Question about Garden
Where do I find part numbers for my Ariens TR424 rotary tiller. I need a new gear case - aluminium
  • 3,740 Answers
Go to this page: http://www.jackssmallengines.com/help.cfm
The choose menus:
Airens
Front tine tillers
RT424 4hp (note model and serial numbers!) pick yours
It will be 902026-xxxxxxx x= your number
There are 2 gearbox part numbers
1. 00201400
http://www.jackssmallengines.com/searchdb2.cfm?arisku=00201400&aribrand=Ariens&arireturnurl=http%3A%2F%2Fwww.jackssmallengines.com%2Fhelp.cfm%3Fario%253dgetAssemblyCollectionariamparipa%253dS4JA%252bvDiuhxnRQKPG3HpjA%253d%253dariamparica%253dVW4ZVMgDKUJOh%252fyuxQghxw%253d%253dariamparioem%253dT5AoXrwJ%252fdc5PmlGuX535Q%253d%253dariamparit%253dac83beea-d9ce-4586-92eb-5b37a36e4d95&ariqty=1
And
00287100 (Aluminum)
http://www.jackssmallengines.com/searchdb2.cfm?arisku=00287100&aribrand=Ariens&arireturnurl=http%3A%2F%2Fwww.jackssmallengines.com%2Fhelp.cfm%3Fario%253dgetAssemblyCollectionariamparipa%253dwRJIs3RYfQcbYmA%252bu%252bdCDA%253d%253dariamparica%253dYcaPzWhKx8%252f17NVu3Eh%252bXA%253d%253dariamparioem%253dlDrUqX7mT9VVQe1v8FlYOg%253d%253dariamparit%253d0713aa56-cc1e-4998-a4d2-4938cb172940&ariqty=1
That should be what your looking for. All of the seals and bearings can be found there also using the tedious menu search then selecting gearcase at the top of the picture.
Thanks for choosing FixYa.
Kelly
P.s I tried a net search for just the gearbox part number 00287100 with only one result. Seems you will have to use the menus.
Posted on Sep 03, 2010
Testimonial: "Thank you very much. I have now managed to find the part I want and it is being ordered. Hopefully delivered in 5 days. Cheers Jim"
How do i remove the gear case on a lawn boy 55382
take the whole thing apart... Wow and I looked, thats ugly
Dec 15, 2013 | King Kutter II Gear Driven Rotary Tiller...
Oil leaks out of shaft
hello, you have a bad axle seal that needs replacing,replace or keep putting in gear oil,
Feb 09, 2012 | King Kutter Ii Gear Driven Rotary Tiller...
Worm gear has a hard spot, and doesn't turn freely. Tines will run for a short period of time and then stop.
You will probably need to replace the worm gear and any other worn parts in the gearbox. Check your owners manual for part numbers. If extensive repair is needed and your machine is several years old you may be better off with the Mantis trade in program for a new tiller. I found this to be the case with my own tiller last year. Call or go to www.mantis.com.
May 24, 2011 | Mantis Little Wonder Tiller/Cultivator...
How much gear oil for gear box and gear case
most gear boxes have a bottom drain and a side fill plug , you fill until the oil runs
out of the top plug
Oct 18, 2010 | King Kutter Ii Gear Driven Rotary Tiller...
The tiller will not rotate. The PTO shaft on the tractor is spinning but the tiller will not move. The shaft coming out of the top of the tiller will not spin. There was also a burning smell with a...
Sounds as if you might have destroyed the gearbox or cooked the internal clutches or both....nothing to do but disassemble the gearbox to find out...you may have a broken gear tooth or teeth jamming the pinion...the FIX may be more expensive than the cost of a new tiller...call Tractor Supply to see if replacement parts are even available...sorry to be the bearer of such bad news... ;-(
Aug 11, 2010 | King Kutter Ii Gear Driven Rotary Tiller...
I have a Ariens tiller model #901001. The rear
YOUR PROBABLY HAVE A GEAR CHEWED UP?CONTACT CHOOCHOOPARTS.COM FOR DIAGRAM? DID YOU CHECK OIL...IF OUT OF OIL IN REAR TINE TRANSM ...YOU CHEWED UP THE BRASS GEAR ....I REBUILT MY MAIN TRANSM...EASY TO WORK ON...AWESOME MACHINES.
May 04, 2010 | Garden
How much gear oil 72'' tiller
In Gearboxes use gear oil (type GL5-85W 140 or Triple Zero
Grease; which can be poured, and has "EP" i.e. "Extreme Pressure" additives.) Fill the gearbox to approximately half-full level.
Apr 09, 2010 | King Kutter II Gear Driven Rotary Tiller...
I just got a 5' KK rotary tiller and the pto shaft fits onto the tractor just fine with the button lock. The other end doesn't want to slide all the way onto the tiller gearbox drive shaft. It only goes...
http://www.youtube.cohttp://www.everythingattachments.com/Tractor
http://www.everythingattachments.com/Tractor-3-Point-Hitch-Tillers-Rotary-Tillers-s/76.htm
go to the second site first, it will explain your "problem.". Your problem is you need to adjust the length of the pto shaft to your particular application. not all pto shafts fit all attachments "out of the chute"
once the shaft is adjusted OR prio to modifying it, view the first video. both or very well presented. i've been there!
Happy tilling!!
steve wood
Rancho de Suenos
Albuquerque, NM
Mar 10, 2010 | King Kutter II Gear Driven Rotary Tiller...
My king kutter till will not hold gear oil.
If it is leaking around the shaft you can replace the seal.
Mar 23, 2009 | King Kutter II Gear Driven Rotary Tiller...
Garden Logo
702 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
