Question about Kenmore 14.8 cu. ft. Top Freezer Refrigerator with Factory-Installed Ice Maker
Frige work poorly - Kenmore 14.8 cu. ft. Top Freezer Refrigerator with Factory-Installed Ice Maker
  • Kenmore Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 03, 2010
I was defrosting a mini magic chef refrigerator i didn't puncture anything that i can see..but now it won't freeze
It sounds like the proverbial ice pick defrost. The evaporator tubing is so delicate that you could have scratched it enough to cause a small hole. the other possibility is the compressor just stopped pumping. Mini friges are notorious for poor compressors.
Jul 27, 2014 | Refrigerators
The freezer has stooped working it is the two door at top with freezer at bottom and ice and water not sure of model number.
check the back of your frige you will see the black roud metal under your frige that is the compressor check the overload of the compressor and also check the wiring diagram at the back of your frige see ther if thers an existing fuse in the wiring diagram.
Aug 11, 2010 | Refrigerators
Whirpool gold Frige no light or temp display working
I am having the same problem does anyone have a solution?
Dec 18, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water slow ice not thick
if you have a side by side frige thin wen you open the door on your frige side thare shud be two diles one for the freezer and one for the other thurn the one that has freezer two the rite intell it gets on 5 or wen it gets to max and if its a reguler frige then and it a new one then its in the freezer part if its a older one thin there both in the bottom frige an torwds the roof of the inside if that dont work have your filter cleaned and ask a frigeration company geve you a shot of freeon in it
Dec 16, 2009 | Dishwashers
I have water pooling inside the refriderator. It
there is a drain in the freezer than gets pluged, unplug frige from wall, put food in ice chest take hair dryer and melt ice thats at back wall in freezer remove icemaker if there, and back wall of freezer inside, melt any remaining ice, **** up water with wet vac or sponge,see the pinky size hole in the pan under the coils, point hair dryer at it for a wile. now take the the lower back cover off behind frige and blow all the dust out and find the plastic tube, about the size of your finger and put the wet vac on it until you can hear it sucking in the freezer, take e cup of hot soapy water ond poor it in the freezer pan. put everthing back and your good to go
Dec 09, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
Frige freezing solid
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jul 03, 2009 | Samsung RB2155 Bottom Freezer Refrigerator
Frige
check to see if the air chamber between freezer and frige is not blocked with ice or something else
Apr 13, 2009 | Kenmore 64812 / 64814 Top Freezer...
Strange noise coming from new Oster 5 c.f. frige...
I did not post a problem with a wine cooler...We all know that problem was caused by the wrong fuse that was installed at the factory.. My question was about the Oster 5 C.F. frige...no, I did not get any answers...No, I do not want your premium service...I just thought I may get some free insight on my problem...
Dec 17, 2008 | Oster 12-Bottle Wine Cellar - Black
My freezer is working but my frige is not cooling
wrong model # ,defrost problem. remove freezer panel, check heater, check limit switch while still covered in ice, if both ohm infinity, replace defrost timer.
Sep 15, 2008 | Haier HTP18GAA Top Freezer Refrigerator
Kenmore 14.8 cu. ft. Top Freezer Refrigerator with Factory-Installed Ice Maker Logo
42 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
