Question about Samsung Cell Phones
I want to knw how could i block my number while calling to any other number
How to block numbers
To block calls, open the Phone app, select Call History, tap the number, then select Block Contact or BlockCaller. To block calls, open the Phone app, select Menu > Settings > Call Reject > Reject Calls From and add numbers. To block calls for numbers that have called you, go to the Phone app and open the Log.26 Sep 2016
How to Block a Number on Any Phone ' PCMag.com..
or go to this link for other phones. How to block numbers Google Search
Oct 28, 2017 | Cell Phones
My sim card is blocked an i dnt knw the puk code.the number is 8484311
so Mr. johnoy please contact your sim card provider..they will give u the PUK code...........
Nov 04, 2012 | Cell Phones
PUK code ,pls help me is an idea network & my num 9743530248 ,i dnt knw my sim card number
y dear:
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
But:
Don't try to enter a PUK code without knowing the right one.
You need to call your service provider to get this code.
It can be as many as 8 digits, and it is random. If you enter too many wrong codes,
you can permanently damage the device. So Please You Go to Service office
and Get the Duplicate Sim From Office Oprater Same Your No Problem will Solved
Jul 31, 2012 | LG Cell Phones
The shaft will not go all the way into the flywheel
you know what the year is of the car you need the motor for and whoever you got the motor from should know what year the car it came out of.on these they are interchangable from year to year until you get into i think about 2001.or you can get the engine number off the block and call a wrecker to find out what year it is.
Nov 12, 2011 | 1998 Chevrolet Lumina
Dnt knw my puk code to unblock my phone
The only way to get your PUK number is to call Net10 customer service. Their number is 1-877-836-2368. Just request the code from the agent.
Good luck!!
EJ Kudelka
Sep 07, 2011 | Motorola Mobility NET10 Cellular Phone
No manual and am receiving unwanted calls at night just became threatening how do i block them
Using Call Block
If you subscribe to Caller ID, you can save phone numbers to the call block list. When a call comes in, the phone compares the received phone number to the numbers on the call block list. If the phone number is on the list, the phone replaces the caller's name with Call Blocked and disconnects the call. (The caller hears a reject tone.)
The call block list holds 20 entries, and all stations share the same list. You can add entries through the Call Blocking menu, by selecting Add Call Block in the CID menu, or by blocking incoming calls. (Only one station can edit the call block list at a time.)
Blocking incoming calls
  1. When the phone rings, wait until the display shows the Caller ID information (usually after the second ring).
  2. If you want to block the call and add this number to the call block list, press Block.
  3. When the phone asks you to confirm, press Menu/select or Block. Blocking an incoming call from an "Unknown" or "Private" number is the same as selecting Unknown Number or Private Number from the Call Blocking menu.
Call Blocking menu options
  1. With the phone in standby, open the menu and select Call Blocking.
  2. Choose one of these options:
  • Create New(Handset only) - Add an entry to your call block list. The phone will prompt you to enter a name & phone number.
  • Private Number(Handset only) - Block all calls from numbers reported by CID as "Private." (This does not count as one of the 20 entries.)
  • Unknown Number(Handset only) - Block all calls from numbers reported by CID as "Unknown". (This does not count as one of the 20 entries.)
Call block entry options
  1. With the phone in standby, open the call block list and find the entry you want.
  2. Press Menu/select to open the individual entry menu. Choose one of these options:
  • Edit(Handset only) - Edit this entry. The phone will prompt you to edit the name & phone number.
  • Delete - Erase this entry from the list & allow calls from this number.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Mar 20, 2011 | Uniden DECT21883 Trio Cordless Phone
Www.mbiz-support.com
Samsung games with code
Feb 03, 2011 | BMW 750 Cars & Trucks
My phone is blocked and i do not knw my puk code however i can not do anything on my phone and i really need to unblock it right nowplease
Check your SIM pack to get your PUK code, if not try contacting your Service provider for the PUK code.
Best regards
May 08, 2010 | Cell Phones
What is message center name in philippines for my nokia 5800?
check in messages option u can see the service center number. u also need to knw the network provider. call the customer service and they can give u also.
Feb 06, 2010 | Nokia 5800 XpressMusic Smartphone
I have a blackberry curve 8900! And the problem is that when i miss a call it only showa the number of calls missed but it doesn't show who or the number
the problem is that the contact no which gives u misscall is registered twice in ur cell so the name of the contact person does not appear and for dat reason it shows the number thats it jst check ur contacts first and u will come to knw the no registered twice
Jan 13, 2010 | Cell Phones
Cell Phones Logo
14 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
