Question about Gestetner - AO40 Wide Format Copier Copier
Gestetner CP6123 giving error E12
My Copier machine has stopped after the paper got stuck with the master in the waste bin. I have removed all the paper bits stuck and the masters from the drum and the waste bin. but now only the error code E12 is left. how to reset the machine
  • Anonymous Mar 18, 2014
    We really want to fix it
Shut the machine off. Hold down the reset button while turnng the machine back on. This should reset the code unless there's a real problem. Let me know and we can go from there.
Posted on May 14, 2008
You should check the all paper sensor, there must be a pieces of paper in some sensor and make the sensor in wrong direction. You should remove all and off the power for a while and the start to use it.
Posted on May 12, 2008
What causes error 12 on a gestetner 6123 duplicator
6123 gestetner digital copy printer no salve problum single line on copy. cleane complete scanner and thermalhead,
May 15, 2012 | Gestetner - AO40 Wide Format Copier Copier
I'm have error code e12 in toshiba estudio 350,pls help me!
hi there is paper jam in paper path plz first cheq yours machine for paper jam
thanks
May 12, 2010 | Toshiba e-Studio 350 Copier
Where is the waste toner bottle for the Gestetner dsc 535
It is located on the lefthand side of the machine under the yellow pcu unit. You will have to remove a cover next to paper tray 1
Mar 16, 2010 | Gestetner Copier
Gestetner DSM635sp paper stuck error.The machine throws the error and then stops. there is no paper that is ever stuck. Thanks for your help.
Hello sir; There should have a paper stuck over the pick up roller that you can't see if you pull out the tray paper should be squeeze together. the solution way is replace paper pick-up roller.
Oct 01, 2009 | Gestetner Office Equipment & Supplies
Error code e542
The error code means that the finisher bins could not find HP. The problem shows up when something is placed under the bins and stops them from moving down, most of the time a "G" file or a case of paper. Move the object and move the bottom bin up till you hear it click. Before doing that make sure the MAIN Power Switch is OFF on the right side of copier... Then turn the copier back ON and it should clear it self.. Good Luck
Apr 18, 2009 | Canon imageRUNNER 6000 Copier
Gestetner DCS424 error message: replace used toner bottle
There are 2 waste toner cartridges, be sure to empty these 2 cartridges . If you remove the waste toner in both cartridge it will automatically clear the error message.
Feb 27, 2009 | Gestetner Copier
DCS424 error message replace used toner bottle
Cannot print from Tray 1 in Gestetner 6002
First make sure that the machine is reading/ seeing the paper size of the paper that is in the tray ( select tray 1 from the touch screen and see what the paper size reads). If the machine sees a different size then that in the tray, use the 'user tools' and change the paper for that tray. Also, go into your printer settings on/in your computer and make sure that the proper paper size is selected ( the size that is in the tray you want to print from). If the orientation of the paper size is different from the tray -- will not print and give you the error.
May 06, 2008 | Gestetner - 6002 Digital Imaging System...
Can You Help me Please
You need more help than I can give you. Someone needs to take off the back cover and manually move the bins up or down to be able to remove all that paper stuck there. This is the only way to do it and not break a sorter bin, which if that happens, is a LOT more work to fix. The bins could also be jammed on the stapler. Personally I'd leave this job to a qualified tech.
Apr 25, 2008 | Canon NP 6551 Black and White Copier
863 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
