I have a Pioneer VSX-D912 Receiver. All of a sudden his evening, the unit starts overloading and shutting down. This only happens when choosing dvd option or cd. When using cable option, everything fine. I run the sound from the cable thru speakers same as dvd. have had set up same way for a while. What could be causing this possibly??
    Novelist:
  • 150 Answers
If the problem only occurs with some inputs, not with others,
it is most likely that you have a severe "hum" problem on
the input cables.
A large amount of hum (or feedback oscillation) on any input
may cause a critical condition on the output due to distortion.
Because this condition can blow the amplifier, as well as the
speakers, not to mention that it can damage your ears, a smart
(modern) receiver may trip a safety circuit when this happens
and turn itself off.
One of the problems with over-loading an input with hum or
an out of control oscillation, is that the rogue signal is amplified,
causing the output amplifier to clip the peaks of the resulting
waveform. The clipped peaks (in turn) contain intense high
frequency harmonics, whose energy can exceed the normal
operation parameters by several orders of magnitude
(from Fourier Transform Theory)
These high energy harmonics will barrel through a normal
speaker's frequency cross-over network, causing the speaker
(tweeters) to blow, damage to the amplifier and/or cause
extreme hearing pain.
For this reason overload protection is a good idea.
1) When troubleshooting this problem, always start at a very
low volume and turn it up very, very slowly. Ware hearing
protection at first, if you are not sure what to expect.
2) Listen for any objectionable noise, hum, roar, whistle....
etc.
3) Check the grounding on the offending input cables.
4) Unplug the offending device from the input, and check
if the problem persists, in which case the receiver is defective,
or if it does not, then the input device is at fault.
5) If you have a digital DC voltmeter, check that no DC voltage
is present at the output of the offending input device.
6) Clearly if the problem occurs only with some inputs,
then it is caused by:
a) The input device such as the CD player
b) The connecting audio cable
c) The receiver input jack (ie grounding)
d) The receiver's input pre-amp (internal)
e) The receiver's internal switching.
The problem can also be caused by a faulty power-supply
or line isolation within the input device (such as the CD player)
Any problem beyond this stage, such as a defective final
amplifier, shorted speaker wires, etc....
would cause symptoms regardless of which input you selected,
which you said is NOT the case.
Hope this helps, Martin
Posted on May 22, 2008
    Scholar:
  • 70 Answers
Try this before you do anything else. Swap the inputs around at the receiver. important that you do it a the receiver, not at the devices. So you wind up with the cd\dvd player in the cable input and the cable input in the cd input. Do have the same problem????? If yes at least we've isolated the problem to the the cd player or it's cable so the easiest thing to do is to change the cable
If no, and the problem is the cable now, it's within the receiver.
Come back witht the answers.....
Posted on May 12, 2008
    Genius:
  • 1,224 Answers
I have same model pinoneer the manual states one of several things here
sometimes when moving unit loose strands of speaker wire get caught inside speaker panel insert please clean our and wear a static guard ground velcro wire attached around arm with wire attached to sterio this keeps static from zapping your receiver
Make sure there are no loose strands of speaker wire touching the
rear panel. This could cause the receiver to shut off automatically.
• If the STANDBY indicator blinks and the power shuts off
automatically, take the unit to your nearest Pioneer authorized
service center or your dealer for servicing.
When a search is performed
by a DTS compatible CD
player during playback, noise
is output.
• This is not a malfunction, but be sure to turn the volume down to
prevent the output of loud noise from your speakers
• If the unit does not operate normally due to external effects such as static electricity disconnect
the power plug from the outlet and insert again to return to normal operating conditions.
Resetting the main unit
Use this procedure to reset all the receiver’s settings to the factory default. Use the front panel
controls to do this.
1 Switch the receiver on.
2 While holding down the TONE button, press and hold the
 STANDBY/ON button
for about three seconds.
3 When you see RESET? appear in the display, press the TONE button.
OK?
shows in the display.
4 Press TONE once more to confirm.
OK
appears in the display to indicate that the receiver has been reset to the factory default
settings.
these are the most technical explainations that this system gives
    Problem Solver:
  • 13 Answers
If the Cable works fine, and the DVD does not, then the Receiver is most likely not overloading and shutting down. You don't mention how your DVD is connected, but I'm going to guess it's with a fiber optic cable. In that case there's a very high likelihood that the cable is either not seated properly or the fiber optic transmitter in the DVD is intermettent.
