Keyboard makes a clicking sound when you type
  • 4,737 Answers
I don't think there's a setting to turn on or to turn off the sound. If you've installed any additional software for keyboard, then I can't tell since you didn't mention anything except the keyboard sound. It would be helpful if at least you did mention the Operating system installed on your computer. First try with an external keyboard and check if it makes the clicking sound or not. There are many reasons, but most of all, it's related to motherboard. If you need further help from me, let me know with more details like the installed O.S, and the Laptop model and make.
If the system/laptop is under warranty, you better call them and let them check before you start working with it. Otherwise it'll void.
Good luck.
Thanks for using FixYa.
Posted on Sep 03, 2010
The number keys to the right will not work, even after pressing number lock. suggestions?
Please open Device Manager and uninstall what is showing under "Keyboards". If you're unsure on how to perform these steps, follow this link:http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=c03540049&lc=en&product=5450010&tmp...
Once you have uninstalled the keyboard driver, restart your notebook and it should automatically reinstall for you.
Let me know if this resolves the issue.
  • If the keyboard is not working in Windows, continue with these steps to uninstall and reinstall the keyboard software in Device Manager.
  • Click Start , then click Control Panel.
    Control Panel opens.
  • Click Hardware and Sound.
  • Click Device Manager under Devices and Printers.
    Device Manager opens.
  • Click View, and select Show Hidden Devices.
  • Double-click Keyboards, right-click the keyboard name, and then click the Uninstall button to remove the device from Windows.
  • Restart the computer.
  • The keyboard should now work correctly.
  • Your computer comes with several software programs that can test the keyboard for key or hardware failures. For more information, see the HP Support document Testing for Hardware Failures.
  • Notebook key presses are slow to respond
    If there is a short delay from the time a key is pressed to the time the character displays on the screen, the Filter Keys function might be activated. The Filter Keys function provides a greater range of key press options to fine-tune key delays and prevent inadvertent key presses. To disable Filter Keys and return to the default keyboard behavior, use the following steps:
    1. Click Start , and type keyboard in the Search box. Then select Change how your keyboard works under Control Panel.
    2. Remove the selection from Turn on Filter Keys. Then click Set up Filter Keys.
    3. Remove the check next to Turn on Filter Keys when SHIFT is pressed for eight seconds.
    4. Click Apply, click OK, and then close the Ease of Access Center.
      The keys should be more responsive.
    Pressing a notebook key once types several characters
    If two or more characters appear when pressing a key, use the following steps to adjust the key repeat delay:
    1. Click Start , and type keyboard in the Search box. Then click Keyboard under Control Panel.
      The Keyboard Properties page opens.
    2. Set the Repeat delay slider to Long. Click Apply, and then click OK.
    Notebook beeps while typing
    If the computer sometimes beeps while you are typing, Toggle Keys or Sticky Keys is active. Toggle Keys causes the computer to emit a beep when the Lock keys are pressed. Sticky Keys causes the computer to emit a beep when the Ctrl, Alt, Shift, or Lock key is pressed. Use the following steps to disable Sticky Keys and Toggle Keys:
    1. Click Start , and type keyboard in the Search box. Then click Change how your keyboard works under Control Panel.
    2. If selected, remove the check next to Turn on Sticky Keys. Then click Set up Sticky keys.
    3. Remove the check next to Turn on Sticky Keys when SHIFT is pressed five times.
    4. Click Apply, and then click OK to return to the Make the keyboard easier to use page.
    5. Remove the check next to Turn on Toggle Keys.
      If selected, remove the selection from Turn on Toggle Keys by holding down the NUM LOCK key for five seconds.
    6. Click Apply, click OK, and then close the Ease of Access Center.
      The beeps no longer sound.
