Question about Compaq Computers & Internet
How to fix error code 1516? - Compaq Computers & Internet
  • 480 Answers
You can try a doing a Check Disk on the computer.
Click on start > open my computer > right click local disk C: > go to properties > go to tools tabs and click check disk > put check on the boxes to fix the issue then click on start > it will prompt you to restart the computer > click OK > wait for the restart and the check disk then see if you still have the same error
Cheers!!!
Posted on Sep 03, 2010
My H3 Hummer 2006 is giving me p1516 p2176 p2135 p2176 and p2135 codes what to do so I fix it
code p 2176 refers to both the accelerator position sensor E and the throttle position sensor E--maximum stop performance ===causes --wiring---APP or TP sensor
code p 2135 refers to same items but switchF A/B- voltage correlation or implausable signal===causes --same as previous
I have no listing for a p 1516 as the book does not cover it but I am guessing that it is a specific code to hummer and still related to the problem area of the APP or TP units
if you find and fix the APP or TP problems then that code by go
Oct 19, 2014 | Hummer H3 Cars & Trucks
I have a 2001 saturn with codes po1523 1516 0606 0221 how do i fix them
If you can purchase a Haynes repair manual in it there is a trouble code definition table telling all the code meanings! You could go to your parts store and give them the codes and they can look it up too but you will still need a repair manual to show where in relation to the codes the fault is! Good luck!
Oct 05, 2014 | Cars & Trucks
Error code 600 shows up when your streaming movies?
There are 9 different Netflix contact info to contact. Below are the best contact info based on turnaround time and results posted by other users.
888-638-3549
800-585-8131
866-716-0414
888-357-1516
866-579-7172
866-579-7115
tweet @Netflixhelps; Customer service Twitter feed
Online Help
Netflix Customer Service
First go to https://help.netflix.com/help; Online customer service submission form
Live Chat
First go to https://contactus.netflix.com/help Click "Start Live Chat" at the bottom
888-638-3549
800-585-8131
866-716-0414
888-357-1516
866-579-7172
866-579-7115
Online Help
Live Chat
Apr 06, 2014 | Netflix
P1516 p2101 27 chevy cobalt
check the plug going to your throttle body sometimes the small wires will visually look ok but will have break 1-4 inches from plug or in the plug itself
Dec 23, 2013 | Chevrolet Cars & Trucks
2 error codes on 2006 chevy cobalt p2101 and p 1516
P1516 IMRC Input Error (Bank 1)
P2101 Throttle Actuator Control Motor Circuit Range/Performance
fgtech v53
Mar 28, 2013 | 2005 Chevrolet Cobalt
Any known fixs for code 1516
Change your throttle actuating control about $160 bucks
Oct 06, 2011 | 2003 GMC Yukon
Raw file system
To fix the problem
Disable the S.M.A.R.T error detection feature in the CPUCool program or similar utility.
Boot to the Windows 2000 or XP installation CD, and at the Startup menu, press R for repair.
In the Recovery Console, type the following:
chkdsk /p
When the CHKDSK process has finished, reboot the computer.
Run the program again.
The error should no longer be reported unless you start using the S.M.A.R.T error detection feature again.
Error occurs with PartitionMagic 8.0
If you encounter Error 1516 with PartitionMagic 8, first run CHKDSK /F on the affected partition. For instructions on how to run CHKDSK, read How to Run Microsoft's CHKDSK from the Command Line. If this does not fix the error, try running PartitionMagic with the /IFC switch, which causes file system errors to be ignored.
To run PartitionMagic with the /IFC switch
Boot from the first PartitionMagic rescue disk.
When you are prompted to insert the second rescue disk, press Ctrl+C to drop to the command (A:>) prompt.
Insert the second PartitionMagic rescue disk and type the following:
pqmagic /ifc
Press Enter.
please go ahead and try the above steps may be it will fix it
Feb 26, 2009 | Symantec Norton Partition Magic-8.0...
No picture, no sound, error code 7
Sounds like one of two problems
1) Convergence chips are shorted....One quick test is to desolder and remove both STK392 chips....then power the set on. If the tubes light up the chips were shorted. You can get new ones from www.TvRepairKits.com
2) Another possible problem is a bad HVG - AKA the flyback.
Try the convergence chip test first. Note: On some Philips sets you can just unplug cable "1516" instead of removing the chips.
For instructions on how to find/remove cable 1516 visit the website listed above and click on their tips page. On that page click on the "Magnavox DPTV3xxx Checks" link.
Jan 31, 2009 | Philips 46PP9302 46" Rear Projection...
Error code 1516
Error Message:
Error 1516: Partition improperly dismounted (EA3905EC).
Solution:
Solution #1: One possible reason for the error involves the improper setting of a “dirty” flag in a restart record in the journal file, or activity log for a given hard disk. The term flag refers to a yes/no or true/false variable or a specific quantity that indicates the current state of a program or a piece of hardware. This can happen if the system crashed, or lost power while you attempted to create or write to a hard disk.
Running CHKDSK can solve this problem. Click Start, Run, type cmd, and then click OK. The Command Prompt should appear. Next you need to indicate the disk you want to repair. Type cd C:\, and then press ENTER. If you suspect that the error is on a drive other than C:\, substitute the appropriate letter for the drive you want to check. Next, type chkdsk /f, and then press ENTER. This command checks the drive you indicated for errors, while the /f switch fixes any errors. You may need to run the utility more than once to fix all errors.
Solution #2: Another reason for this error involves a conflict with Windows 2000/XP and SMART (Self-Monitoring Analysis and Reporting Technology) error detection, which is a feature of some software utilities. To resolve the problem you’ll need to disable the SMART error detection feature. Consult the utility’s documentation for instructions on disabling the SMART error detection feature. If you can’t turn SMART error detection off, you may need to uninstall the offending utility.
Next, insert the Windows 2000 or XP installation CD into your computer’s optical drive and reboot your computer. At the Startup menu, press R to access the Recovery Console. Type chkdsk /p and press ENTER. Reboot the computer and attempt to run DriveCopy. If SMART error detection was successfully disabled, then you shouldn’t encounter the error anymore.
Dec 13, 2007 | Computers & Internet
Computers & Internet Logo
35 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
