Question about D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE)
I need to know where to type in the ip address to configure my airplus extreme g router by dlink to get to the part where I put in the userer name Admin?
    President:
  • 1,851 Answers
Open an Internet Explorer and at the adress bar (where you can see the internet url) type the ip address of the router without http://www before it, just the numbers separated by the dot. When you finish typing hit enter. Now there must be a window to type admin and password.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Sep 03, 2010
Does the d-link airplus xtreme g model DI-624 support WPS?
yes there is RESET or WPS button for RESET all settings to factory defaults. For that press RESET/WPS button for 1 seconds it is in the back side of router. Then all settings defaults . You need to configure your router with below method. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. Then set WAN settings as internet service provider settings enable DHCP. .Click on wireless and enabled it. Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Mar 03, 2011 | D-Link AirPlus Xtreme G DI-624 Wireless...
I need to reset the Admin settings on my wireless router.
Press and hold the reset button on the back of the router for 15 seconds and it will load everything back to default.
Dec 31, 2010 | D-Link AirPlus G DWL-G730AP Wireless...
Unable to set , even type the password
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi Then save settings and restart router Then connect cable from internet service provider to WAN port of router and connect ethenet lan cable from computer to lan port of router. . Let me know if you need further assistance. Thanks for using FixYa.
Nov 14, 2010 | D-Link AirPlus DI-524 Wireless Router
I DO NOT HAVE A CD FOR MY dlink 628
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi . Let me know if you need further assistance. Thanks for using FixYa.
Oct 13, 2010 | D-Link DIR-625 (790069292637) Wireless...
How do i put a password on so others can use my internet
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then Click on wireless ->wireless security then enter WEP code then save settings and restart router.It is your password to connect wifi.. Let me know if you need further assistance. Thanks for using FixYa.
Sep 30, 2010 | D-Link AirPlus DI-524 Wireless Router
Where do I type in the ip address to get to the configuration for my dlink air plus extreme router after I connect the computer to the router and resest the router by hold it in for 10 seconds?
hi, start your internet as you would be trying to connect, in the top search bar type as follows
http://192.682.1.1 or 192.168.0.1 normally the user name will be : admin and normally the password would be : password you may have a different ip address than the 2 i have given as an example, it normally says on the label under the router itself what this will be r with the cd that came with it...hope this helps please vote and rate thanks
Sep 03, 2010 | D-Link Computers & Internet
Hard drive crashed lost my dlink disc how would i put my dlink router on my new computer
You need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Clickon wireless settings enable wireless then enable WEP Security then add WEP code .It isyour password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Jan 13, 2010 | D-Link High-Speed 802.11g Wireless PCI...
Want to know the pre shared key
If you don't know your pre shared key or forgotten it. You need to access the configuration page of your router and create a new network name and a sign a new network key or pre shared key. Create the profile of your SSID/Wireless network connetion under wireless settings.
Jan 17, 2009 | D-Link AirPlus DI-524 Wireless Router
I cannot connect to my router via the IP in the browser
Check first the cables and connections, and the broadband filter.
You need to connect through cable to configure the router.
To access the router panel you need to input the router IP address on Internet explorer bar.
default IP is http://192.168.0.1
If IP is not default, you find out IP by opening the command prompt from start menu>>all programs>>accessories>>system tools (that kind of dos mode). On command prompt type ipconfig/all.
The default gateway is router IP.
On the router access panel default settings are :
User Admin
Password leave blank
See all procedures on manual below.
Copy and paste the address below on your browser address bar.
ftp://ftp.dlink.co.uk/di_broadband_gateways/di-524/di-524_manual.pdf
Dec 08, 2008 | D-Link AirPlus DI-524 Wireless Router
Connecting two networks
Yes. For your router go to the computer that has the router attached. Open up Internet Explorer and in the address bar type in the IP 192.168.0.1 That will open up your router configuration. Just be warned that you should NOT play with any of the numbers that are there unless you know what they are.
Hope This Helps
All The Best,
RCF
May 27, 2008 | D-Link AirPlus DI-524 Wireless Router
D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE) Logo
29 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
