Question about Linksys WRT120N Router
Can not access the browse button for firmware upgrade for Linksys wrt120n router
When connected only with WAN,
Enable the remote update option under managment.
Posted on Jul 31, 2012
  • 9 Answers
SOURCE: I Upgraded RV042 to latest firmware from Linksys Site and now Router Continually reboots
i think there might have been some sort of virus(spyware, adware, trojan)
Posted on Dec 30, 2007
SOURCE: How to Upgrade the Firmware on a Linksys Router
I have update the fireware of linksys router WRT54G ver.2.2 by wireless.. Wrong move.. Then it stop loading.. now I can not get in to the router even i reset the router.. what can i do to have it back..
Posted on May 10, 2008
  • 252 Answers
SOURCE: How to configure Huwaei MT880 with linksys WRT120N router?
Try these steps:
  1. Shut down the DSL/Cable modem
  1. Power up the router (no cables just yet).
  1. Power up the modem and wait for the appropriate lights (power, ethernet, and activity – something along these lines)
  1. Connect the modem and router with an ethernet cable (if there is a WAN port on the router make sure to put the cable in this port).
  1. Connect Port 1 on the router to the network card on the computer using an ethernet cable and check to see there is a light at the correct port.
  1. Open a web browser, such as Internet Explorer or Firefox. Input your routers id (usually an IP address or an URL) in the browsers address bar and press Enter. The address bar is where you would normally see, for example, http://www.google.ca If you don't know the IP address (such as 192.168.1.1) or the URL, try going to the manufacturers web site and downloading a manual.
  1. Now, a window will open asking for a user name and password (these are given to you in the instructions of the router). For example, Dlink sets up some of their routers as, username: admin and leave the password field blank then press OK.
  1. Now you are in the configuration page of your router (wireless most probably). Here you can set the encryption, new passwords etc… If your not comfortable doing these on your own most routers have a wizard that you can follow.
  1. If everything goes alright and the settings are successful you can now try the wireless connection. Go to a machine with a wireless card, right
  1. At the computer with the wireless connection, make sure the connection is on You might be trying to connect to the network by using either the application that came with the router or windows wireless configuration. Right click the icon in the system tray and “view available networks”. If it comes up in a window saying “Windows is not setup for wireless networks” then you must right click on the correct icon in the tray.
  2. Now, in the list of available networks, click on the name of your network Click on "connect" and it should ask for your security id (the encryption code). Put in the code (usually twice) and click connect or OK. It should now be "acquiring anip address" and in a few minutes it should be connected.
Posted on Nov 07, 2009
  • 345 Answers
SOURCE: WRT120N doesn;t permit VPN accesses
Most times when VPN is not working is because one of the ports is not forwarding right. Easy fix is to go to router settings and enable DMZ for your computers IP address. Also you can actually find out what are the ports this VPN uses and go to Port Forwarding part of router and open the ports manually. My favorite is DMZ. All this does is open up ports for your computer IP address so there is no blocked pockets. Good luck.
Posted on Jan 12, 2010
govinda123
  • 2260 Answers
SOURCE: unable to connect to the internet with my linksys
If you connect the computer directly to the AT&T modem , it work. That means the modem is working properly.
AT&T is DSL connection type. the DSL connection works on 2 different modes. 1) DHCP 2) PPPOE.
Now you will need to connect the modem and the computer to the router. open the set up page of the rotuer.
The set up page is the page where you can change the settings of the router.
According to the type of internet connection you can change the settings of the router
Click Here for step by step by instructions
Posted on Feb 16, 2010
My wrt120n was hacked. login password was changed and i cannot login into the conf webpages. I do have physical access to the router. I tried to do the following after some search on the internet 1....
Please reset the router by pressing the reset button while your router should be plugged in to the power cable.
While reseting the router the lights on the router should be blinking for 30 seconds.
Try this this should work.
Apr 28, 2013 | Linksys WRT120N Wireless Router
I cannot open wrt120n firmware...what program will open it so I can save it?
In the Administration area of the router, you have the option to do a Firmware Upgrade. Once there, you can browse to the firmware file you'd downloaded earlier. No need to use any program other than the smarts within the router itself. DON'T do anything while the router is upgrading firmware!
Oct 28, 2012 | Cisco Linksys Wireless N Home Router...
Trying to configure my Linksys WRT120N router, but when I click 'Save Settings' I get an error message (324). What's wrong?
I think you can try upgrading the firmware on your router,
Connect the computer to the router.
Download the latest firmware.
Open the setup page of the router and upgrade the firmware.
After upgrading the firmware, reset the router and reconfigure it manually.
See How to upgrade firmware on Linksys router.
Watch video: Linksys router setup
Mar 27, 2012 | Linksys WRT120N Router
I can't connect to the internet w/ my new laptop. I can't find my security key to hook up.
This article documents a known issue with resetting a Linksys WRT120N to its factory default settings.
Symptom: Holding down the reset button on the back of the router does not reset the settings.
1) Download the latest firmware from Linksys (link below).
http://homesupport.cisco.com/en-us/wireless/lbc/WRT120N
2) Unplug the router, hold the reset button, and plug in the router while still holding the reset button.
3) Open Internet Explorer, go to http://192.168.1.1
4) Use the "Browse" button to locate the firmware file downloaded from Linksys.
5) Once the update is complete, unplug the router and plug it back in.
6) Hold the reset button on the back of the router for about 30 seconds, a light will indicate when it resets.
