Question about Masterbuilt ESQ30B Smoker
Where can I get a replacement LED unit for Masterbuilt Electric Smoker, Model #20070408
  • 72 Answers
SOURCE: MASTERBUILT GAS SMOKER
Here is the link for the maunel online in pdf format
http://www.masterbuilt.com/pdf/manuals/7%20in%201%20Smoker.pdf
the main website says individual parts will be availible for sale soon, main website is
http://www.masterbuilt.com/index.html
hope this helps
Posted on Nov 09, 2008
SOURCE: Element won't heat on Masterbuilt smoker
I called Masterbuilt and they said they no longer sell the elements. you have to buy the cabinet @ $189 for the 40" model. I decided to pull my element and see if i could find one that would work by going to an appliance repair parts store.
When i pulled the element, i found that the terminal that plugs into the element was burned/melted in two. i replaced the terminal end, pluygged it in and tis working fine.
to remove the element, you need to remove the element cover/chip loading chute first. its easy, 2 sheet metal screws and 2 nuts and 2 machine screws. one of the nuts/machine screws is a little hard to get back on when you reassemble but it can be done. after the cover is removed, you will see 3 screws where the element goes through the back wall. only removed the left and right ones. do not loolsen or remove thecenter one. after you remove the 2 screws, you can coax a small amount of the wire leads out into the open and you can inspect them to see if they are broken.
if the problem is truly a bad element, you will have to find an element somewhere. i cant help with this except to say that Masterbuilt customer service says they are negotiating with their supplier to see if they can sell the elements seperatly. they hope to have that resolved by summer.
hope this helps.
D Smith
Posted on Dec 09, 2008
  • 7 Answers
SOURCE: My Masterbuilt electric smoker stopped heating will cooking
I just bought a new Masterbuilt Smoker by default two weeks ago I borrowed a friend’s to smoke about 30lb. of Salmon to then can. Ran the smoker every day for three day. ON my last batch the heating element would not work. Talk about Frustrated! The Smoker was only 2 yrs. old.
Knowing I borrowed I felt I had to replace. So online to Cabelas and I ordered my buddy a new smoker and had it shipped. I then found this website... GOT TO LOVE the internet. I saw many other people had the same problem. Found an Answer...
The Problem was one of the connector to the heating element was poor quality and if you don't clean your smoker on a regular basis. The heat and moister caused the small copper connector to corrode and the wire to come loose. I took a wood chisel and cut off all the rivets on the back. I was then able to pull the back off with no damage and access the small box in the lower back. I found the connector. Went to the hardware store and bought a replacement for .75 cents. A pair of wire crimpers and the problem was fixed. I also bought ½ inch Sheet metal screws to secure the back it was good as new. So I returned the smoker to my buddy and kept the new one. When it arrived I saw Masterbuilt has since fixed the problem and provided an access panel to the element and connectors.
Mike in Alaska
PSU313@yahoo.com
Posted on Jul 03, 2010
heatman101
  • 43501 Answers
SOURCE: can you buy a replacement heating element
Here is a pdf of the smoker book and on page 4 there is a parts list with the cust. service number to order replacement parts...there is an element kit listed there, that is what you need.
http://www.masterbuilt.com/pdf/manuals/Smokehouse%20models%2020070206,%2020070106.pdf
heatman101
Posted on Jul 25, 2010
kel1guy2002
  • 3740 Answers
SOURCE: Masterbuilt smoker model 20070910 with
Hi and welcome to FixYa, I am Kelly
It is telling you that the temp is below 40 degrees F. All you need to do is warm up the temp probe to 40F and it should work just fine. Use a hand held hair dryer or a warmed up shop vac on b.l.o.w to warm it up.
Happy New Year,
Kelly
Posted on Jan 01, 2011
Masterbuilt 20072612 ERR1 error code
ERR1 MEANS YOU NEED A NEW BODY KIT. PER MASTERBUILT, THE SMOKER IS DEAD AND NEEDS A FULL BODY KIT (BASICALLY THE ENTIRE UNIT)
Apr 18, 2014 | Masterbuilt 20070106 Electric Smoker
The Masterbilt 20070106 which we bought 18 months ago is "dead". There is power coming from the electrical outlet, but there is no power to the smoker. I do not see a website for parts for the...
You are not the first Masterbuilt Electric Smoker owner to have this problem. The Model 20070106 has been plagued with electrical problems from day one. Maybe, that's why it only has a 90 day warranty?
As far as parts are concerned, you can call Masterbuilt (800-489-1581), first to see if they can help you. More than likely, you will need to replace the electronic control panel on the top of the smoker and maybe the electric element, too.
Another place to try is www.factoryapplianceparts.com.
Sep 20, 2011 | Masterbuilt 20070106 Electric Smoker
I have a Masterbuilt electric smoker and have lost the instructions that came with it. Would instructions from a different smoker work with my Masterbuilt? Do you know how I might get the Masterbuilt...
Masterbuilt makes several different models of electric smokers. f you can furnish the correct model number of yours, I may can help you.
Thanks for choosing FixYa.
Aug 05, 2011 | Grilling
Exactly how does the charcol come into play not exactly sure where to place it.
Debbie, unless you listed the wrong model number for your Masterbuilt Electric Smoker ... Electric Smokers don't use charcoal at all. They use wood chips, that are placed on the wood chip tray, just above the burner. The smoldering wood chips generate the smoke.
In case you've misplaced your Owners Manual. Here's a link to it that you can download and print for future reference. http://www.masterbuilt.com/pdf/manuals/07092010%2020070910%20Manual.pdf
Hope this helps you to enjoy your smoker.
Apr 16, 2011 | Masterbuilt 20070106 Electric Smoker
I NEED A MANUAL FOR MY MASTERBUILT ELECTRIC SMOKER
Here is a link to the Masterbuilt Smoke House 30" Electric Smoker, Model # 20070210. Which is what I think you have. You can download and print the manual.
http://www.masterbuilt.com/pdf/manuals/20070210%20ESQ3082%20Manual.pdf
Hope this is what you need. Please let me know.
Mar 07, 2011 | Masterbuilt Electric 30inch Smokehouse ...
Digital panel no longer works. need source for circuit board and approximate cost
Masterbuilt Digital Smoker no longer heats up and digital display has stopped working completely. The unit acts like there is no power to it and is completely dead. By replacing the digital component will this solve my problem
Jul 01, 2010 | Masterbuilt 20070106 Electric Smoker
Masterbuilt ESQ30B Smoker Logo
96 people viewed this question
Top Masterbuilt Grilling Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Masterbuilt Grilling Expert? Answer questions, earn points and help others