    Wrong characters appear when typing, changing keyboard language, or Dvorak
    If the wrong characters appear when you are typing, or you are trying to use a different keyboard, use the following steps to synchronize Windows to the type of keyboard you are using:
    1. Click Start , and type region into the Search field. Click Region and Language from the search results.
    2. Click the Keyboards and Languages tab, and then click Change Keyboards.
      The Text Services and Input Languages page opens.
    3. Click Add.
    4. Select the keyboard you want to use, and click OK.
    5. From the Text Services and Input Languages page, select the new keyboard in the list and click Move up until it is first in the list. This makes it the default keyboard.
    6. Click OK. You can now use the new keyboard.
      If you find that the new keyboard service works correctly and you do not want to use the other keyboard, repeat these steps and Remove the keyboard service that you do not need.
    HP Notebook PCs Notebook Keyboard Troubleshooting Windows 7
    Aug 23, 2015 | HP Computers & Internet
    My computer makes dinging noise when I type.
    Try This
    Go to "HELP SUPPORT"
    Type "on screen keyboard"
    click on settings on on-screen keyboard
    click on make click sound.
    Jul 21, 2011 | Dell Dimension 2400 PC Desktop
    No sound
    Try this:
    Click Start, select Run, type "services.msc" without the quotes and press Ok. Services window will open up. In that window, select the Windows Audio Service and the status and startup type of the same. In case the startup type is disabled, double click on it and select the startup type as Automatic. After that right click on this service and click Start. In case the Start is greyed out, click on Restart. Now check for the sound.
    Jul 07, 2009 | Compaq Keyboard
    I can't get my hp 6980 to print wirelessly. The bluetooth isn't enabled. How do I enable it??
    Normal 0 Go to Control Panel and click on Sound.
    Next click Bluetooth Devices.
    Click Add button, lower left corner of the Bluetooth Devices window.
    Insure batteries are installed.
    Press the Connect Button on the Keyboard (Usually located on the under side of your keyboard) this allows Windows to see the keyboard so you can pair the keyboard to the computer.
    On the computer choose My Device Is Set Up and Ready To Be Found.
    Click NEXT.
    The keyboard should appear in the Add Bluetooth Device Wizard Window.
    Select your Keyboard and click Next.
    When prompted, select Choose a Passkey For Me and click Next.
    Windows will generate and display a Passkey.
    Type the Passkey specified on the Bluetooth Keyboard
    (do not use the keyboards keypad when typing the passkey)
    No charters will appear on the monitor when typed, but if you make a mistake, you can backspace.
    You must enter the Passkey within 30 seconds.
    If you don’t enter the Passkey within 30 seconds, click Back and click Next again.
    Once the Passkey is entered, the Keyboard should be connected to the computer.
    Finish and follow any on screen instructions.
    Hope this helps. Bud
    Jan 26, 2009 | Office Equipment & Supplies
    How can i turn on the bluetooth in my laptop
    Press the Connect Button on the Keyboard (Usually located on the under side of your keyboard this allows Windows to see the keyboard so you can pair the keyboard to the computer.
    Click NEXT.
    Finish and follow any on screen instruction.
    Jan 21, 2009 | Computers & Internet
    Need problem with set up software for bluetooth hp 6720s please helt tks
    Click NEXT.
    Finish and follow any on screen instructiond.
    Jan 19, 2009 | Computers & Internet
    Install bluetooth
    Click NEXT.
    Jan 11, 2009 | Logitech MX5000L
    Connect MP620 via bluetooth
    Click NEXT.
    Jan 05, 2009 | Canon PIXMA MP620 All-In-One InkJet...
    Bluetouth setup
    Click NEXT.
    Jan 03, 2009 | Canon MP610 Photo All-In-One Printer
    I haver tlaptop toshiba A200-1M4 but i cant get drivers for bluethoth and my mic is not working
    Normal 0 Normal 0 Go to Control Panel and click on Sound.
    Click NEXT.
    Jan 03, 2009 | Canon S 100 InkJet Printer
    Computers & Internet Logo
    397 people viewed this question
    David Payne
    David Payne
