio from Input
My 5.1 channel became 2.1 channel. What is going on? It play normally last few days. When i check in SETUP menu, surprised that audio setting change to 2.1 channel. No matter how i reset it , off power, push the microswitch on the PCB board, still cannot turn it back to normal. Anybody can help.....from malaysian
Jun 20, 2008 | LG LH-D6230 System
Lg LH-D6230. How to hook up? PLEASE HELP! NO INSTRUCTION MANUAL!!
je kan met 2 tulp aansluitingen via de dvd speler audio out naar je tv gaan en dan de instelling aux van de dvd speler gebruiken zo kan je surround tv kijken
Jan 16, 2008 | LG LH-D6230 System
LG LH-D6230 DVD
I had a similar problem coming from South Africa to Australia and had to change the regional code setting.
Change to multizone format:
1)Ensure no disk in unit
2)Unplug unit from AC supply
3)Plug unit back into ac supply
4)Use remote control for the following commands:
5)Press the power key, the unit will come on
6)Wait until no disk appears on the display
7)Press sequentially the keys: PAUSE;3;1;4;1;5;9
8) "Code" will appear on the display
9)Press 0 (multizone)
10 Press sequentially the keys: PAUSE,POWER
11)The unit will turn off(standby mode), leaving the new regional code programmed. If you do not succeed at the first attempt disconnect the unit and repeat the above steps (1 to 10)
Hop this helps
Susan
Jan 12, 2008 | LG LH-D6230 System
IS POSSIBLE TO UPLOAD DIVX PROGRAM (PATCH) ON IT ??
Try this:
http://www.videohelp.com/dvdhacks?dvdplayer=D6230&hits=50&Search=Search
Apr 18, 2007 | LG LH-D6230 System
LG LH-D6230
The life of LG optical pick-up is Aprox.1000hours if it is more then 1000 hours used then just replace optical pick-up.
Feb 07, 2007 | LG LH-D6230 System
LG LH-D6230 System Logo
285 people viewed this question
Top LG Audio Players & Recorders Experts
Marvin
Marvin
PNiss
Mike Duncan
Mike Duncan
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
