Question about Honda Garden
I have a Honda xr2600 power washer. When I tried using it, water was squirting from the top of the gun. I took it apart to find that there are o-rings on top of some kind of washer---looks like a lock washer but it's made of cardboard??? Two of these washers were broken. I can get the o-rings but I can't seem to find the washers. I tried getting the manual for this model on line with no luck. Any assistance will be greatly appreciated.
    President:
  • Honda Master
  • 1,388 Answers
The washers that you describe are made of teflon and are split to facilitate installation and/or allow expansion as they wear. These washers are actually seals and at times are used together with orings to seal high pressure. You should be able to replace washers with teflon tape available at most auto parts or Lumber center and examine orings carefully with magnify glass looking for cuts or rough edges. I believe that most guns were designed to be replaced instead of rebuilt because when water starts leaking, the metal parts of the gun where seals are used get cut similar to water faucet seat. When this happens, the seals will not work. Good luck
Posted on Sep 03, 2010
I have a Honda 5 hp XR2600 presser washer, I have trouble keeping it running without the choke on. It starts right up, but it need the choke on to keep running.
I would try empting the gas out of the tank just to make sure you don't have some water in the gas. If that doesn't help you have a carburator that needs to be cleaned or maybe rebuilt.
Sep 30, 2013 | Garden
I have a weekender h1610 power washer i took the spray gun apart and cannot remember where this little spring goes
email me pictures of the spring and the part that it came from and i will try to help u ,,, mcelhannonelvis@hotmail.com
Aug 30, 2012 | Garden
I bought a honda pressure washer power boss 3000. I load the gasoline, start the machine, but pressure water is not coming out from the trigger. i tried so many things , but can t get started.
If you are using a water tank for water supply, remove the water supply line from the pressure washer and connect a water hose from a faucet. Turn the water on, then crank the engine. Pull the trigger of the spray gun until water comes out. When then water starts to spray properly the release the trigger, shut engine down with pressure on the line then reconnect the water supply from the tank to the pressure washer. If this fixes the problem then the problem was "air-locked"! Happens alot with new pressure washers that have never been run. If you need any other help, please email me @ davidandlisacampbell@yahoo.com
Feb 18, 2011 | Honda Pressure Washer PSI 3000
Xr2600 excell pressure washer I was using it and it lost water pressure does not have any pressure. the engine runs fine just don't know what the problem is.
I have the same problem and it seems the piston in the back has a ring and the ring is broken i half i'm talking it to get fixed tomorrow i will keep you informed.
Aug 16, 2010 | Honda Garden
The water pump
Any possibility the unit froze this past winter? They do have to be winterized.
May 05, 2010 | Honda Karcher G2400HH-R Pressure Washer
MY HONDA POWER WASHER
Nozzle is dirty. Use small diameter wire to clean out nozzle.
Sep 09, 2009 | Honda Pressure Washer PSI 3000
Garden Logo
336 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
