Question about Bosch Dishwashers
I cannot figure out how to advance a cycle without having to go through the entire cycle. For example, I had a drain problem with my sink and the plumber put the rinse and hold cycle on for about 10 minutes; now every time I want to turn on the dishwasher it is in the rinse and hold cycle. How can I change it???
  • Bosch Master
  • 2,605 Answers
Welcome to FixYa.
Your post doesn`t specify a model number, however on most Bosch dishwashers in order to change from "rinse & hold" to "regular" ( or any cycle ) simply turn the unit "on" and once the machine begins push the regular button twice.
Or the button applicable to the cycle you want.
That should change the display to look like this...
If this doesn`t work, try it for "econo" or any alternative and let me know how it goes.
Good luck.
Regards,
Macmarkus :)
Posted on Sep 03, 2010
Water leaked all over the floor after completing drying cycle
It is probably a clogged drain line that dumps into either your disposal if you have one or directly in the drain under your sink you may have an air gap on the sink they tend to plug around this area.
Apr 27, 2017 | Kenmore 15121 Built-in Dishwasher
Dishwasher will not advance through cycles - Frigidaire GLD2250RD
Thanks for writing to Fixya.com.
Is your drain hose stopped up with debris - have a double sink next to the dishwasher. You can plug both drains, one at a time with the water running in the sink while holding the other drain closed. Try it first and if it works, its free, otherwise you may find it's another issue like maybe a bad pump motor on the dishwasher.
Thanks for contacting Fixya and please accept the solution if it has helped you.
May 27, 2010 | Frigidaire 24 in. GLD2250RD Built-in...
Water does not drain out
Hi and welcome to FixYa, I am Kelly.
There is always just a minimal amount of water in the bottom of a dishwasher so that the pump seal does not dry out causing water to run through the pump motor. Usually though it is not visible yet is is possible.
Excess water in the bottom of the tub post cycle are a sign of draining problems however this is a list of what it could be.
1. A partially clogged drain
2. The timer motor is not functioning properly
3. A broken or worn pump impeller
4. Clogged wash arm holes.
Here is what you need to do:
Check your entire drain system. Start at the final outlet and work your way backward to the motor pump connection on the dishwasher.
Suspected areas are.
a. The sink connection outlet is clogged (this can be inside a garbage disposal.
b. The air-gap is clogged in the very top part of the air-gap (Usually located on the back of the sink and is around 3 inches tall) Remove the cover, unscrew the top nut and check under the horse shoe bend inside the plastic top for obstructions. Clean as needed)
c. There is debris on top of the the motor pump housing blocking the inlet drain. (This would be inside the housing of the lower wash arm on the very bottom)
d. The motor pump outlet drain port is partially blocked. (only accessable from the motor pump exit hole after drain hose removal.)
A partially blocked inlet tub drain to the motor pump would also explain why the lower part of the dishes are not getting clean. Additionally you would have spotted dishes post cycle.
When the drain is partially blocked some models use the float level switch in the tub to control the advancement of the timer. If the water does not drain the motor pump continues to run and run and the cycle does not advance until the tub is drained and the float switch senses same. i.e extended cycle
Check under the float assy for debris.
One more thing to check is the lower wash arm holes for debris or obstructions. If the wash arm is retaining water it can drip out after a drain cycle and cause the puddling you noticed.
Thanks for using FixYa.
Kelly
Apr 29, 2010 | GE 24 in. Profile PDW7800 Built-in...
Not washing dishes
Hi and welcome to FixYa. I am Kelly.
Dirty dishes post cycle are a sign of draining problems however this is a list of what it could be.
Kelly
Apr 27, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Not cleaning dishes properly
A partially blocked inlet tub drain to the motor pump would also explain your soap dispenser problem. Additionally you would have spotted dishes post cycle.
Kelly
Fridgidair Dishwasher takes long time to run
ok with the soap prime the sink before you start it and clean the dish washer.take a table sppon full of tang put it the dispencer and run the unit this will clean the unit
Apr 25, 2010 | Dishwashers
Standing water in bottom of dishwasher when cycle is done
It sounds like your sink plumbing may be plugging up. Unplug garbage disposal if possible and check for obstructions. DO NOT place your hand in the unit while plugged in. Try to look into it with a flashlight. If nothing is seen then you can take the traps off of the sink plumbing and check there for obstructions. If this is also clear then try some clog cleaner in the sink drain to see if that helps.
Dec 16, 2009 | Frigidaire Dishwashers
Vessel sink's drain is leaking
a waste with a over flow does not work well with a vessel sink because the sink is to thin
Jun 16, 2009 | RTO W/ Overflow Chrome 1 5/8" Vessel Sink...
Bosch Dishwasher Not Draining
Im really not all that familiar with the bosch unit, but a few things i would ck. when you cancel a cycle (it should drain the water) is it humming??? does it sound as if it even trickling into the sink discharge?? do you have a disposer under your sink that this unit drains into, if so remove the clamp and look for possible obstructions right there.Honestly passed this ill have to defer to someone else sorry and good luck
Mar 10, 2008 | Bosch SHU9915UC Dishwasher
Dishwashers Logo
195 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