7) Allow the router to reset for 1-2 minutes.
8) Open Internet Explorer, go to http://192.168.1.1
9) Enter "admin" for the username and "admin" for the password (without quotes).
Your router should now be reset to the factory defaults!
Nov 04, 2011 | Linksys WRT120N Router
How do I reset my router password
Here is the step-by-step instruction to reset Linksys WRT120N Router
  • First af all you have to make sure the power is "On" . Power the router up while pressing the reset button located at the back of the router using pencil or paperclip
  • After around 30 seconds you will be prompted with the boot loader. Connect the boot loader using the standard IP address if you have not changed it (http://192.168.1.1)
  • Upgrade the firmware to the latest one from Cisco site
  • Power cycle the router and allow it to come up.
  • When it is fully up, press and hold the reset button for 5 secondsThe LED light will blink indicating that you're done holding the reset bottom. If the Power LED won't blink try to press and hold the Reset Button for I minute and then power cycle the router for another 1 minute.
  • Power cycle the device and now you have reset your linksys WRT120N router See the following link if you forgot to setup linksys router
(http://infoteknotainment.com/reset-linksys-wrt120n-router)
May 24, 2011 | Linksys WRT120N Router
WRT120N no .bin or .img file in firmware update download
Hi Friend
in order to upgrade the firmware please follow the steps:
1. Click the link (http://homesupport.cisco.com/en-us/wireless/linksys/)
2. Enter the model number of the router and hit enter.
3.Click Download Tab
4.Now enter the hardware version of the router (which you can find by turning the router upside down)
5.Now you can download the firmware which is a .bin file and save it to the desktop.
6.Open the router page and click Administration and click Firmware upgrade.
7.Select the file from the desktop by clicking Browse and start upgrade.
8.Turn off the router for 30 seconds after upgradation and turn it on..
i hope this will resolve the issue.
Regards
Chiranjeet
May 21, 2010 | Linksys WRT120N Router
Set up wizard,didn't work. Disconnected all and set it up with ethernet cable to laptop and did the online setup and works for a while wireless then says connected but no internet access, somethintg about...
This router has issues with the wireless connections.
It is recommended that you will upgrade the firmware of the router.
Once you upgrade the firmware of the router, reset the router for 30 seconds. wait for 1 minute and then reconfigure the router.
WRT120N router has issues with the firmware.
Click Here for step by step instructions
Mar 08, 2010 | Linksys WRT120N Router
My linksys wrt120n will not reconize the road runner modem when the ethernet cable is hooked up to it
This router has lot of issues with the firmware. Firmware is the software of the router. First thing you need to do is upgrade the firmware of the router.
If you connect your computer directly to the modem it will go online. Download the firmware of the router from the web site www.linksys.com/download .
Now connect the computer and the modem to the router. open the router set up page. upgrade the firmware. After upgrading the firmware, reset the router for 30 seconds . Unplug the power and plug it back in. wait for 1 minute and reconfigure the router.
Click here for more information about the router and router set up
Feb 22, 2010 | Linksys WRT120N Router
Feb 16, 2006 | Linksys BEFSX41 Router (DHBEFSX41)
Charter High-Speed Cable and the BEFW11S4 Version 4
To resolve this problem, you will need to upgrade your router's firmware. Click ftp://ftp.linksys.com/pub/network/befw11s4_v4_v1.50.14_code.bin and download the file to your Desktop or My Documents folder (the link is to v1.50.14 firmware code). Once the BIN file has been downloaded, follow these instructions to upgrade the router's firmware: NOTE: Before upgrading your router's firmware, please make sure that the procedure is being performed by a computer that is connected directly to the Router with an Ethernet cable and not a wirelessly connected computer. Accessing the Router's Setup Page 1. Open a web browser such as Internet Explorer or Netscape. 2. When the browser window opens, go to the Address bar and type in the router's IP Address and click on the Go button (192.168.1.1 is the default IP address of Linksys Routers). 3. A window will appear prompting for a ?User Name? and a ?Password?. Leave the ?User Name? field blank, and type in the router's password and click on the OK button to login (admin is the default password). 4. The router's web-based ?Setup? utility should then load. Upgrading the Router From the router?s ?Setup? page, locate the Linksys logo in the upper left-hand corner of the page. Follow the instructions below depending on which logo matches your specific screen: If the logo matches the image above ("Linksys - A Division of Cisco Systems, Inc."), follow these steps. If not, skip to the next logo version. 1. Click on the Administration tab. 2. When the ?Administration? page loads, click on the Firmware Upgrade sub-tab. 3. When the ?Upgrade Firmware? page loads, click on the Browse button, and browse to the location where the firmware file was downloaded (and possibly extracted) to. 4. After browsing to the correct location, select the firmware file and click on the OK button. 5. Click on the Upgrade button to upgrade the router's firmware. If the logo matches the image above ("Linksys"), follow these steps: 1. Click on the Help tab. 2. When the "Help" page loads, click on the Upgrade Firmware link. 3. When the ?Upgrade Firmware? page loads, click on the Browse button, and browse to the location where the firmware file was downloaded (and possibly extracted) to. 4. After browsing to the correct location, select the firmware file and click on the OK button. 5. Click on the Upgrade button to upgrade the router's firmware. After completing the steps above, the router's firmware should be upgraded successfully.
Feb 16, 2006 | Linksys BEFW11S4 802.11b Wireless...
Linksys WRT120N Router Logo
47 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
