Question about Vizio L32 32 in. LCD HDTV
My Vizio suddenly has white dots going diagonaly across the picture, don't know how to get them off. It's only a few years old.
3 Suggested Answers
roety
  • 585 Answers
SOURCE: White dots in plasma tv
The only thing you can try is to adjust the tiny control on the Y board, if you want to try do this. Open the set , set it up so you can watch it with the back off. now looking at the back on the left side you will see a circuit board larger connected to a smalled one or two that go to the screen edge . on the larger board look for a few small controls, mark their positions with a dark sharpy then turn each a little while looking at the dots to see if one makes them better or worse. If one control effects the dots try to center it for the least amount of dots, if no effect is observed when a control is turned return it the original position that you mark before starting. if the dots do not clear either the Y board is bad or the whole scfreen is defective.
gd lk
Eric
Posted on Aug 15, 2009
milkburp
  • 416 Answers
SOURCE: Vizio 42 in TV LCD HDTV white line across to of
That white line (usually jagged) is actuallly part of the transmitted picture. However, you are not intended to see it because it is located in what is known as the 5% overscan area. Your TVs today are more than just cable ready... they are a versital, technology filled multimedia display. You can see that line because the screen size or wide mode you are using is intended for 1080p/24 signals. You have 0% overscan with this screen size setting. This allows you to see ALL of the picture, including portions of the picture the broadcaster did not intend for you to see. You can change your screen size using the Wide feature in the Setup menu. See pg.62 of your user manual for details and descriptions of the various wide modes.
Posted on Mar 14, 2010
Vizio M420kd vertical thin white line on left of screen pictures have lots of green ghosting
If you've ruled out that the source you're displaying from is good, I would contact vizio for a warranty repair
Jan 24, 2014 | Vizio Televison & Video
My Vizio picture was great. All of a sudden the screen started flickering. I was able to change the channel but it was still flickering. I shut off the directv receiver and the problem was still there. ...
The tv buffer boards for the tv backlight,the X or Y buffer boards it is dead or dying.Take it to the tv shop,for a propper diagnoise and price estamate to changes the wright tv buffer board.
May 08, 2011 | Vizio P50HDTV20A 50 in. Plasma HDTV
White dots all over the screen
White dots are due to bad DMD chip and qualified tv tech can replace required DMD chip in this tv to fix the picture issue.
Please contact nearest Samsung service center or local tv repair shop for repair estimate.
Thanks.
May 16, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
Screen flashing ribbons of color over picture
i think its your cable box. check it carefully.
May 25, 2009 | Vizio VA26L 26 in. LCD HDTV
My Vizio L37 keeps turning off!
change the main board will fix this problem
May 16, 2009 | Vizio L37 Television
Xbox
if its less than a year old phone Microsoft customer support.
if not it could be early signs of 3 red lights
Jan 17, 2009 | Microsoft Halo 3 for Xbox 360
Vizio plasma hd 42
Sounds like you hit the PIP (picture in picture) button on the remote. Hit it a few more times and it should go away.
Jun 16, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio P42 Plasma HDTV10A
THE CABLE INPUT IS SERVED ON 22" VIZIO HOW AND WERE CAN I GO TO FIX THIS PROBLEM IN ATLANTA
May 19, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Sudden color/picture distortion
you have a shorted green CRT that is affecting the other crts the short is internat to the crt that leaves what is called retrace lines. if the set is more than three years old then replace all three guns.
Feb 25, 2008 | Samsung TX-R3080WH 30" TV
Vizio L32 32 in. LCD HDTV Logo
259 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
