Question about Kenmore 26.0 cu. ft. Side-By-Side Refrigerator
My refrigerator stuck on defrost until I turned it off. After turning it back on it is working good. What caused this? It is a GE side bye side
  • Kenmore Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 03, 2010
Compressor and fan stop working
There is a possibility that the defrost timer turned the compressor and fans off and stuck in the defrost lobe of the defrost timer. I want you to try turning the defrost timer slowly clockwise. The defrost timer is in location 257 behind the control panel inside the fresh food compartment. Here is a photo of the parts location HERE
If doing this causes the refrigerator to work again then replace the=> WR9X489 Defrost Timer
If this does not work I want you to try something else so let me know what happens Thanks
Sea Breeze
Apr 05, 2013 | GE Profile Performance 25.2 cu. ft....
Defrost heater mnot completely defrosting
unplug it and get your hair dryer remove the panel again and blow dry the entire thing untill all is melted be carefull not to over do ad not to put dryer in the freezer stand back where the water will not splash on the dryer after leave it off for 1 hour than turn back on and put setting on number 3 for 2 to 3 hours than adjust to your normal setting not higher than 5 or it will repeat problem.It is getting very well cool causing to over cool to fast.
also air spray out back side and bottom of refrigerator is always a big help
Good Luck
Apr 08, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer & fridge warms up on average every 6-8 weeks. Remedy turn off and leave 24 plus hours with doors open. On turning on the fridge and freezer cool down again to operating temperature....
Good day,
That's too long a period, for a normal. defrost system failure.
You'll have to wait until it quits, then remove the rear panel and look for ice (not frost) building up somewhere in the freezer compartment.
I have solved similar problems on this model, by replacing the defrost thermostat with a GE 60 degree thermostat, and a WR9X330 GE 6 hour defrost timer to get this model to defrost completely.
It's also possible that the refrigerant charge is slightly low, causing the defrost thermostat not to reach a cold enough temperature to perform a good defrost cycle. (building ice over a long period of time).
Make sure Freon 12 was used when replacing the compressor.
Some substitutes caused the evaporator coil to act as if it was
slightly low on charge.
Nov 08, 2009 | Westinghouse Refrigerators
GE side by side freezer not working - ice buildup
check the defrost timmer if it is working you need a defrost heater you can manually turn the defrost timmer to check the heater the timmer turns off the compressor and on the heater 2 or 3 times a day the timmer is a box with a round knob sticking out of it turn the knob tell it clicks look under the front for it or in the back most refrigerators have a wiring diagram on the back or by the compressor
Oct 20, 2009 | GE Refrigerators
Model tfh22prsa GE Side-by-side freezer ok refrigerator warm
There are 3 things to look for on the TFH22PRSAAA refrigerator when this happens. First we need to have a look inside the rear of the freezer and see is there is frost build up on the rear back panel that covers the evaporator. If yes you the next thing to do is look inside the fresh food compartment for the defrost timer located behind the control panel as shown in the photo below. I want you to turn the defrost timer clockwise until the compressor motor and fans stop. The refrigerator should be in the defrost mode now. Open the freezer door and listen for crackling and sizzling cause by the defrost heater being on. If there is no sounds or changes the you need to let me know. The timer should turn the refrigerator back on after 25 minutes. If not simply turn the timer again slowly clockwise until the compressor restarts. If you need to do this you will need to replace the defrost timer because the timer is no longer running as a timer and has become defective. I am going to stop here because I don't want you to think this is too hard to do It's easy to do these test and I will be here to assist you. Let me know when you are ready or if you fell you have it under control please rate my solution when were finished the repair, Thanks, Sea Breeze
Aug 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side. The freezer will freeze up with
Replace the defrost heater, located at the bottom of the cooling coils, behind the back wall of the freezer.
Aug 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side GSS20IEP Refrigerator freezer freezing
this is a problem that is no stranger to most GE side by sides; GE has used a glass type defrost heater in the freezer which often fails. If you manually defrost your appliance (unplug and leave doors open for 24 hrs) then plug back in, it will appear to work normally for a few days and gradually build up frost on the evap panel (back panel in the freezer) and eventually the refrigerator side will seem to loose cooling due to frosted damper, or lack of cold air transfer over the evap coil. The fix for this is to replace the defrost heaters (s). While not as common, defrost thermostats can open causing the unit to skip defrost, and even less likely is the defrost control (either mechanical timer or adaptive defrost). First, defrost your appliance, then remove the evap panel and ohm out the heater(s), if open, replace. If they check ok, check your defrost thermostat (small disc like object attached by a clip on the evap. coil itself) for signs of popping open or open ohm readings at normally closed temperatures. Its a good idea to change this anyway when replacing defrost heaters as the two work hand in hand. Last, check the defrost timer by manually advancing the screw advance clockwise until you hear the first click, then check voltage to the defrost heater and thermostat, if no voltage present replace timer. If your appliance is equipped with a adaptive defrost board, refer to the schematic for proper diagnostics.
Jun 11, 2009 | GE GSS20IEP Side by Side Refrigerator
Fridge stopped working
Sounds as if the unit is stuck in defrost. How old is it? Look for mechanical {twist} timer and turn it until it starts. If it is a newer model unplug unit for 1 minute this might reset control board but you'll have to know if it is either mechanical or Automatic defrost!!
May 27, 2009 | GE GSH25KGRWW Side by Side Refrigerator
GE Profile side by side freezer not working at all. Fridge ok.
Is the fridge side working? If not try turning the defrost timer dial until it clicks. If it now goes you need to test the defrost circuit as there's still a fault but it'll go for 12 hours untill it trys to do another D'frost. If this doesn't work try bypassing the thermostat. cheers
May 15, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE side by side refrigerator has totally stopped working.
Look inside the unit and make sure the thermostat hasn't been accidentally bumped or turned.
You could also have a stuck or malfunctioning defrost timer. This device, usually located at the bottom of the unit, sometimes accessible from the front, interrupts the compressor operation and initiates a defrost cycle in the freezer section (using electric heating elements). It is basically a timer. Sometimes they stick or stop working. If you can reach it, you may be able to rotate the dial clockwise with a screwdriver and get the refrigerator working for the time being. However, you should replace it if this is the cause.
Mar 28, 2009 | GE Refrigerators
Refrigerators Logo
46 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
