Question about Vacuums
Please help, need to thread a Jones 641 sewing machine - can you help please? Thanks Jane
SOURCE: With my K6 Industrial Singer
Hello there, loosen your top thread tension,if it looping on top of the material the tension is way too tight, you will also find changing the thread size to smaller thread, the top tension will also reduce,depending on application a good size thread to use is 25 grade,bobbin tension should have just a slight amount of drag as the top thread and bottom work against each other when sewing.
regards
Tony
Posted on Feb 03, 2009
HansPP
  • 2510 Answers
SOURCE: I had a toyota rs2000
Try this site:-
ewingonline.co.uk/instructions/toyotars2000
Posted on Jan 28, 2011
SOURCE: i have the brother Ls-2000
adjust your tension.You probably did not wind your bobbin properly as well.Make sure you oil your machine every month or so and make sure your bobbin is seated properly before you sew.
Go slower with the pressure foot speed and use the right needle.ALWAYS test on scrap of your sewing material first!!!
I have this machine for like 2 years and can do 2-5oz cowhide and buffalo leather on it (no joke, and it works FLAWLESSLY) inside it has full steel construction,just needs regular oiling compared to pro machines and easily made a few grand $$$ with it while my pro machine is getting repaired (I don't even bother with my pro machine anymore) But you MUST oil it every month and use the RIGHT needle and adjust your tension properly
Also pull out the thread a good 6 inches from the needle and bobbin before dropping the pressure foot and sewing.
Best $70 bucks (WITH TAX) I spent hell,the leather I use costs more than the machine!
Posted on Feb 07, 2011
SOURCE: received stitch'n time sewing machine
If you email me I will scan the manual, and email it to you.
quintas3@hotmail.com
Posted on Jul 12, 2011
  • 244 Answers
SOURCE: In my Singer Sewing Machine
There could be several things causing this.
First, be sure the bobbin is in the bobbin case correctly. There is usually a line diagram showing the correct placement or you can check the owner's manual.
Second, make sure your needle is inserted correctly. If it is not completely set in the housing, this can prevent the bobbin thread from being caught by the hook. The groove in the needle should be ffacing toward you to assure that the thread interacts with the hook.
Third, be certain the upper threading is correct...passing through all thread guides and correctly through tension and take up lever.
Finally, make sure the bobbin case is free of lint. The machine brush that came with the machine will clean this area well.
I hope one of these suggestions helps you solve your problem. If so, please come back to Fixya and rate my advice!
Posted on Jul 24, 2011
In my Singer Sewing Machine model 1014 the Needle Won't Pick Up Bobbin Thread. Could you please help. Thanks
Jul 24, 2011 | Vacuums
How to get Brother sewing machine apart to replace spool spindle.
To be honest the best thingon such instructions is the manual which is provided along with the machines,but many people don't have it , probably because they have lost the manual orthey have got the machine as a used one and forgot to take the manual alongwith it.
Please follow the belowinstructions :-
Close to the end of theHandwheel , there is usually a spindle, at the back of the machine.
This is where you need to restthe spool on and you would notice it sitting perfectly.
In case the length of the spindleis less , then pull it up gently with your fingers.
Also there are machines these dayswhich have easy to replace facilities , so the spindles just slide intothe machine for safety norms when you put the machine away.
Therefore , all you need to do it pullit up and it would be fine.
An example of a manual forbrother's sewing machine can be found in the below link which would give you anidea of how exactly it's done.
http://bit.ly/j2BdsP
Hope this helps ..:)
Jun 11, 2011 | Vacuums
Looking for manual for jones buttonmagic vx591s
This sounds like a Sewing Machine problem?
Perhaps we don't have an easier to see slot for this problem?
It is ending up under 'Vacuums'-- and I wonder how many of us in Vacuum's know much about sewing machines?
Please try re-listing your problem-- and let me know if you can (or can not!) find a better department to report your sewing machine problem in?
Mack B
Jan 27, 2011 | Vacuums
I have the brother Ls-2000 sewing machine i threaded the top as well as the bobbin but when i try to sew the thread gets stuck and it bunches up and tangles in the bobbin. also the little bit that did sew...
Jan 12, 2011 | Vacuums
Kenmore YM-40-35 R Sewing Machine Manual (or copy) wanted. If a manual is not available, I'd be OK with instructions for threading the needle and bobbin and any additional details that an expert may...
Please go through the below document which will give you the help you wanted:
http://www.ehow.com/how_4798790_thread-bobbin-kenmore-sewing-machine.html
http://www.ehow.com/how_5839_thread-sewing-machine.html
http://www.youtube.com/watch?v=1j8e8FvwUlQ
You will also find additional information on every page at the left hand side (Ehow.com) and on the right hand side(Youtube).
Please let me know if you need any additional information or have any information that you would like to share with me.
Jun 10, 2010 | Vacuums
While using the pin stitch , the machine has started skipping stitches, knocking loudly, the top thread is breaking, sometimes thread knots up on the underneath side. I have cleaned bobbin area, changed...
Please go through the link given bellow to have the resolution to your problem...
http://sewing.about.com/od/sewingmachineindex/a/mtroubleshot.htm
Let us know if you want something else please accept the solution.
Thank You for contacting fixya.com
Apr 27, 2010 | Vacuums
With my K6 Industrial Singer sewing machine the top thread seems to be too tight. The bottom thread is looping too much on the top of the fabric. The timming is ok. I have checked and rechecked that I have...
regards
Tony
Apr 04, 2008 | Singer Vacuums
Vacuums Logo
290 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
