Question about Samsung HT-X715T Theater System
Unit does not want to switch on no power ...What could be wrong???
  • 52 Answers
Make sure it's plugged in. Sounds a little silly but you would be surprised...
Make sure the wall socket works. Plug a lamp or something that you know works.
Might be a fuse. Look in the back of the unit to see if it's accessible, otherwise you have to open the unit.
Posted on Sep 03, 2010
Why do i have no audio or faults.
1. speakers not attached correctly.
2. power not turned on
3. volume turned too low.
4. blown fuse.
5. blown power transistors.
6. antenna not connected properly
7. wrong selector switch pressed, receiver in wrong mode.
Given that you've provided no information at all as to whether the unit was working properly previously; if the unit stopped working while it was playing; whether the unit was fine until the last time you powered it off; anything you did prior to the unit not working such as disconnected the system and reconnected it again, etc. the possibilities above may provide your solution.
If the unit is producing an error code, get a copy of the manual and look up the error code.
Otherwise, the unit may need to be repaired.
Apr 13, 2015 | Pioneer Elite VSX 51 AV network receiver
Waring pro electric deep fryer won't turn on. No issues with the outlet, used twice before with no issues. What's wrong with it? No parts missing
Turn power off. take off bottom cover and check power is coming the the Heater coils. If no power check for blown fuse. If you have power at Heater Terminals then you need a new Coil
Mar 22, 2015 | Waring Kitchen Appliances - Others
Error code 212
212 Comms Error between Outdoor Unit and HR Box No3. 1. Defective connection in HR unit power supply and transmission connection 2. Wrong setting of the HR unit Rotary switch and Dip switch 3. Defective HR unit PCB
Feb 14, 2015 | Heating & Cooling
My microwave just went out .... how do I see what's wrong with it....
Sorry to read about your problem.
It seems your have a general failure in the power control or switch failure on the unit. if you unit has power, and things lite. it is more likely you have a control/switch problem,
since you can replace your unit for under $100.00 a service call would not be worth it.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
sdsf
Dec 22, 2010 | Emerson MW8991SB Microwave Oven
My power switch won't turn on and a green light on the back of the computer is blinking when the red switch is on the 115 and stops when on the 225. What do you think is wrong?
First off, the red switch is for 155 or 220 volts and should not be adjusted or moved from its position.
Now, disconnect the unit from its power source and allow to set for 3 minutes.
Re-install your power connection and do not push the power switch.
Look in the rear of the unit at the power supply and see if you have a green light.
If so, push power and have fun.
If not, you will need to most likely replace the power supply.
Good luck..
Nov 24, 2009 | HP Compaq Presario SR1303wm PC Desktop
I turned the cam part of the switch the wrong way and now switch always stays open circuit. The cam causes the switch arms to touch. By turning the cam the wrong way, the switch arms get bent and now won't...
I have a 88W and a 200 W power units that had the same problem after I turned the ON/OFF post the wrong way. I took both units apart after finding the screws. On the 88 W unit there a three screws, two obvious and the third under the timing wheel. Pry the wheel off using two paint can lid pry tools. Note that the only thing holder the wheels is the center piece pointing to the ON/OFF post. Find the switch that surrounds the post inside and you will find that the switch brass wipers are bent. They need to be pretty much in a straight line (not knowing what they originally look like. It's pretty amazing engineering but ought to not damage when turned the wrong way.
The 200W unit is the same design except comes apart differently. There are two screws slightly under the label at the two bottom front corners. With an exacto knife peel back the corner about 1/2 inch to find them. The other two are obvious. Bend the ON/OFF switch wipers the same way. Note that after they are bent properly, if you turn the post one tick, (a tick is the amount that the timer, red and black ON/OFF clips cause the post to turn), it contacts should connect then disconnect for the next tick.
Oct 25, 2009 | Malibu ML200RT - Low Voltage Power Pack...
Plugged in with power switch on but no power to the unit
Just open the unit and go to power supply section and check the fuses maybe its busted already replaced it with a identical rating,and renew all solders in parts joints in power supply section.maybe its loose or crack.
Hope it may help you;
Regards;
VOTIT
Apr 23, 2009 | Wurlitzer Jukebox 1015 One More Time...
Motherboard power on but no display.
Greetings!
Check first if all the cable, wire are connected properly.
See also at the back of your power supply if the switch is on, cause some power supply have switch aside from your system unit.
Usually once you open your computer you can hear a beep sound if their is no beep sound means something wrong with your computer.
As you turn on the computer see the fan of your power supply at the back of your unit if it revolves if not something wrong with your power supply, if the fun of your power supply re volves it's your motherboard have something wrong.
Thanks
Nov 11, 2008 | Intel D845GVSR Motherboard
Charging
"unit turns on and off with the ignition switch, sometimes."
There is something wrong with your power cord or the connection to the cigarette lighter. Your unit should turn on and off with the ignition switch. If the unit is on and doesn't turn off with the ignition switch then your unit is running on battery. If your unit doesn't turn on with the ignition switch then the unit is not getting power from the cigarette lighter.
Dec 28, 2007 | Garmin StreetPilot C330 GPS Receiver
Samsung HT-X715T Theater System Logo
82 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