Start by removing the fiber optic cable from the DVD and Receiver and switching ends. Use little compressed air in the connectors to blow out any dust. Do not use "lung-power", as the moisture could cause problems. Sometimes the laser connections just line up better, especially with inexpensive cables. If that doesn't help, try another fiber cable. Since they are glass fiber, they are subject to crushing and cracking from being kinked or bent too sharply
If that doesn't work, try the coax digital connection or analog audio connection between DVD and Receiver.
If you are not using the fiber connection, use the same logic: switch to another set of outputs from the DVD, and another set of inputs on the receiver.
My money is on a bad audio cable first, a bad transmitter in the DVD player second and a bad receiver a distant third option.
MANUAL FOR PIONEER STEREO RECEIVER MODEL VSX-D901S
Hi
Check the following link. Its athe manual for VSX D 912. May be the same for your one.
http://audio.manualsonline.com/manuals/mfg/pioneer/vsx-d912.html
Ajin
Jan 19, 2012 | Pioneer Audio Players & Recorders
The buttons assigning DVD, TV, VCR, etc suddenly changed their assignments. DVD was now TV, VCR was now DVD, etc. I don't think it all happened at once either. Now I can't get sound from the...
There are facilities to CHOOSE the digital assignment. I've seen where extended power loss will randomly lose custom settings. Open the manual.
Jul 07, 2011 | Pioneer VSX-D912 Receiver
Is there a pioneer vsx d912 color manual online?
Here is a copy of the user manual of this unit , just click HERE.
Dec 04, 2010 | Pioneer VSX-D912 Receiver
I have a Pioneer VSX-D912. I just switched to HD Sat. When I hook into the component ports, I get no picture. When I use the DVD port I do get a picture.
I have exaclty the same problem. DVD into comp in 1, and my Homecast HT8000 into comp in 2 on my D912.
The dvd gets a picture.
The TV does not.
Looking at the settings I have "Component video Input" set correctly.
I'll add that when I do switch from DVD to TV, I get a scrabled vision of what is on TV for about half a second befoe the TV itself says "No, I can't display that" and gives me the blue screen of 'no signal'
Dec 29, 2008 | Pioneer VSX-D912 Receiver
OVERLOAD
Turn the unit all the way down. Now, before you try to power up again, make Absolutely Certain that there are no shorts or damaged wiring going to the speakers. Still no go? Then try to power up with no wiring attached. Good? Now just the wiring, no speakers. Make Sure that there are no wires touching! Then try speakers. If there is a problem, you'll find it .....accordianman
Mar 11, 2008 | Pioneer VSX-D912 Receiver
Overload...
Pioneer posted this on it's Canadian Web Site:
Poor wiring connections, bad wires or a bad speaker may cause this. As you increase the volume, you will increase the amount of current you are drawing from the receiver. To troubleshoot this issue, try the following:
  1. Disconnect each speaker wire connection. Inspect for any frayed or damaged wiring and replace it.
  2. Check the impedance of the speakers; make sure they are properly rated for your stereo. In most cases, they need to be 8 ohms. Only a few Pioneer receivers will support lower impedance.
  3. If the problem still continues, try these steps:
    1. Turn the receiver off.
    2. Remove one speaker.
    3. Turn the receiver on.
    4. Increase the volume.
If the receiver overloads, repeat steps 1-4 (selecting a different speaker each time). If you disconnect a certain speaker and the receiver no longer overloads, have this speaker checked at a service center. It could have a bad speaker component, like a tweeter, sub-woofer, or even a bad crossover.
Dec 08, 2007 | Pioneer VSX-D514 Receiver
Overload
Ok, how much is "a bit"? If you are operating your unit at the 50% or more level, your unit is working as it should, as DVD and CD players output more signal than other sources...accordianman
Nov 26, 2007 | Pioneer VSX-D307 Receiver
Blinking Standby
regarding the Pioneer VSX-912 blinking standby light. This is how you reset it; press the "advanced surround" and the " enter" at the same time for about 3 seconds. Make sure you press the ENTER on the reciever (its the one on top next to the small dial) If you press the "ON" instead of "ENTER" it will not work. If an error message comes on and shuts the unit down, just reset it again. This should save you some $$$$. To bad Pioneer did't put this info in the manual.
May 22, 2007 | Pioneer VSX-D912 Receiver
907 people viewed this question
 Grubhead
Grubhead
