Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
My ge refrigerator two door make snow in the freezer and not cool good
  • GE Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 03, 2010
I have a GE GSH25JFTA CC refrigerator and it is not cooling properly. What should I check or replace?
Depending how long the power was off you may have an ice blockage in the freezer. Normal cooling causes the freezer coils to build up frost and snow coating all over the coils. A normal defrost cycle melts that frost/snow off and keeps the coils clear so the fans can move air through the coils.During the power outage the frost may have started to melt wetting the snow. If the refrigerator then came on and re-froze the wet frost/snow into a solid block of ice, the normal defrost cycle would not be able to clear that solid ice out. So it may be blocking the air flow. Remove freezer back panel and see if there is ice back there. If yes--use something like a hair dryer to melt everything out until it is completely clear. Make sure the fans are running also.
Apr 14, 2015 | GE Refrigerators
I have a GE refrigerator, the refrigerator part of the fridge went warm and will not cool, the freezer part is cool but will not freeze ... what do i do to fix this situation?
where is the freezer?top,bottom or side by side and what is the model number.first off when you open the freezer door do you hear the fan blowing,also touch the back inside wall of the freezer,is there like ice or snow on it,if so you have a defrost problem.G,E, has had a lot of problems with the computer boards,send the model number and let me know what you find and i can help you better
Dec 03, 2010 | GE Refrigerators
My ge profile PFS22SISBSS FRIDE IS NOT STAYING COOL WHAT COULD BE THE PROBLEM?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 21, 2010 | GE Profile PFS22SBSS Bottom Freezer French...
GE GSS22JF not cooling both freezer and frigerator. Steps to try to figure out problem
open the freezer door,from the bottom up remove the second draw or bin and touch the back wall to see if there's like snow or ice on the back wall,if so you have a defrost problem,with a meter check the heater and the thermostat,if no ice then you have a bad computer board located on the back outside wall of the machine part number wr55x10942.let me know what you find
Sep 26, 2010 | GE GSS22JF Side by Side Refrigerator
Back wall of frezzer covered with snow, removed cover, coils frozen over with ice. have to de-frost freezer every 3-4 wks. Model#: GSL22JFTA BS
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Sep 11, 2010 | GE GSS25JFM Side by Side Refrigerator
No ice from icemaker, rest is 'warming up' freezer fan goes on
OK I need to ask you a few questions about your refrigerator. You mentioned that both sections are warm does this mean not cooling at all as if warm like room temperatures or do you mean not cooling enough to make ice or keep food at safe temperatures like 38 degrees f.? please answer theses questions because this will tell me a lot. If you look into the rear of freezer do you see snow or frost building on the rear wall of freezer? If yes then unplug and begin manually defrosting and placing frozen goods into a standby refrigerator. We will need to decide if there is a defrost problem, compressor start problem or a motherboard problem. Could you do that and answer these questions ASAP so we can get you going or decide what direction you will need to take. Thanks, Sea Breeze
Mar 29, 2010 | GE Refrigerators
Snow building up around ice maker opening
Check to make sure the dispenser door is closing all the way and I mean ALL the way.
GE has had issues with the solenoid rusting out on those units and not letting the door close all the way.
Sep 03, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
SNOW FORMING IN FREEZER
Could be a number of things. Is the fan running in the freezer section, are the door gaskets sealing completely, even on the bottom of the doors? Could be a defrost issure where the thermotat is allowing it to over heat during defrost and the the cooling cycle starts after defrost and forms the ice an snow from the moisture in the unit.
Dec 30, 2017 | GE Profile 21.6 cu. ft. Side-by-Side...
Freezer wont stop running
check that the dispenser flap is sealing properly as an air leak here will produce frosty snow
Aug 17, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a ge side-by-side refrigerator. The freezer part is working by the fridge part is barely cool. What can the problem be? This refrigerator was purchase in 09/99.
Check point 1: Check on the back wall of the freezer compartment for snow build-up, if there is snow on the back wall you have a defrost system problem. Call for service.
Check point 2: Make sure the condenser under the cabinet is clean. If it is plugged up with dust or dirt clean it by vacuuming it out then blowing it out.
May 15, 2008 | GE Refrigerators
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
109 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
