Question about Acer AL1711 17" LCD Monitor
Acer 1711 17"Lcd monitor vertical stripe problem
Hi all
I have a problem with a 2 inch dark stripe in de middle of the screen (see through) everything else is normal but de stripe is vertical and darker then the other parts of the screen. After 30-60 minutes the stripe slowly blends in and you can hardly see anymore, Onces I turn the lcd off for a few hours and turn it back on again it starts all over again. Anybody has a suggestion lose contact inside perhaps? or which chip to check
Greetings
Richard
  • 981 Answers
That's pretty easy; not much is wrong. You have a backlight with several sections to it, and one section has gone dark on you; once you carefully take the monitor apart (on old towels, perhaps) and find the backlight circuits and LEDs or compact fluorescents, clean the dust out and retry; if the dark bit persists, you get to repair the supply power (or replace the lamp) for the center bit. Usually it's an edge-lit light pipe (rigid or woven) that lights your 'stripe.'
If you search on the ODM model number you find once you open the thing up (i.e. on the guts) you might get a hint as to how the supply is set up and save some disassembly/reassembly steps or simply find a replacement balanced light-strip or LED equivalent to swap in. Otherwise test the larger capacitors in service in the backlight power section for warmth through a vinyl glove (having also taken other electrical service safety reviews of your bench, in 3 or more passes, with a friend around, so you don't casually spoil the mostly-working monitor or vital organ.) You could use AC probes to find a leaky cap too. (Probably something 3cm cubed with 6 to 8 like neighbors, natch; though it could be that an upstream component is bad and the center circuit merely the victim among the supplied circuits.)
Posted on May 12, 2008
Why in my Acer monitor AL1717 comes vertical lines in middle of the screen ?
Try updating your display driver and also try with another monitor cable, in case its broken.
Apr 28, 2014 | Acer AL1717 17" LCD Monitor
About 2 inch yellow stripe appears on the LCD screen
This typically is a sign of either a problem with the monitor itself, the cable, or the computer.
Fault isolation is key here. If you have access to another monitor, I would suggest connecting that to the computer, or vice versa. That way you can figure out what's broken.
If it's the computer, you might be able to purchase a replacement video card. If it's the monitor - you're out of luck, and likely need to purchase a new one.
Nov 15, 2017 | E-Machines 19" Widescreen Flat Panel TFT...
Connect Digital and Analog cables at the same time.Any use?
does not help. keep dvi connector (white one) on computer and in the back of monitor.
and surely it will not take away those vertical stripes.
those vert stripes... hmm... your monitor might have a problem which you can't fix by your own.
Feb 22, 2009 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Dark vertical stripe on monitor
You screen "LCD" is broken , need new lcd panel. Very expensive
Feb 01, 2009 | Samsung T220HD LCD Monitor
Dark Grey Vertical Bar
1. try connecting laptop to an external monitor and check if this vertical dark gray bar appears. if yes it means video is the problem. you need to boot in safe mode then uninstall the video driver. boot to notmal mode then download and install the latest video driver. if still same problem then replace video card. if video is built in with motherboard you need to replace motherboard.
2. when the vertical dark gray bar did not appear in the external monitor then it means issue is with the LCD panel. Do this turn off laptop. press and hold D key then press Power button at the same time or Press and hold on the Fn key then Power button check if the test will run. Color displays full screen when you keep pressing on N key when the colors appears check the vertical dark gray bar if still exist in the test, this means LCD panel and LCD cable needs to be replaced.
Oct 31, 2008 | Computers & Internet
Acer 5670 screen has dark transparent vertical stripe
you will need to check the display cable and if that is ok, you will need to replace the display panel... You're getting a short on the circuit board causing rows of pixels to be blocked out
Here's your display on ebay...
http://cgi.ebay.com/NEW-ACER-ASPIRE-5670-15-4-WXGA-GLOSSY-LCD-SCREEN_W0QQitemZ320249932106QQihZ011QQcategoryZ31569QQrdZ1QQssPageNameZWD1VQQcmdZViewItemQQ_trksidZp1638Q2em118Q2el1247
Jun 13, 2008 | Acer Aspire 5670 Notebook
2-inch picture stripe in middle of screen.
deight, your set is going into total vertical collapse, either the vertical IC is failing or some support component to the vertical circuit is failing, should not be an expensive repair, hope this helps, BMW Rider
Dec 12, 2007 | Sylvania 6419TA 19" TV
Dark Vertical Stripe on Right Edge of Screen
I experienced the same approx. 1/2" vertical stripe on a Viewsonic vx1945 and ATI Radeon x1050 video adapter on Vista Business SP1, but the stripe appeared along the left edge of the screen, instead of right edge. I then temporarily decreased the monitor resolution, and the stripe went away. I then increased the monitor resolution back to its original setting, and the stripe did not re-appear. So, that was the 'fix' in my situation, hope this helps.
Dec 11, 2007 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Black Out
Hi Detrix, Check with www.lcdrepair.net if you want a repair. Something is wrong with your LCD controller and or GUI interface circuit or the circuit supplying power to it. If your technically endowed, you may want to open the monitor case and clean the dust and lint from around the circuits using a Small paint brush to sweep away any built up dust. These circuits take the Signal from the computer and controls the 2.5 million pixels on the LCD screen. Dsut can cause major problems with handling all that data. Give it a shot, what do you have to loose, its not dangerous if the monitor is unplugged.
Oct 09, 2007 | Samsung SyncMaster 193P 19" LCD Monitor
Acer AL1711 17" LCD Monitor Logo
253 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
