If i put a 6.3A 250 Fuse in a receiver asking for 6.3A 125V will it damage the receiver
  • 158 Answers
No it wont --in all likliehood your amp is shorted however ,and the fuse will blow again ..its rare that a 6amp fuse blows w/o an internal short causing it
Posted on Sep 03, 2010
Why the slow blow fuse in miele t9800 lt is burnin ?
because your vent is probably clogged up
Feb 01, 2015 | Miele Dryers
Mr. Peter I changed fuse 6.3 amp 125v from f board 6amp 125v from radio shake. is that make any difference.
you need to put fuse 6.3 amp to 6amp with same 125v if fuse not match or it will give problem
May 30, 2014 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Can power on
Check the fuses.Blown fuse conditions
FU1 - 6,3A Doors/covers open is displayed.
FU2 - 6,3A Doors/covers open for the finisher is displayed.
FU3 - 4A paper end condition.
FU4 - 6,3A SC 121 is displayed.
FU5 - 6,3A one of SC302 or SC403 or SC405 is displayed.
FU101 - 15A no response.
Fu 102 - 8A no response.
FU103 - 1A normal operation,optional heaters do not work.
If FU or 102 is the problem,verify the main motor and the fusing unit heater lamps and thermofuses.After change the problematic fuse removal the fusing unit and turn ON the copier.
Apr 18, 2013 | Ricoh Aficio 450 Copier
CAN I USE A 6A 125V FUSE IN REPLACE OF 8A 125V FUSE
An undersized fuse is more likely to pop. There is a reason why fuses are rated as they are
Feb 06, 2013 | Car Audio & Video
The fuse in my microwave oven is burnt. It was rated 15A 125V. Can I replace it with a 15A 250V fuse? What are the pros and cons? I don't want to risk damaging the appliance.
Yes, if it will fit in the holder tightly... you can always change a low voltage with a higher voltage but never take out a 250 and install a 125...
heatman101
Dec 24, 2010 | Microwave Ovens
Can't find 2A 125v fuse replacement for on-off will 250v be OK?
There is no difference between a 125v and 250v fuse. The most important thing is the 2Amp. This fuse is probably the line fuse and could be the only trouble and may have blow with a line surge. Make sure the 2A you use is a Fast Blow Type. If it does blow again you most likely have a internal power supply failure.
Apr 19, 2009 | Sharp Aquos LC-20B2U 20 in. LCD Television
"Protect"
El circuito amplificador de audio esta dañado o dañados si trae mas de uno.
Mar 30, 2008 | Sony STR-DE375 Receiver
6.3a slow-blow 125v fuse
Hi, If the fuse physically fits into your unit then it will work. However- - - WARNING! Although 6.3 amps on a 250v fuse will allow the current to flow it will not afford you the circuit protection you require for a 125v circuit. If the circuit develops a fault then there is a danger that you burn out the circuit before the fuse. As you have already blown one fuse I would suggest tracking down the fault before you do any thing else.
The Scrivener.
Oct 12, 2017 | Pioneer VSX-D458 Receiver
81 people viewed this question
 Grubhead
Grubhead
