Question about Home
My Kohler toilet is about 5 years old and is making this awful whistling sound after being flushed. What part needs to be replaced so I can make it quiet again!?
  • 43,501 Answers
The valve that fills the toilet is making that sound... it is filling up with dirt and the water is struggling to get through the smaller hole...
heatman101
Posted on Sep 03, 2010
Water not stop running into toilet when flush on Kohler pull up top flush toilet
Replace the flapper even t looks good the loose the ability to seal
Sep 06, 2017 | Cars & Trucks
Koehler one piece toilet trickling water into tank
The flapper at the bottom of the tank is leaking and needs replacement.
Feb 08, 2014 | Kohler SAILE ELONGATED ONE-PIECE TOILET...
I have a Kohler elongated toilet that is about 4 years old. It occasionally makes a flushing sound on its own while not being used. A plumber said I needed to replace the Comarron tower flush valve, a...
You can look at the gasket thats hooked between the flush valve and the toilet and see if its in bad shape and letting water get past it and eventully flushing your toilet. If its bad i would try to find one similar or drain the holding tank and use a little clear water proof silicone on it. Use a paper clip to clean out the hose going to the flush valve and you should be good to go.
Sep 03, 2012 | Kohler Cimarron 2-PC Elongated Toilet with...
Whine or squealing from tank when Kohler Santa Rosa toilet is flushed.
Sounds like an air lock is making the water fill in squeeze thru the piping. C if u can undo the piping from the tap below the tank and take out tank and try flushing the unit thru from the out side fill pipe. U may hv something stuck in the pipe line. cheers
Aug 25, 2012 | Kohler Santa Rosa K-3323-55 Innocent Blush...
The toilet tank doesn't fill up properly. I have replaced the flap several times during the past 24 months. I have come to the conclusion that the whole flushing system has to be replaced with...
Kohler toliets can be a pain to repair. I have found with them that the only thing to do with them is go to a plumbing company, take the model number with you and replace all in the inner parts to it. You will replace the fill valve and flush valve. After I do this on Kohler I don't have anymore problems with them. It should work for you, just make sure they are Kohler parts. Good Luck
Tool Belt Diva
www.toolbelt-diva.com
May 16, 2011 | Kohler Toilet - One Piece with Ingenium...
Kohler Toilet year old do not have flapper. It has stright pipe
This is how it is meant to work!
Short push of lever for small flush, push and hold lever for full flush.
Aug 16, 2009 | Kohler Toilet - One Piece with Ingenium...
Kohler one-piece has no flushing power
Hi
try to increase the amount of water for each flush .
Jul 17, 2009 | Kohler Toilet - One Piece with Ingenium...
Toilet will not flush
It sound like you have debris caught in the fill valve. Remove the top where the washer is and put your hand over it and slowly turn the water on to flush the fill valve. Replace the washer with a new one and then replace the top.
If you have the old ball and **** style, replaceing the diaphram is harder so I would recommend replacing it with a fluidmaster fill valve. Hope this helps.
Apr 06, 2009 | Kohler K-3422 - Wellworth Elongated...
Master bath toilet replaced with a Cimmeron class 6 confort height toilet. The master bath toilet backs up to the hall bath toilet - same wall. The hall toilet is very old. When the old toilet is flushed,...
Kohler is correct. The most likely cause of this problem is an obstruction in the common vent stack that both toilets share. When you flush the old toilet it need more air to flush and will get it from the easiest source (your new water saver toilet). First adjust the float level in the old toilet so it won't use as much water or just stick a brick in the tank to take up space.Second, run a snake down the vent stack from the roof to check for obstructions. Birds will sometimes nest in there.
Mar 16, 2009 | Kohler K-3489 Cimarron Comfort Height...
Home Logo
238 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
