Question about Kenmore Dishwashers
I have a model 665.15831791 When it fills with water it does not go into a cycle, it automatically discharges the water
    President:
  • 1,197 Answers
It could be two things causing such problem: no power to the wash pump motor or the motor itself is bad. Remove the wire plug from the motor and check for the 120V when the timer is on wash cycle. If there is no power then check the wires and the plug at the timer. If this is not an issue replace the timer.
If there is a proper power to the motor then the problem with your dishwasher is a bad wash pump motor. If your dishwasher is less then 5 years old then it could be under limited manufacturer warranty. Call kenmore with the model and the serial numbers and they will tell you. If the dishwasher is more then 5 years old I do not recommend you to repair it yourself. I've seen many times when it's not possible to install the pump back after repair because the plastic tub got warped.
here is the link to the schematic diagrams for your dishwasher ... you can also order for timer and other parts if need be from the same link as well
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dishwasher-Parts/Model-665.15831791/0582/0130000?pathTaken=
Posted on Sep 03, 2010
  • SAM JAYANTH CHANDRASEKAR
    If you do find my solutions helpful .. please dont forget to rate the Solution. they are our encouragement to Serve you folks better.
My hoover 500mb 5.0kg washing machine fills up fine at start of cycle then just washes for a bit then just stats to fill up and wont stop till I stop it
I had a similar problem and not sure whether my solution would help you.It was to do with the position of the waste pipe.It should raised about 2ft. ,looped before discharged into the washing machine tee.when the discharge hose is lying on the floor there's a possibility that the water is filling up and going straight out.By raising it you are letting it fill up and presumably triggering the water level sensor.Hope this helps.
May 29, 2017 | Hoover Washing Machines
I have a top loading Kenmore Washing Machine. I don´t have the excat model but looks like a KENMORE HEAVY DUTY SERIES 70 AUTOMATIC WASHER, MODEL # 110.92273100. The problem presents after finishing...
You may have 2 defective parts.
First,make sure the hot and cold water hoses are connected correctly and both turned on.
If the water fill problem is the same,the water temp switch is bad.
The not filling after the wash cycle could be a bad lid switch.
Set the machine for SPIN and turn it on.
If it does not spin,replace the lid switch.
Sep 20, 2010 | Kenmore 24042 Top Load Washer
Filling and running for 2 mins, discharging all the water then signalling that the cycle is complete Model is ADG 7460
This sounds like the heater is faulty. Try running the dishwasher on a rinse cycle- if this cycle completes as normal then this would prove that the heater has gone. If not please get back to me
Jun 12, 2010 | Whirlpool Dishwashers
Our Kenmore Model 110 - 82980120, Stock 29801, 118 G is giving a problem with the Automatic Process. It does not move by itself. It stays at the same place it is kept. If Kept at Wash it stays there, if...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Jan 21, 2010 | Kenmore Washing Machines
Wash cycle and spin
you need to check a simple button called " no spin" may you will see it marked "aspiral shap" and has "x" over
good work !
Jul 05, 2009 | Zanussi ZWF1430W Front Load Washer
Washer will not discharge water after wash or rinse cycle
Pump failure. Unit probably has something stuck in pump....the washer eats the socks not the dryer. suggest shope vac to get water out, and then remove hose from pump and check to see if its clear.
Jun 08, 2009 | Kenmore Washing Machines
I have a GE roll around dishwasher, Model GSC3200Z03BL. It worked one night, did not work the next. After hooking intake/discharge hose to faucet and turning to start, no water is pumped in. Only a...
First off.. the pump does not let water in.. it takes water from your sink faucette via the hose and allows it to enter the DW via an inlet electrically operated valve. If that valve is not commanded by the control system to open, then no water will enter the DW and a wash cycle will not start. Please find the informaton shown below that decribes some reasons why your DW may not be filling with water. You should go thru this series of checks to make sure you've set up the DW correctly aqnd it is not in mid cycle.If by chance you are setting it up correctly and are not in mid cycle then you may have a hardware problem with the system. I would be happy to assist you if it comes to that but I am hoping that the information below will get you started,...
Copied directly from the GE website for your refererence..
Dishwasher - No Water Fill
Often the cause of a dishwasher not filling at the start of its cycle is not electrical or mechanical. Often times you may be starting your dishwasher model incorrectly which results in the machine skipping its first water fill period.
There are presently three different types of starting procedures being used:
  1. Pushbutton type. This system is found on all POTSCRUBBER models.
  2. "Turn-to-start" timer type. After latching the dishwasher door, you turn the timer dial until you hear a click. By advancing the timer dial beyond that point, its possible that the first water fill would be skipped. The first fill is necessary for automatic pre-rinsing of the dishes.
    View a short video about turn-to-start timers:
    Play Video
  3. The most common type is a "push-to-start" timer dial. All that is required to initiate the cycle is to push in on the timer dial. It is NOT necessary to turn the dial.
If you are unsure as to the starting procedure used by your model please consult the Owner's Manual. Download a free copy of the Owner's Manual and/or Installation Instructions.
Here is a link to the website too.. http://www.geappliances.com/search/fast/infobase/10001005.htm
Hope this gets you going..
Sep 02, 2008 | GE Dishwashers
Maytag Neptune filling with water
Is this happening after it has not been used for a while. If so you have a fill valve slowly bleeding some water in. Almost like a dripping faucet. The only way to fix it is to replace the valve. If you want to check it turn the breaker off to the unit when not in use to see if if still fills up. If so you know it would have to be the valve.
Apr 18, 2008 | Washing Machines
Dishwashers Logo
163 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
